Question about Car Audio & Video
How do I hook up my jet sound js-224 equalizer wire color code can you help????
2 Suggested Answers
rteemon
  • 578 Answers
SOURCE: wiring ID- Pyramid SE808ECHO 200watt amplifier/grapic equalizer
THE UNIT YOU ARE USE HAVE SPEAKER IN AND OUT WIRES LOOK AT THE INSTRUCTION AT THE BACK OF THE EQ AND DECIDE HOW YOU WANNA USE THE EQ
Posted on Aug 07, 2009
Need to connect a jet sound graphic equalizer JS-234 to a car stereo. The wires had folded stickers and some a gone. The colors of wires are red,black,gray,green.Only have 2 front speakers .
If it's only 4 wires, Red & black are typically power. red +12volts & black is ground. Gray would be one channel say right side and green would be left (example) you would ground the negative speaker lead on both sides. That is probably an old unit and make sure your car is negative ground. Some Ford & Nissan are positive grounded for some circuits which you may need to reverse the power connections. Make sure there is an in line fuse on the power wire just in case.
Feb 14, 2016 | Cars & Trucks
I need a wiring diagram to get the color codes for a realistic 40 watt equalizer booster model 12-1954
All the wires on my 40watt realistic eq are all the same thickness and I have three red wires can someone tell me what side the power wire should be on and which color wires would go for speakers and which color go for the amplifier
May 09, 2012 | Car Audio & Video
Jet sound equalizer js 214 wire color code
Black wire is ground, Red with 5a fuse is hot. Green/black is L Ground BTL, Grey /black is right ground BTL, the RCAs are left and right low level inputs. Then there is the 5 pin connector. It has a red wire for +12v, two black wires for input grounds, a green wire for left Hi input and a gray wire for right high input. If you install using traditional common ground high level, then you don't used the two BTL wires. Just connect the wires from your 5 pin connctor. If you use the low level RCAs for inputs, then you only need to connect the red and black from your 5 pin connector.(Plus the main red and black) Make sure the switched on the bottom of your EQ are set correctly. COM for common ground and LOW for RCA input or High for Green/Gray wire input. If you are using a floating ground the select BTL and connect the two BTL wires to the floating grounds of your stereo. There is also a line input adjuster so you can adjust your input sensitivity to match your reciever. I have the owners manual if you have any other questions.
Feb 01, 2012 | Car Audio & Video
I dont know where to put the remote wire
If you have an aftermarket stereo you can hook it up to the antenna wire usually blue/white or just blue color if is not an after market I need to know the car year/make/model.
Jan 20, 2011 | Boss AVA-1215 5-Band Car Equalizer
I cant change my phone language from hindi to english
Menu-->settings-->phone settings-->language then choose english.
you could identify the above mentioned path by icons.
Note :
hindi equalent for phone setting and language- are
phone setting ---?₪«?₪¼?¥??₪¨ ?₪¸?¥??₪Ÿ?₪¿?₪??₪??¥?₪¸
language--?₪­?₪¾?₪·?₪¾
thank you
Nov 29, 2010 | Nokia 2690 Cell Phone
I have a 1991 Kawasaki JS 550sx, No spark
that box will not work on the newer bike they are different . you need to not mismatch stuff on the bike you will coast you more money taking cheap rout need right part hope this helps
Aug 06, 2009 | Encore Software Kawasaki Jet Ski...
Wiring ID- Pyramid SE808ECHO 200watt amplifier/grapic equalizer
Aug 01, 2009 | Car Audio & Video
How do i wire an equalizer without any wiring diagrams
how do i hook up my equalizer color code info
Jan 16, 2009 | Car Audio & Video
No color or sound on DVD Player when hooked up with the ShowStopper
Svideo requires the audio cables too, Red and White. Svideo is only carries video.
Dec 30, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
Music plays, but vocals are weak
Check and make sure you hook up the speaker wires correctly to the stereo, they are color coded. This unit does not have manual equalizer settings.
Jan 08, 2007 | Sharp CD-XP7700 CD Shelf System
Car Audio & Video Logo
85 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
