Question about Cell Phones
Instructions samsung e2100b mobile
How do I change the numbers in my speed dial
SOURCE: Krzr speed dial numbers
First, go to Menu. Then, number 4. Speed Dials. Then, if you wish to move your numbers around, simply click on a filled up speed dial slot you wish to change. It will take you to an Unassigned number, where you will click again. Then, there is an open spot where the name you just moved was. Find the name you want to be there, click, and scroll up to find the empty slot, then click.
Posted on Jun 25, 2008
nematics
  • 431 Answers
SOURCE: input voicemail number incorrectly, how do i correct it?
in samsung press one constantely or u can find in the settings
Posted on Mar 29, 2009
  • 43 Answers
SOURCE: Need to change Speed dial 1 to new messagebank
Go to settings and change the speed dial.
Posted on Oct 24, 2009
kisssmooth
  • 92 Answers
SOURCE: i have a samsung E2100B mobile phone and need a
the PUK code is with your SIM's PIN code information...
Posted on Nov 09, 2009
  • 297 Answers
SOURCE: How do I activate the speed dial and turn off the
go in to menu, reading your manual might brighten you up on this phone
Posted on May 26, 2010
How do you put speed dialing in a samsung GT-C3520
To Set speed dial numbers do the following:
1. In Menu mode, select Phonebook.
2. Select a contact to assign.
3. Select More -> Add to speed dial.
4. Select a number (if necessary).
5. Select a speed dial number you want to set.
The contact is saved to the speed dial number.
Note:
• You can call this contact by touching and
holding the assigned speed dial number in
the dialling screen.
• The first 3 speed dial numbers will be
assigned to the top 3 list on the widget toolbar.
May 16, 2014 | Samsung GT-C3520 Unlocked Quad-Band GSM...
I'm having problems with a Samsung KPDCS-12B LCD phone I've recently been given, I need to add myself to group 501 to take calls for my department (Plumbing) but my phone (Extension 250) is...
Hi you need to do this in 2 parts - firstly to add yourself to group 501 follow the step-by-step instructions which are on the video I have posted. Then follow this to add a mobile number to the directory;
Press the TSFR key
Enter 200
Enter code 1234
=/- key to enable
Speaker key
dial 705
I.e. once in 705
Type in speed number, the cursor will tab over to speed dial slot.
Enter 9 followed by the phone number.
Press 12th button down,
Enter name,
Press 12th button. (You will be back at the speed dial.)
Press tab, then enter the next speed dial slot you wish to program.
NB-
( 705 - Speed dial 12th Button down to toggle between)
( 706 - Speed Name the 2 MMC
Jun 08, 2011 | Samsung DCS 12 Corded Phone
Unlock code for samsung e2100b
Get the unlocking code from http://www.theunlockspot.com/samsung-e2100b/rs10wp9/ . Here i found the unlocking solution for your mobile at cheap price.
Dec 25, 2010 | Cell Phones
I forgot the password to view my files on my samsung e2100b. is their a default password or something?
Samsung E2100B Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Samsung E2100B mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung E2100B mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung E2100B with a NOT ACCEPTED SIM Card.
2 - Samsung E2100B will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung E2100B shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung E2100B.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: I mean, to use a sim card from a network other than the network your Samsung E2100B is locked to.
CODE: Its the unique Unlock Code for your Samsung E2100B.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung E2100B.
Sep 19, 2010 | Computers & Internet
CHANGE SPEED DIALS ON SAMSUNG 816
with the handset on hook dial #06 the display should read MMC DISABLED enter 4321 then 1, press # to enter Press ALM/SD button, dial the 2 digit code 10-98, dial the phone number you want stored ( pressing hold inserts a 3 sec. pause and msg inserts a hookflash) press the ALM/SD button to store the number. repeat the procedure for additional speed dial programming.
Jul 08, 2009 | Samsung Prostar 816 Phone
Speed dialing problem
you should use the number like 3 and the green button which you use to pick up the phone
Jun 28, 2009 | Samsung S8300 Ultra Touch platinium-red...
I want to change speed dial nos. don't have manual for instructio
You should be able to download the appropriate manual from
http://uniden.com/index/manuals_results.cfm
Jan 07, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Speed-dial has quit working
Went into "Contacts" and selected one with speed-dial to edit. Made no changes but saved the contact. Magically, speed-dial began working correctly for all numbers. Rebooting or removing/reinserting the battery may also have worked but were not tried.
Nov 25, 2008 | T-Mobile Dash Smartphone
Speed dial not working
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
YOU WILL NEED A PEN AND PAPER.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
