Question about Simrad Nss8 Navigation Pack Nss8 And 3g Radar
Simrad NSS8 Touch screen stops working
A few minutes after startup, the touch screen function stops working.
Touch screen
After clearing the memory,or if the touch panel detection function is not working correctly,follow this procedure to calibrate the touch screen.Press the yellow reset key ,press 1993 and press red stop key 5 times to open the self diagnostics menu.On the touch screen press Touch Screen Adjust.Use a pointed tool to press the upper left mark.Press the lower right mark after it appears.Touch a few spots on the touch pannel to confirm that the marker appears exactly where the screen is touched.When you are finished press OK on the scree,touch Exit on the screen to close the self diagnostic menu and save the calibration settings.
Dec 30, 2013 | Ricoh Office Equipment & Supplies
Touch screen stopped responding
Pull the thermostat face off the wall. Wait a few minutes, & gently line up the pins and place back on. Let display pull up. If that doesn't work, your thermostat is probably under warranty...Replace.
Dec 13, 2013 | Honeywell TH9421C1004 VisionPRO IAQ Total...
I have an LG Optimus Regard Cricket phone and the touch screen suddenly stopped working. How do I fix it?
It's the charger screwing with the phone. Unplug it and I bet it works fine. Find a new charger.
Apr 11, 2013 | LG Optimus Black Smartphone
My Tissot T-Touch Altimeter does not function.
Mine did the same thing; I read in other blogs that this could happen due to humidity. I heat up my watch with my wife's blower for about 5 minutes on high. After 5 min I couldn't even touch it! The screen went blank. After a few minutes when it cooled down the screen came back up and to my amazement all the function came back. it is risky but So far... it works well.
Sep 26, 2012 | Tissot T-Touch T33759851
I just put a new screen and face plate on my samsung eternity and the screen is working but the touch part is not working
TOUCH SCREEN
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take care
Jun 24, 2010 | Samsung Eternity Cell Phone
Garmin Nuvi 650 Touch Screen trouble...
Yes, this is a common problem with a new style screen being used by SHARP. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Dec 07, 2009 | Garmin GPS
Failed to overwrite all data bizhub 250
the overwrite data function is supposed to take about 35 hours but the ones that i have done took about 20 hours and ounce the process is started you should never interupt it this function overwrites all the data on the hard drive HD-504 you could try formatting the hard drive first then overwrite again
1touch the utility/counter button then details
2 press stop,0,0,stop,01
3 enter 00000000 touch end
4 touch tech rep mode
5 touch function
6 touch hard disk format
7 touch yes
8 touch enter when the message the hard disk format completed.result:ng appears touch ok
9 touch hard disk format
10 touch yes
11 touch enter this starts the formatting procedure
12 when the message "the hard disk format completed. result:OK appears touch OK
13 press the reset key
14 touch exit on the tech rep screen
if the format fails replace the hard drive the format process takes about 30 minutes if you need further instructions on how to replace the hard drive post it
Dec 04, 2009 | Konica Minolta Office Equipment & Supplies
Doesn't have the directions to touch to begin
It sounds like a system crash. If you take the battery out and reinstall it a few minutes later this will reset the system and should solve the problem.
Aug 29, 2009 | Nintendo DS Lite Console
Touch screen is not working
not working touch screen
May 22, 2008 | i-mate JAM Pocket PC
Simrad Nss8 Navigation Pack Nss8 And 3g Radar Logo
87 people viewed this question
Top Simrad Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Simrad Cell Phone Expert? Answer questions, earn points and help others
