Tv colour fault
This is what happens when we turn on our alba 32" LCD tv.. This goes on for several minutes before returning to normal.. This happens every time the tv is turned on.. Any solutions?
    Top Expert:
  • Televison & ... Master
  • 75,169 Answers
Problem is with the supply voltage to chorma IC. Contact any service tech: In most cases, some soldering works will be necessary.
Posted on May 11, 2013
SOURCE: TV turns off after short period off time
I have this problem as well-have to keep the house cold enough to keep it on.  I also have a box fan blowing into the right side vents (the side OPPOSITE the built-in dvd player).  It helps a lot to have the fan there, but if you put the fan on the left side vents you will have much more frequent shut downs.
Posted on Sep 04, 2008
  • 520 Answers
SOURCE: Logik T.V. model LK-74 - fault: green and purple on screen
Try moving speakers away from the TV.
Posted on Sep 05, 2008
  • 3 Answers
SOURCE: Tv pictures suddenly goes dark blue
the tube could be going out. Do you have a warranty on that?
Posted on Nov 02, 2008
  • 4 Answers
SOURCE: Green screen
Not really sure how much the tv weighs, but I know it is a bunch. I have 2 of these t.v.s. One I bought at Wal-mart and after about 6 months it started doing this green screen also. I would normally give the side of the tv a good wack and it would go back to normal for awhile. The other tv I bought from my neighbor who was moving for $25. The problem with this one was the "no picture but I have sound". If I wacked this one I could get the picture to come back on for a while, but it would go out again. Well just the other day I took the back off the "no picture" tv and was looking around. I noticed that the circuit board that is attached to the picture tube was loose. I pushed it back down on the tube and put it back together and the picture has been fine since. So I thought I would check the one with "green screen" issues and sure enough that circuit board was loose also. Pushed that one all the way back down and have not had any issues with that tv either. Hopefully that fixed my problem, I guess time will tell. Maybe it will fix yours also.
Posted on Feb 26, 2009
bernardlunda
  • 318 Answers
SOURCE: tv keep going on standby when you turn it on
tv goes into standby all the time if a power supply is not fine, what happens is that a power supply produces two voltages, one small one powers a standby components and bigger voltage powers a line transformer which later produces more small voltages,
then later cancels the first small voltage.
chec your power supply semi conductors like, transistors, diodes and small value resistors, on your power supply. some power supply uses a IC to oscillate a ht. so check a supply at a w/shop.
Posted on Apr 29, 2009
Memorex LCD 32": after about a year a black rectangle about 24" long by 1 1/2" tall has white numbers and letters show up for several minutes goes away. Then a few days ago a large black area of about...
check the settings and see if he has any CC1 or CC's activated or any type of Closed Caption. The only time something like this happens is usually when you have it set for CC2 or something along those lines.
Nov 03, 2013 | Memorex MLT3221 32 in. LCD TV
My 32LD30UA LCD TV is 16 months old, when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.Help?
My HITACH 32LD30UA LCD TV when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.
Dec 12, 2010 | Hitachi 32LD8700 32 in. LCD Television
Alba 42"lcd tv watching tv it just went off,
Alba is now a product of Argos, their low cost help line number is 08456040105
Nov 18, 2010 | Televison & Video
Hi. I have an ALBA LCD32880HDF television which I purchased in August 2009 so just outside warrenty. I have been on holiday for a week and had switched the television off at the wall and returned home...
hi all the black screen solution for me was this (this is assuming you have alba brand tvs and have the black screen BUT can still hear the sound) i after much fekkin around with it eventually found the solution in it (its the bloody backlight brightness in the settings you need to turn it from high TO LOW) ....... now this can be a bit tricky because usually when you have the black screen problem if u unplug the tv for a few hours and plug it back in you only get or should get probably like 30-1min of picture time before the picture goes black so u have to be reallllly fast with the menu button to get into settings before the picture dies (i learned the sequence for my alba lcd32880hdf) it was the following (for this part use the remotes arrows the one with the ok button usually in the centre of them) turn the tv on then click menu then press the up key 2 times then press ok then use the right arrow/button twice (although u cant see what ur doing ur navigating the menu hehe) then press the down arrow/button seven times before finally pressing the left arrow/button (once) <-- (now this bit may need to be done twice if you can remember setting ur backlight to max use it twice it will put it on minimum if in doubt only press it the once remember to totally power the tv off before repeating the steps to reset menus default posistions) remember thats the solution i found for my tv stands to reason (since i did infact buy another tv same brand different model which got the same problem) that this could be a solution for all alba tv users try it worked for me 2 times if ur not sure of the menu look up you tv models menu navigation online to find out the buttons you press gl hopefully it works for you too
Oct 24, 2010 | Televison & Video
Recently our tv has been shutting off. We have
Seems to be problem with Vizio Tv's.. mine does the same thing now. it turns off an on for about 20 times before it will turn on and stay on..
May 25, 2010 | Vizio L32 32 in. LCD HDTV
Screen goes blank but come back when TV is turned off and back on
Ur tv LCD inverter board it dead.Replaced this LCD inverter board ur tv picture will return.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 13, 2010 | RCA L32HD32D 32 in. LCD HDTV
TV turns on, then goes "black"
85% of the time it will be a capacitor ! look at the top of them and if they have a bulge or have been leaking thats the problem there is many of them so study them hard
Aug 07, 2017 | Samsung LN-T3253H 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
