Question about Meiko FV 40.2 Dishwasher
Error 303 info 325
Misfiring cylinder 3 on axiom 2004, replaced coil and plug, need info. On cleaning injectors.
how do you know that, (you never said)
P0303 DTC errors? that?
303 means.
#3 cylinders combustion energy is weak, to a tech it means the piston velocity was week, slow to accelerate, it was.
that can be.
1: spark bad (for gas/petrol engines)
2: injection bad.
3: this cylinder compression bad.
it is NOT just a spark issue, not at all.
it can even be air leaks (vacuum ) near #3 but that cause.
injection rates to seem wrong when ok. lean.
see?
id be all over compression tests.
after all cant burn fuel with weak compression.
it may burn but 303 will keep going.
then spark, cant burn fuel with bad spark
and last is fueling. (air and fuel mix)
in that order, is how it happens in real world.
but we take short cuts, sure, and new spark plugs are prudent fast and only $2 each.
Jul 24, 2016 | Isuzu Axiom Cars & Trucks
How do I fix error 303
The 303 error would indicate that your Hard Drive is failing and will need to be replaced - this is also consistent with the start-up issues you describe.
Sep 25, 2015 | HP Touchsmart 520 1070f Desktop PC
I need hepl to error A05-303 , Riso 230
A05-303 Master disposal error - clean master trash bin and check to see if sensor lever in master disposal path is pushed back
May 30, 2015 | Office Equipment & Supplies
I gave xerox xc7225 error code 303-777 can you help me
Solutions for : Fault Code 303-777, 303.777.00: Power Lost Detected Related Fault Code: 303-777, 303.777.00 Solutions ranked by relevance:
  1. This Problem Requires Additional Assistance. Contact Support
We provide support to the greater California area.
Please contact your support provider for this issue.
If you do not have one you can contact us at 858 573 6300.
May 14, 2014 | Xerox Office Equipment & Supplies
Hardisk 1 quick (303)
Sounds like a faulty hdd. Error 303 means bad communication.
Feb 21, 2014 | Computers & Internet
Where can I get an instrution manual for a EW-303 Radar/Laser Detector, please. Tony Mc.
Are you sure its not WH-303? If so, this is a very old Dual band (X and K bands only) radar detector. Manuals are no longer available for them. You can trade it in for a new model, Email, info@whistlergroup.com and ask for a trade in form.
Jan 15, 2011 | Laser Vehicle Parts & Accessories
116-325 error code on docucolor 3535
Hi the 116-325 error for the 3535 is a 24Volt communication error.
The 24V power supply 105E18641 is probably bad, or possibly some wires that connect them.
Whit
Item, Inc
Sep 22, 2010 | Xerox DocuColor 3535 Copier
Lens error 303- I turn on my camera and it says lens error 303 and then shuts off. I don't know what happened.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 18, 2010 | Kodak EasyShare C160 Digital Camera
2003 pt cruiser has 3 errors they are 440,441 and 303. please help
440 and 441 relate to the evaporative prurge flow system and 303 is a misfire detectec in cylinder 3.
May 07, 2009 | 2004 Chrysler PT Cruiser
Dishwashers Logo
41 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
Dennis Boxerman
ray gallant
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
