Question about eMachines EL1352G-01w (884483537679) PC Desktop
Will a pci express 2.0 x16 card work in the EMachines EL1352G pc?
Will a pci express 2.0 x16 Graphics card work in the EMachines EL1352G pc? like the GeForce 8800 GT
  • eMachines Master
  • 32,281 Answers
Yes this eMachine has 2 PCI Express slots provided they are not occupied.
You can check the specs from this WEB site.
http://reviews.cnet.com/desktops/emachines-el1352g-01w-sempron/4507-3118_7-34169004.html
Posted on May 12, 2013
2 Suggested Answers
  • 11800 Answers
SOURCE: will pci express x16 graphics
Yes, it has the slot
http://i.walmart.com/i/rb/0088448353767.pdf
Posted on Apr 30, 2011
I have an Emachines T6532. The screen keeps "glitching" out on me. Any idea what might be causing this, or how to fix it??
http://i2.photobucket.com/albums/y47/beetle665/IMG_4829.jpg
DUDE! You can't post pictures like THAT!
Put sum clothes on that girl!
-> OH,....I'M JUST KIDDING! <-
1) Check the monitor cable.
If attached to the monitor, use the monitor, and cable on a WORKING computer. Same thing? Need a different monitor.
Use a KNOWN to be working monitor cable, if detachable; on your computer.
No? Monitor cable is good?
Go on.
2) We are dealing with a graphics problem.
Next in line is the graphics chipset.
The eMachines T6532 Desktop PC uses an MSI MS-7207 motherboard. Also known as the MSI K8NGM2-L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
Clicking on the photo shows a MUCH better view.
You have two white PCI slots at the Bottom, (PCI1 and PCI2), and a white longer PCI Express x16 slot above them.
[The shorter white slot above the long white PCI Express x16 slot, is a PCI Express x1 slot)
Integrated Graphics is also known as OnBoard Graphics.
A term that seldom seems used anymore. Too bad because it explains better.
ON the motherBOARD.
The graphics chipset is part of the motherboard chipset, which is Soldered TO the motherboard.
If the OnBoard Graphics of the motherboard is suspected to be bad, the tech will then use a graphics card; and bypass the Integrated/OnBoard graphics.
You have your choice of using one of the white PCI slots, if available; or the white PCI Express x16 slot.
Posting in case you have a graphics card sitting around.
Anti-Static Procedures are FOLLOWED, with your unplugged from power computer. The graphics card is physically installed.
Monitor attached to graphics card.
When you turn the computer on, the graphics won't be perfect. This is because THE graphics drivers for THAT graphics card; has not been installed yet.
Will sort of look 'Fred Flintstone-sih'
(Color quality will probably be set at 8 bit, instead of 16-bit; and Screen Resolution will be wrong)
That's OK. Right now you are just trying to get graphics.
I'll guide you through installing the drivers.
Post back in a Comment.
Regards,
joecoolvette
Mar 12, 2013 | eMachines Computers & Internet
Tip
Pci express 2.1 x16 graphics card slot into a pci express x16
hi can a pci express 2.1 x16 graphics card slot into a pci express x16 socket. And if yes will there be limitations.
Thanks
on Feb 17, 2010 | Computers & Internet
Can an EliteGroup 945GCT-M3 run a Geforce 440 GT graphics card?
AS it GEFORCE 440 requires (pci express) PCI-E 2.0 x 16 and your motherboard has 1 x PCI Express x16 slot, so you just need to check your motherboards manual if motherboards pci express is x16 2.0 if so, you can go for a upgrade and run. as I found itcan run nvidia geforce 8 or 9 on fixya.
Jun 24, 2012 | EliteGroup 945G-M3 (V1.0b) (945GM310B)...
WHAT GRAPHICS CARDS ARE COMPATIBLE WITH THE AVERATEC ALL-IN-ONEDESTOP PC'S?
1) It has an Intel G35 Express motherboard chipset,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
Under the - Chipset heading on the left, scroll down to - G35
Note that under the - Graphics heading, all the way to the right, that the Intel G35 Express chipset;
1) Will support a PCI-Express x16 expansion slot. This means a PCI-Express graphics card can be used, IF, there is a PCI-Express x16 slot on the motherboard.
[ PCI-Express is a technology. The current PCI-Express technology is PCI-Express 2.0
There is a PCI-Express x1 expansion slot, and a PCI-Express x16 expansion slot. (Not relating to Your computer at the moment)
The PCI-Express x1 slot is Not used for a graphics card.
The PCI-Express x16 slot IS,
http://en.wikipedia.org/wiki/PCI_Express ]
2) Has Intel GMA X3500 Integrated Graphics.
Meaning if there is NO graphics card installed right now, the computer is using Integrated Graphics, (Intel GMA X3500,
http://en.wikipedia.org/wiki/Intel_GMA#GMA_X3500
Now,...you are essentially working on a laptop with a touchscreen.
Once you remove the 10 screws from the Back Cover, and remove the cover, you are looking at the exposed circuitry of the computer.
You NEED to follow Anti-Static Precautions. This cannot be performed as on a regular desktop computer. Touching the metal frame (Of the unplugged from power computer) will do you No good.
You need to use an ESD wrist strap, and connect it's alligator clip to a good ground source. [ Electro Static Discharge]
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
With the Back Cover off the manufacturer knows all of the hardware components are exposed. This means the person working on the computer should be aware of Static issues, and use proper tools.
The average consumer is not aware of this. This is why only a ram memory upgrade is recommended by the manufacturer. (Before they went out of business)
This is why there are no service manuals released, also.
Only for the qualified authorized service techs.
So,...let's look together. See if there is a PCI-Express x16 slot, for one.
It can be any color. Will be longer than any other expansion slot on the motherboard. The PCI slots (Usually white) are not as long.
(164 contact pins. 82 on each side)
These examples of a PCI slot, and versions of a PCI-Express slot, are all the same color. (Yellow) Not usual for a desktop computer.
http://en.wikipedia.org/wiki/File:PCIExpress.jpg
The top example is an example of a PCI-Express x4 slot.
Hardly EVER used, I didn't mention it.
Has 64 contact pins. 32 on each side.
The next slot down is an example of a PCI-Express x16 slot.
164 contact pins. 82 on each side.
Next down is an example of a PCI-Express x1 slot.
36 contact pins. 18 on each side.
Next down is another example of a PCI-Express x16 slot.
Last example is an example of a PCI slot. TOTALLY different technology than PCI-Express.
124 contact pins. 62 on each side. (Unless PCI that is 64-bit)
IF, there is a PCI-Express x16 slot on the motherboard, you can use PCI-Express 1.1 or 2.0 graphics cards.
You need to be concerned with;
A) How much height is available for the graphics card, and how much length? Check the measurements inside the computer. Match to dimensions of the graphics cards you are looking at.
B) How much POWER does the graphics card require? It's in the Minimum Requirements stated for the graphics card.
How much power is available to the all-in-one computer?
This could be an instant stopping block.
AMD ATI Radeon graphics cards generally use less power, than a comparable Nvidia graphics card.
C) Worried about your computer per se uses DDR Sdram ram memory, and the graphics card uses GDDR3 ram memory? (Just an example. Not directly related to Your computer)
Don't be. Doesn't matter what graphics memory a graphics card uses.
The graphics card does Not rely on the system resources (Processor and Ram Memory) of the computer.
A graphics card has it's own Processor, (GPU. Graphics Processing Unit), and graphics ram memory.
For additional questions, or to have me explain in further detail, or to clarify, post in a Comment.
Regards,
joecoolvette
Feb 26, 2012 | HP Presario Computers & Internet
Hi, Is Asus ATI Radeon HD6450 Silence 1GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card capable for my Compaq HP Presario SR2020NX? -thanks a lot.
You mean will the Asus ATI Radeon HD6450 with 1GB of graphics memory, work in a Compaq Presario SR2020NX Desktop PC?
Yes.
The Compaq Presario SR2020NX Desktop PC has a PCI-Express x16 expansion slot.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757470&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3245048
{Motherboard illustration and photo are towards the bottom of the page}
Look at the specifications.
Scroll down to the heading - Expansion slots.
Three PCI. (PCI expansion slots)
One PCI Express x16 graphics.
NOTE*
Looking at the motherboard illustration, it is Wrong.
Shows - PCIEX1 (PCI E X1)
According to the specifications it is a PCIEX16 expansion slot. (PCI-E x16)
A PCI-Express x1 slot has 36 contact pins. 18 on each side.
In comparison a PCI slot {White} has 124 contact pins. 62 on each side.
Looking at the photo of the supposed PCI-E x1 slot they show, the black PCI-Ex1 slot is longer than the white PCI slots.
It is a PCI-Express x16 slot with 164 pins. 82 on each side.
The Asus ATI Radeon HD6450 uses a PCI-Express x16 expansion slot.
So you know the graphics card will fit. Low-profile to boot.
Power requirement:
The Compaq Presario SR2020NX desktop computer comes with a 300 Watt power supply.
(Although in actuality it's more like 70 percent of the maximum rated wattage. 210 Watts)
Enough power for the computer, and the graphics card.
ATI graphics cards do not use as much power as a comparable Nvidia graphics card.
Concerned that the Asus graphics card uses DDR3 graphics ram memory, and the Presario SR2020NX uses DDR2 Sdram ram memory?
Don't be. The graphics cards graphics memory runs independent of the computer's ram memory.
Information on PCI-Express,
http://en.wikipedia.org/wiki/PCI-Express
For additional questions please post in a Comment.
(Top right of your page, blue Comment)
Regards,
joecoolvette
Sep 15, 2011 | HP Compaq Presario SR2020NX PC Desktop
How do you replace the graphics card
you can purchase a pci express x16 video card. It installs in the pci express x 16 slot on the motherboard
Feb 05, 2011 | eMachines T3604 PC Desktop
We have an emachine w3400 and need and new video card but don't know if it is PCI standard or PCI express how do i find out?
The eMachines W3400 desktop computer has an MSI MS-7145 motherboard.
(MSI = Micro Star International, Inc)
This is the MSI MS-7145 motherboard,
http://www.e4allupgraders.info/dir1/motherboards/socket754/msi7145.shtml
The MSI MS-7145 motherboard, has one PCI Express x16 expansion slot, which is used for a graphics card.
Viewing the bottom left of the photo, you will see three white PCI slots.
Right above them is a longer white slot.
This is a PCI Express x16, expansion slot.
Scrolling down to the subheading - Expansion Slots,
You will see - One PCI Express 16x slot, listed.
Should you require information in installing a PCI Express graphics card, or information on which PCI Express graphics card may fit your needs, state so in a Comment.
(Believe upper right of your page)
Jun 16, 2010 | E-Machines eMachines Desktop PC
Upgrading graphics card
This is eMachines Support, and the specifications page for the eMachines C6535 desktop computer,
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=C%20Series&model=C6535
Scroll down the list until you come to the Video heading.
You'll see - PCI Express (PCI-E x16) slot available
This means you have a PCI Express x16 graphics slot on the motherboard, and it is open, and available.
You can use a PCI Express graphics card.
Two things I would like to note.
1) You need to check the System Requirements of the PCI Express graphics card you're going to buy, and see if your System Resources are able to support it.
The main thing you need to look for here, is what power is required for the graphics card.
Does your Power Supply have the necessary Wattage?
Not only does your Power Supply have to be able to deliver the necessary power for the computer system resources (Processor, Ram Memory, etc), it also has to be able to deliver enough power for THAT graphics card.
Since eMachines Support doesn't list the power of the Power Supply, I searched online for a Power Supply replacement for the C6535.
Seems the C6535 comes with a 300 Watt power supply.
Problem is, back in the day the C6535 was made, power supply manufacturers were 'Fudging' the true maximum Wattage, that their power supply's were truly able to deliver.
A more realistic figure, is 70 percent of the maximum rated Wattage stated.
This would be 210 Watts.
Therefore, you're going to need a better power supply, to support any of the really decent PCI Express graphics cards out there.
2) PCI Express came out in 2004.
PCI Express is a technology.
The PCI Express technology has gone through three major changes, or upgrades, since it came out.
A) PCI Express 1.0 version
B) PCI Express 1.1 version
C) PCI Express 2.0 version
PCI Express graphics cards now, are made in the PCI Express 2.0 version.
You can use a PCI Express 2.0 graphics card in a computer with PCI Express 1.1 technology.
PCI Express 2.0 is Backward Compatible with the PCI Express 1.1 technology.
Your computer uses the PCI Express 1.1 technology.
If you use a PCI Express 2.0 graphics card in a computer with PCI Express 1.1 technology, you won't get the full capability of the PCI Express 2.0 graphics card.
Will you notice?
NO
We haven't begun to fully use all the bandwidth of the PCI Express 1.1 technology yet, much less PCI Express 2.0
(PCI Express 3.0 technology is just around the corner, and getting ready to be used on newer graphic cards. Marketing strategy)
Have any further questions concerning this, please post in a Comment.
JCV
Information on PCI Express,
May 18, 2010 | E-Machines eMachines Desktop PC
Ok, i have two things to ask 1: Where is the video card on a emachines W3503? 2: Could a video card swap be done between a W3503 and a W3052? Thank you for viewing :)
1. The emachines W3503 has an integrated ATI Radeon™ X300 based graphics card. It has also a PCI Express (PCIe x16) slot available.
2. The emachines W3052 has a NVIDIA® GeForce®4™ MX graphics card. I'm not sure whether it is integrated or not, but I'm sure that if it is not, it will be an AGP graphics card. Since The emachines W3503 has a PCI Express (PCIe x16) slot available for installing a graphics card, the swapping of graphics cards between the 2 machines is not possible since they support different types of graphics cards.
Jul 11, 2009 | Computers & Internet
eMachines EL1352G-01w (884483537679) PC Desktop Logo
132 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
