Question about Johnson Pump Johnson WPS 2.9 Aqua Jet Water Pressure System Pump
Leaking water pump
Our boat has a Johnson WPS 2.9 - the boat is fairly new and it was boxed in. However we noticed water leaking from the box and the floor is badly damp. Opening up the box we found a leak underneath the pump. Have a plate underneath at the moment with the water turned off. Any advice about what to do?
I have a 60hp Johnson outboard motor, ran fine in a barrel of water put it on the boat. Put the boat in the water& the motor started but had no power it wouldn't rev up & it wouldn't move the boat& then it...
Check fuel pump diaphragm,could also be stuck needle and seat in carburettor.dont think it is head gasket,would not cause fuel to come out of exhaust.take off carb cover squeeze primer,if fuel comes out of front of carb it is needle and seat.also check if choke is not sticking
Aug 14, 2014 | Boating
Video on how to replace a water pump for 1993 30hp johnson
One of these videos on YouTube may work for you
http://www.youtube.com/results?search_query=johnson+30hp+outboard+water+pump
Jun 25, 2014 | Boating
Changing impeller on 90hp v4 johnson 2000
Remove Linkage Under Carburetor
Remove Bolts Securing Gear Box Remove Gear Box
Do Not Turn Shift Linkage
Remove Water Pump Housing
Fit New Impeller
Re Fit Gearbox Follow Procedure In Reverse
Mar 16, 2013 | Boating
I have an 8 hp. Johnson outboard motor. 1999. Very little use(less than 50 hrs). I came home from trolling the other day and set the motor on it's stand down cellar. The next day I noticed a clump of...
I believe you got fishing !one wrapped between prop and seal. Remove prop and inspect for line and leak around seal. If not, than the seal under water pump plate is leaking your gear oil.
Sep 21, 2017 | Boating
OIL LEAKING FROM NEXT TO WATER PUMP ON MY 2005 YAMAHA YZ 250
The only oil that can leak from iside your engine is from the gearbox. There is no sump as the engine is lubricated by the oil fed in through the induction system. Clean the area thoroughly and leave it for a while(overnight) then check again. The oil could just be overfill from the 2-stroke tank. By cleaning it first you are given new evidence to identify the leak point. Hope this helps, when you have more info let me know.
Dec 08, 2011 | Yamaha YZ 250 Motorcycles
Leaking water onto floor from inside machine
2 common places.1 leak from the pipe/s from the valves to the dispenser box,2 @6 o/clock position in the fold of the door seal is where these models produce a small split.filter not tight.water bubbling over stand pipe when machine pumps out?these machines are usually fairly leak free so might be just one of these things i`ve listed here with luck.
Dec 29, 2010 | Bosch Classixx WFL 2066 Front Load Washer
How tough is it to change water pump impeller on 15hp johnson
There is no special tricks.Unbolt the gearshift linkage that has access through the side of the leg.Usually a small plate.Unbolt the lower g/box.4 bolts I think.The box should then drop.If not,use a rubber hammer and be patient.Put the lower skeg of the g/box in a vice to make things easier.NOW.When you lift the housing of the w/pump take a note of which way the impellar pump lobes are curled.DON'T put the new impellar in the wrong way.It's probably worth putting in a new seal whilst it's apart.You spin the housing or imp. as you put it together.Use a small bit of grease for the initiall dry start-up.Put some very good grease on the top splines on the driveshaft.It goes straight into the crankshaft.If it corrodes,nothing comes apart.As you put the g/box back on,spin the prop so the splines go back in.There is no special alignment.Gearchange linkage and you go fishing.(take the prop off and regrease the splines on the shaft of it)Hope this helps
Jul 22, 2010 | Boating
40 Hp Johnson outboard motors stalls out after a few minutes running then takes forever to start again
May likely be one of two problems:
1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
Sep 17, 2009 | Boating
Water coming out of the transmission lever grease fitting
The water discharge hose goes through the case in back of the motor. The hose or fitting could be broke or loose. If not the discharge then the water pump is leaking.
Apr 07, 2009 | Boating
Johnson Pump Johnson WPS 2.9 Aqua Jet Water Pressure System Pump Logo
27 people viewed this question
Top Johnson Pump Plumbing Experts
Donni Steen
Tom Chichester
Are you a Johnson Pump Plumbing Expert? Answer questions, earn points and help others
