Question about Pool & Spa
Speck e71 pool pump
Need to replace shaft seal on proline speck E71 pool pump. The problem I'm having is I cannot lock the shaft to remove the impeller, there is no place on shaft to put wrench to stop from spinning
john224
  • 1378 Answers
SOURCE: need to disassemble pentair dynamo pump to replace
Remove the cover from the back of the motor and lock the shaft from turning. Then spin off the impeller.
Posted on Jun 13, 2009
  • 106 Answers
SOURCE: How to remove impeller on pool pump to replace seal?
First, separate motor and pump. Remove back cover of motor. Drive shaft of motor either has a slot on end for a large screwdriver or a flat on it for a wrench.(usually 7/16) Hold shaft and unscrew impeller.
Posted on Feb 21, 2010
  • 35 Answers
SOURCE: I can't remove the impeller on a 4hp Speck
If the shaft seal has been leaking for some time the stem on the impeller has likely spit due to corrosion on the motor shaft. This makes it near impossible to un screw the impeller. You can try and isolate the armature of the motor and use a channel lock on the impeller. The only other way to get it off is by breaking it. Use a flat head screwdriver and a hammer and break apart the area around the center of the impeller until you can pry off the everything but the stem. You'll have to remove the ceramic part of the seal and pick out as much of the stem as you can. Then you can get the wetend off the motor and remove the metal cup seal.
Posted on Oct 17, 2010
adamh294
  • 310 Answers
SOURCE: trying to replace a 4hp motor on a speck pump but
Id be happy to help if you could tell me what model speck pump you are working on.
There is just not enough information here.
Once you have the model, you can contact me @: adamh@newconceptchem.com for further assistance. I will give you the website for all the speck manuals incase you need it as well.
http://www.speck-pumps.com/html/usa/download_pool.html
thanks,
adam
if this post has helped you, please take the time to vote positively for me on this site.
Posted on Oct 28, 2010
john224
  • 1378 Answers
SOURCE: MY E90 III SPECK POOL
Thank you for posting your question here on Fixya.com.
Replace the mechanical seal located behind the impeller along the motor shaft. Half is on the impeller and half is in the seal plate.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 29, 2011
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
My pool pump is making a screeching noise
Chances are you either have something stuck in the impeller (not likely), or your motor bearings are worn out. If the latter is true, you are about to lose the use of your motor.
Depending on your motor, you may be able to have the bearings replaced. Otherwise, you may be looking at a new motor.
When the bearings on mine were going out (mine are non-serviceable), I just continued to run the motor til it completely failed. Then I replaced it.
If you are the "do-it-yourself-er" type, it is much cheaper to order a new motor online and change it out yourself. Takes less than 30 minutes. Be sure to replace the shaft seal when you change out the motor. I replaced my Sta-Rite Duraglas (A.O.Smith) motor and seal for $150.
Hope this helps.
Jun 15, 2013 | Speck Pumps Pool & Spa
I have a speck 90 series pump with a broken impeller how do i remove the impeller off the shaft
You'll need to remove the back plate off the motor. Take a pair of channel locks and hold onto the bolt that goes through the motor. With your other hand, unscrew the impeller off the shaft.
Jun 14, 2011 | Speck Pumps Pool & Spa
MY E90 III SPECK POOL PUMP IS LEAKING BEHIND THE IMPELLER. WE JUST REPLACED THE HOUSING O RING. PLEASE ADVISE A FIX
John
Apr 28, 2011 | Speck Pumps Pool & Spa
Pump is 10 years in continuous operation. Stopped working. Can it be fixed or time for a new pump? 660/341-4801 prnhcc@aol.com
you should be able to replace the motor and shaft seal. You may need a new impeller/diffuser as well. Will still cost less than a new pump, unless you want to upgrade to a more energy efficient pump like the intelliflo.
Oct 26, 2010 | Speck Pumps Badu Ecom3 Variable Speed Pool...
I can't remove the impeller on a 4hp Speck pump...I've worked on several 3/4 to 3 hp pool pumps but this one is a first...also, how is the seal plate attached? maybe I'll figure that out if I'm able to...
Oct 16, 2010 | Waterway Executive Spa Pump 4hp Impeller...
Trying to replace a 4hp motor on a speck pump but can't remove the impeller, also, how is the seal plate attached? I've worked on several 3/4 to 3 hp pool pumps but this one is a first!
thanks,
adam
Oct 16, 2010 | Speck Pumps Impeller 1hp Full1 12hp Up...
Speck Pump Model E90 has very little pressure when vaccuming pool
while I can not personally vouch for this company, they do stock speck parts.
http://www.poolpartsonline.com/m-44-speck.aspx
You will most likely need part # 2920741271 - O-RING (strainer tank) It's the o-ring that sits underneath the strainer lid and is most likely cause of your weak vac pressure. Make sure when you replace it, you use a good silicone based lube. It will help the lid seal better and prevent the o-ring from deteriorating faster if you used a petrol based lubricant.
Jun 16, 2009 | Speck Pumps Impeller. 3/4 Hp, S.F. 1.0,...
Proline Pump 8D-10-1n11CB. This is for a pool and is leaking from the shaft to the motor
The pump seal is bad on the unit. This requires disassemble of the pump unit. Remove power to the unit, dissasemble pump housing, remove the impeller from the shaft of the motor by removing the allen screw with an allen wrench. Seperate pump housing from motor remove the old seal replace seal. Lube motor shaft with a little clean oil or wd40 to facilitate easy install thru new seal,reassemble in reverse.
Jun 03, 2009 | Hayward 1.5 Hp Northstar High Performance...
Pool & Spa Logo
48 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
