Question about Speck Pumps Pool & Spa
Remove impeller on proline speck E71 pool pump
dragonsthatk
  • 547 Answers
SOURCE: water leaking
some times you need two people one to hold the shaft the other to turn impeller on you need to put in a vice wraped in a towel and not to tight or break it off and replace it to
Posted on Feb 11, 2009
  • 990 Answers
SOURCE: Proline pool pump SD-1--1N11XB
This sounds like you have a bad seal in your pump and the loose piece is probally a piece on the shaft of the motor called a water slinger. This is just there in case your seal goes bad and leaks water it will spin with the motor and sling the leaking water out and away from the motor so a small leak does not ruin your motor. But you will still need to replace your seal and "O" ring.
Posted on Nov 04, 2009
  • 151 Answers
SOURCE: Proline Pump 8D-10-1n11CB. This is for a pool and is leaking from the shaft to the motor
The pump seal is bad on the unit. This requires disassemble of the pump unit. Remove power to the unit, dissasemble pump housing, remove the impeller from the shaft of the motor by removing the allen screw with an allen wrench. Seperate pump housing from motor remove the old seal replace seal. Lube motor shaft with a little clean oil or wd40 to facilitate easy install thru new seal,reassemble in reverse.
Posted on Jan 17, 2010
  • 106 Answers
SOURCE: How to remove impeller on pool pump to replace seal?
First, separate motor and pump. Remove back cover of motor. Drive shaft of motor either has a slot on end for a large screwdriver or a flat on it for a wrench.(usually 7/16) Hold shaft and unscrew impeller.
Posted on Feb 21, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: how do i remove the impeller from a dynamo pool
WITH LOTS OF LUCK . THEY SCREW OFF(OFF TO THE LEFT LOOKING AT THE IMPELLER SO COUNTER CLOCKWISE ) VICE GRIP OR SCREW DRIVER ON SHAFT TO HOLD IT, THING IS IF THE SHAFT IS RUSTY YOU HAVE A REAL GOOD CHANCE OF BREAKING IT AND IMPELLERS CAN BE HARD TO FIND.. THE SEAL SHOULD BE # 1000 FOR THAT PUMP... BEST OF LUCK.. J
Posted on May 25, 2010
Remove impeller from Speck pool pump
less hassle replace whole pump if impeller bad possible leak possibility
Mar 24, 2018 | Pool Pump Pool & Spa
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
Can't get impeller off proline pump
backwards thread screw then impeller turns off regular if you hold back of motor
Jun 16, 2012 | Hayward 1 12 Hp Super Swimming Pool Pump...
I have a speck 90 series pump with a broken impeller how do i remove the impeller off the shaft
You'll need to remove the back plate off the motor. Take a pair of channel locks and hold onto the bolt that goes through the motor. With your other hand, unscrew the impeller off the shaft.
Jun 14, 2011 | Speck Pumps Pool & Spa
I have a proline 1.5hp pump need to replace the shaft seal. I can't seem to get the plastic impeller off. We use a screwdriver to hold the shaft screw and try to turn the impeller counter clockwise...
Keep trying - It is stuck and will likely break but you have to remove it to change the seal. It is not uncommon to need to replace the impeller when the seal fails since the water gets behind the impeller shaft and rusts the metal causing the impeller to bind. If you still cannot get it free pull the motor thru-bolts and lock the rotor once removed from the motor in a vice. Use a large pair of channel locks to break the impeller free...replace it if necessary.
John
May 15, 2011 | Waterway 1.5hp Hi Flo Above Ground Pool...
MY E90 III SPECK POOL PUMP IS LEAKING BEHIND THE IMPELLER. WE JUST REPLACED THE HOUSING O RING. PLEASE ADVISE A FIX
Thank you for posting your question here on Fixya.com.
Replace the mechanical seal located behind the impeller along the motor shaft. Half is on the impeller and half is in the seal plate.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Apr 28, 2011 | Speck Pumps Pool & Spa
I can't remove the impeller on a 4hp Speck pump...I've worked on several 3/4 to 3 hp pool pumps but this one is a first...also, how is the seal plate attached? maybe I'll figure that out if I'm able to...
If the shaft seal has been leaking for some time the stem on the impeller has likely spit due to corrosion on the motor shaft. This makes it near impossible to un screw the impeller. You can try and isolate the armature of the motor and use a channel lock on the impeller. The only other way to get it off is by breaking it. Use a flat head screwdriver and a hammer and break apart the area around the center of the impeller until you can pry off the everything but the stem. You'll have to remove the ceramic part of the seal and pick out as much of the stem as you can. Then you can get the wetend off the motor and remove the metal cup seal.
Oct 16, 2010 | Waterway Executive Spa Pump 4hp Impeller...
Trying to replace a 4hp motor on a speck pump but can't remove the impeller, also, how is the seal plate attached? I've worked on several 3/4 to 3 hp pool pumps but this one is a first!
Id be happy to help if you could tell me what model speck pump you are working on.
There is just not enough information here.
Once you have the model, you can contact me @: adamh@newconceptchem.com for further assistance. I will give you the website for all the speck manuals incase you need it as well.
http://www.speck-pumps.com/html/usa/download_pool.html
thanks,
adam
if this post has helped you, please take the time to vote positively for me on this site.
Oct 16, 2010 | Speck Pumps Impeller 1hp Full1 12hp Up...
I have a proline 2hp above ground pump. A snake
The impeller is still jammed you need to get it cleaned out. You can try with a pair of needle knose pliers if that doesnt work your gona have to remove the pump bolts that hold the motore to the pump pod. Remove the bolts around the motor and seperate it this will give you better axcess to the impeller. Clean it out and try to move it if the impeller will not spin freely with the debris removed the motor has burned up .
Jun 24, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Jun 03, 2009 | Hayward 1.5 Hp Northstar High Performance...
Pool & Spa Logo
138 people viewed this question
Top Speck Pumps Pool & Spa Experts
k24674
Gil Shultz
Jay Finke
Jay Finke
Are you a Speck Pumps Pool and Spa Expert? Answer questions, earn points and help others
