KENMORE ULTRA FABRIC CARE QUIET PAK PLUS MODEL 110.82791120 WASHING MACHINE. I need an owners manual or to find out how to set the custom memory button. plus its not letting ANY cold water into the machine even on rinse.
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: I have a kenmore elite
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Posted on Jan 27, 2011
Kenmore smartwash quiet pak 9, wash machine door wont lock
the door latch on the machine is already locked in place
or there is electric circuit issue, the wire going to the lock broken, come loose,
you mite try, resetting the unit it it has reset switch.
or
try unplugging the unit for a while 30 minutes than plug back in try setting up a different wash cycle.
if all fail than call the customer service line ask for technical service.
Oct 04, 2015 | Kenmore Washing Machines
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
May 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Need cu size of my broken washing machine.
it is a 3.0 cubic foot.
  • I would do some research before spending a lot of money on a front loader.
Aug 05, 2008 | Kenmore 24032\24036 Top Load Washer
I also need the answer...
Verify Lid switch ..... A solved rating is great motivation to continue giving priceless advise........
Oct 03, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
