G62 367dx after 2 seconds after the ignition is turned off.i tried to reinstall the boot and remove the battery without success
  • 3,799 Answers
Computers don't have ignition. And they don't have a boot. Are you sure you are asking the right question here?
Posted on May 13, 2013
My Toshiba Portege Z10t will not turn on. No lights, I have tried to start it with and without the power chord connected, have held the on switch down for up to 10 seconds with out any response. The u
Try this:
Unplug the charger from the unit (but leave it plugged into the wall outlet) and remove the battery. Push the power button and hold it down as you plug in the charger. You may have heard of soft boots and hard boots...this is like a super hard boot. If it starts up, you can reinstall the battery. Good luck.
Jan 11, 2015 | Toshiba Computers & Internet
How do I get my key remote to lock/unlock my toyota rav4 2002 model? I changed the battery because I thought that was the problem but it is still not working. The red light on the remote comes on but then...
You will need to try reprogramming the remote 1st, below is the complete procedure. If the reprogram doesn't restore function then you will need the dealer to test the keyless entry system, you may have a bad module or remote (only applies if both remotes don't work).
Start with the key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition(Do NOT Turn) Pull key out.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
3. Perform these steps within 40 seconds.
A. Close then open the drivers door.
B. Close then open the drivers door.
C. Insert the key into the ignition(Do NOT Turn) Pull key out.
4. Perform these steps within 40 seconds.
C. Close the drivers door
D. Insert the key into ignition and leave it in ignition.
E. Turn the ignition to ON (Do NOT Start) then back to OFF.
F. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically
indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
locks should lock and then unlock once indicating successful programming. If
the door locks cycle twice, repeat steps A and B in step 6 as the remote was
not accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Open drivers door.
Aug 24, 2011 | 2002 Toyota RAV4
Hi I m trying 2 program my remote on my 2001 Pontiac Aztec
Obtain all remote transmitters for this vehicle.
1. Close all doors.
2. Insert key into the ignition cylinder but do not turn it.
3. Press and hold the Unlock button on door lock switch on drivers door.
Hold until instructed to release.
4. Remove key from ignition and then insert key into ignition without turning ignition cylinder and remove key.
5. Insert key in ignition a third time and leave key in ignition. Do Not turn ignition.
6. Release door lock switch on drivers door panel.
A Chime will sound 3 times indicating that you are in programming mode.
7. Press both the Lock and Unlock buttons on the remote up to 30 seconds.
A chime will sound 2 times if remote has programmed successful.
8. Repeat step 6 if you are programming additional remotes.
9. Remove key from ignition to exit programming mode.
NOTE: If you are having trouble getting this procedure to work, we have found that some vehicles need step 3 to be done before step 2
Aug 02, 2011 | Pontiac Aztek Cars & Trucks
Key buttons will not operate locking system,i have changed battery but still no good.use master key,gets me into the car but alarm goes off and also when i attempt to drive it.
I have the same problem kinda. Lost my master key and sent my ecu off with a home made 2 button key to program immobiliser. This key works to start the engin and drive but I cannot get the key to program with the alarm and locking system. You can try the following steps as may work for you.
I can get my car into programming mode after step 1 but step 2 does not work for me. The locks do not go off at all, not once or twice. Battery in remote key is fine as LCD lights red.
Can anyone help please?
Toyota celica 2000 - 2005 remote keyless entry programming guide
STEP 1
1. Key out of the ignition. Open the drivers door , all other doors are closed . Driver door is unlocked
a. Insert the key into the ignition ( do not turn it ) take key out
b. Insert the key into the ignition ( do not turn it ) take key out
a. Close and then open the drivers door.
b. Close and then open the drivers door.
c. Insert the key into the ignition ( do not turn it ) and pull it out.
c. Close drivers door.
d. Insert the key into the ignition and leave it in the ignition.
Turn the ignition to on (as far as you can go without turning the engine over ), then back to off .
e. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
STEP 2 (Does not work for me)
a. Press the lock and unlock buttons on the transmitter simultaneously for 2 seconds
b. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock then unlock once indicating successful programming. If the door locks cycle twice, repeat steps 6a and 6b as the remote was not accepted.
Hope this works for you.
Hayley
Oct 03, 2010 | 2000 Toyota Celica
Lights come on but no fans or powerup
Please follow the steps below.
1. Please removed the battery and unplugged the power supply.
2. Held down the power button for 45 seconds.
3. After 45 seconds reinstalled the battery and the power supply and pushed the power button and if it works then you don't need to replace your motherboard.
4. Else try it couple of times or up to five times before it worked if worst comes to worst.
Thanks
Aug 26, 2009 | Acer Aspire 5050-3242 Notebook
Powers up for 1 to 2 seconds shuts itself off
probably a boot loop, hold down the f8 key when you turn it on untill you see a boot menu and select "safe mode", if you can get it to start there, you should be able to shut it down and have it start normaly the next time. if not hold down f8 again and select "last known good configuration". if it still continues to loop after that, you will have to reinstall windows.
Aug 18, 2009 | Acer Aspire 5500 5570-2609 Laptop
Keyless entry
watch this video if the video dosent work go to www.vehix411.com to see the video " />
Dec 03, 2008 | 2000 Chevrolet Venture
Calculator keeps powering off after a few seconds
  1. Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and turn the unit on. This will cause the unit to reboot the operating system.
  2. Hold down [Home] [Enter] [P], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
    1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts. 2. Delete Operating System – The operating system will be deleted without deleting any documents. 3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS. 4. Complete Format – This will delete the OS and all documents for a total erase of memory.
    Note: TI-Nspire family model options 2 and 4 above require that the OS be reinstalled. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
Dec 03, 2008 | Texas Instruments TI-Nspire Graphic...
Laptop wont turn on anymore.
poncha,
Your battery might be dead and it might cause problem to boot.
  • Remove battery, insert A/C adoptor and try to boot normally, if success then you should change your battery and all will be fine. If no success then try next step.
  • Remove battery, remove A/C adoptor. Press and hold power button abt 10 seconds then insert A/C adoptor holding the power button on. Keep holding for 30-45 seconds. If still no success then have a tour to the service centre.
Thanks & Good Luck
Iqbal
May 18, 2008 | Dell Inspiron B120 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
