My washing machine start to fill then stops
After afew seconds of filling up it stops filling and nothing else
catriver
  • 878 Answers
SOURCE: Starts to fill and then stops, and the cycle continues on.
Jmars, under the consol there is two pressure switches. One controls the fill and the other is back-up incase the other fails. It sounds like your water pressure switch is tripping too soon. Try putting the washer into a self test mode by pressing in this order soak--soil level---soak--soil level. The machine should enter a test mode. Let it run it's test and see if you come up with any error codes. The pressure switch is the one on the left under the consol. It will be marked OPR, the part number is 8054766. The consol will lift up by using a putty knife under each end, pushin on the clips and lifting up. The back panel of the consol is removable. Catriver..post back
Posted on Apr 15, 2007
ginko
  • 19396 Answers
SOURCE: Washing machine fills in the water but does not start the wash cycle
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them.
    Repairclinic
    Partselect
    Don't forget to rate the solution.
    Many thanks.
    Posted on Sep 01, 2008
    • 641 Answers
    SOURCE: washing machine does not stop filling
    Does the machine start working normally after turning the wash cycle manually ?
    Posted on Jul 26, 2007
    SOURCE: frigidaire washing machine
    OK Check elec plug at motor . Mine was doing exac same thing . Take belt access panel off back and pull wire plug off motor and push back firmly on . This plug does not have a tab so vibrates off . Good luck .
    Posted on Mar 12, 2008
    • 958 Answers
    SOURCE: fill will not stop
    you may have a problem with your pressure switch. or sometimes they call it the water level switch.
    try to use it in the small level and see if it would stop filling around medium or large quantities of water.
    if it would stop filling , then replace the water level sensor.
    tnx 4 using fixya,
    drcool
    Posted on Oct 19, 2008
    Bosch washing machine starts filling with water, then does nothing, timer counts down but no movment
    have a technician check it out as it may be a board problem
    normally the fill level switch ,when the set water level is reached activates 2 things
    it stops the water in and at the same time moves the program on to start the wash cycle
    so it is either that switch or the program board
    Aug 13, 2015 | Bosch Washing Machines
    Washing machine stopping and starting when filling
    Sounds like maybe a bad water inlet valve? timer may have isses as well? have u tried running it in hot water only and cold water only cycle? see if one line is bad in ur inlet valve?
    Dec 16, 2014 | Washing Machines
    Washing machine doesnt work kelvinator smartdrive 085 0.5kg
    you have to check 1- water pressure switch (wps) , 2- the hose which fixed between wps and drum may disconnected or broken.
    Jun 12, 2017 | Kelvinator Washing Machines
    I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
    Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
    Jun 05, 2011 | Fisher and Paykel (IWL12)
    Press the start button,you hear a click,water runs for a second or so, water stops,that's it. Nothing else happens. Any suggestions. Thank you,S.Nielson
    If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
    Washing Machine Problems No Water
    Washing Machine Fix Washing Machine No Water
    heatman101
    Feb 19, 2011 | Frigidaire Washing Machines
    Bosch WFX Excel
    You have to replace the water inlet valve, the valve where water enters your machine.
    Jan 22, 2008 | Bosch Exxcel WFX 2467 Front Load Washer
    Washing Machines Logo
    89 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
