Question about Music
Roland FP3 electric piano maitenance
I have a loose key. How hard is it to remove the cover and fix it?
Hacklet
  • 18 Answers
SOURCE: Roland 3000 Digital Piano 88-Key Full-size weighted keyboard
It's not really for the faint of heart, but generally this is caused by gunk getting into the key circutry. Underlying the 3000's keyboard is a silicone pad with 2 contacts on it, the measurement between each being hit is the issue usually but yours just sounds like there's something in there causing a physical or contact obstruction.
What you really want to do is to remove the keys and clean everything but this isn't easy... You could try using 99% alcohol (from a pharmacy) to clean inside it which may well help you.
There's a good thread on a similar issue at:
http://www.electronicspoint.com/roland-hp-3000s-digital-piano-dodgy-note-t18946.html
Which may help you work out how to do the disassembly if you are brave, but I would start with pouring some alcohol in and poking it and hoping for the best 1st. It sounds crude, but it works amazingly well with some things.
Posted on Jul 12, 2009
  • 5603 Answers
SOURCE: It's a Roland HP-7e digital piano about three years old.
You may need to clean the contacts which are usually conductive rubber. I explained stuff for another Roland problem with two keys that were intermittent. I have an EP-7 that I had to do the cleaning of the key contacts. Use 91 or 99 % Isoprophyl alcohol to clean BOTH the conductive "pill" (Black under silicone rubber domes) AND the traces on the board where they press. Clean gently as the traces have a hard black coating.
Posted on Jul 29, 2009
  • 1138 Answers
SOURCE: Have a HP 1700 Roland Digital Piano that has one
It sounds as if the membrane under the key needs to be replaced. It can be done with some careful work yourself but you might want to consider having it serviced by a Roland dealer as apparently the parts are becoming scarce. Hope this helps.
Posted on Aug 20, 2009
  • 1138 Answers
SOURCE: Roland KR-5500 digital piano
Unless you are skilled at electronics troubleshooting, you would probably be better off taking it in to be repaired. It might be the power transformer or a filter capacitor or a number of other things. The problem may not even be visible. You will definitely need a schematic and some test equipment. Try this site:http://www.vintageplanet.nl/ or this site:http://www.rangeraudio.com/stock16.htm
Posted on Oct 18, 2009
Prestopick
SOURCE: I need a service manual for Roland FP8 piano, or..
Did you ever get hold of an FP-8 service manual? The weight replacement is relatively simple: The case opens by removal of eight screws, four at each end on the underside. The top then hinges up. Keyboard assembly is removed by first unplugging the two white ribbon connectors at the center, then removing the screws at the front edge (underneath) and the screws (gold) at the back of the assembly (accessible from the top). Keys pop out by spreading the two "wings" at the pivot point, and then the weights (Roland calls them "hammers") lift out. Roland will sell you new ones, but I have no idea whether the replacements are any better than the originals. I've done two of these pianos so far, and have a third waiting to be worked on. I do have a service manual, but I think I downloaded it freebee somewhere.
The other failure mode on this piano is the electolytic coupling caps on the output board - I've replaced all of them on both pianos - don't remember the value offhand.
Paul Prestopino presto11@verizon.net
Posted on Nov 19, 2009
Had lots of buzzing coming from the back of Marshall AS50D. Removed the back cover and buzz gone. Any problem with leaving back cover off? Warnings on the back say not to remove the cover!
It was probably just loose screws and the cover was vibrating. Reinstall it and check that the screws hold in tight. If they're not, fill them with glue and some toothpicks, redrill the holes (the bit has to be as thick as the center of the screw, so that just the threads dig into the wood) and reinstall the grill.
If the vibrations persist, that means something else is loose. Try first with the screws that hold the metal chassis. Check for loose speakers, too. Then try the screws and nuts that hold the transformer, PCB, etc. These should have thread locker and not be loose, but if they are, clean it well with thinner and reapply some thread locker.
Only do this if you have experience and know what you are doing, and the safety precautions you have to take. Don't think you know, read safety precautions when working with electric equipment. The safest bet is to take it to a tech.
Also, removing the cover changes the sound of the amlifier. It should sound more bassy. It doesn't have tubes, so it shouldn't be a big deal, except that you should keep it for resale.
Jul 22, 2017 | Marshall Music
How do I remove the cover to fix a popped-up key?
Fixing the keys on digital piano. try to watch the video maybe there is a tips to fix your piano. thanks
Dec 26, 2015 | Casio Privia PX150 Digital Piano
Is it OK to superglue the key guide to to circuit board?
if the pin is plastic the try deforming the end bit so that it has to be pushed hard into the holes (one end only)
Apr 20, 2015 | Music
How do I connect my roland piano 5500 to an amp
On the rear of the piano there will be two 1/4" jacks labeled Output Left and Right. One will be labled Mono as well. If you are using a stereo amp, use both, and if a mono amp use just the mono output. If your amp is a guitar type, connect a shielded cable with 1/4" phone jacks such as you'd use with an electric guitar from these jacks to your amplifier. If you are useing a home stereo amp, you will need a cable with 1/4" phone jacks from the piano to RCA phono jacks on the amp end.
Oct 08, 2014 | Roland HPI-7F 88-Key Digital Piano -...
How can I repair roland digital piano model ep 95?
Sounds like something is on the board and is causing the problem. Try cleaning it with rubbing alcohol on a cotton swab, or spray clean it with electric contact cleaner spray. Let it dry and give it a try. Be sure to unplug the piano when you're in there working on it. Also, check for loose resistors, diodes, etc. Re-solder them if they're loose.
Sep 03, 2014 | Music
How do I replace one key?
You will need to gain access to the keybed, remove screw from back of keybed the fix it to the base of the keyboard. Slide the keybed back making a gap of about 2cm at the front of the keybed.
Look at the back of the key towards where it pivots and you will see a small arrow, push something like a credit card between the keys at this point and the key will pop up, you can then slide forward releasing the key.
If you need more info please ask.
Jun 07, 2014 | Yamaha YDP-161 Arius Graded Hammer Piano...
I have a key that sticks really bad...how do I fix it?
carefully remove the cover of your ypt-320 and also remove the sticky key to check the rubber pad under it .try replacing it.
Jun 03, 2014 | Yamaha YPT-320 Keyboard
The b key strikes to hard, so there is any touch resopnce on the middle B key, what can i do to fix if?
You will have to clean the keyboard touch pads. its a pain full job because one has to remove at least 50 screws before one gets access to the key pads. Remove the back cover and make a note of what screws goes ware.Then remove the screws that hold a long circuit board over the keyboard ( lots of small screws ) . Invert this board and clean the black carbon tracks as well as the rubber key pads with solutions like WD40. Install it back in the reverse order making sure you put all the right screws in the right place. Should work fine after that until dust again gets in between.
Sep 26, 2011 | Yamaha Mm6 Synthesizer Keyboard...
How hard is it to repair a sticking key on the keyboard. I have a new Yamaha MM6 and it's going to cost me all kinds of shipping charges to exchange it. Was wondering if it would be worth it to just...
It kinda depends on if a hammer is broke or key is broke. Or if a foreign object is stuck in there. Typically not hard if you can remove screws and remember how they go back in. TypicAlly the bottom panel comes off keyboards ( start by removing those screws ) or the top case will fold up ( still bottom of keyboard screws ) then multiple screws to realease keyboard assembly. May have to disconnect some wires/ ribbon cables so have a sharpie ready to label to ensure correct reassembly. Then it's all about if they have separate keys or a keytree or sometimes just removing ba key and reseating fixes sticking problems. Get yourself a can of blow off or contact cleaner just in case. Not sure who locally to you sell parts but you can always call manufacturer and ask who does their distribution for parts.
Aug 26, 2011 | Yamaha MM6 Mini Mo Keyboard Pro
Keys on yamaha digital piano are sounding more than one note at a time how can i fix this?
The keypads can develop dirt , failure of pads which can result in such malfunctioning. If you are able to open the piano then carefully remove the keypads , clean the surface and reset.
this must solve the issue unless the pads/springs/mechanism are having fault.
Jul 05, 2011 | Roland Hp337 Digital Piano
Music Logo
49 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
