Question about Sharp Heating & Cooling
A/C runs fine for 7-8 minutes, then shuts off.
Something goes wrong by former post. correct one with this. Thanks. A/C runs fine for 7-8 minutes, then shuts off. Power on buttons can restart process. App. 7-8 min.. and shut down.Try to check error code can get 5 flash yellow led on.What goes wrong. Many Thanks.
  • chanpn May 11, 2013
    That's my sharp AU-F22SEY A/C .
    Sergeant:
    Champion:
  • Sharp Expert
  • 243 Answers
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
Posted on Mar 10, 2015
vanni7
  • 163 Answers
SOURCE: Furnace stopped working.
HI!!! Looks like your ignitor has stop working..change your glow ignitor and you should be fine..Good luck..
Posted on Jan 04, 2009
SOURCE: amcoraire / aos241hx / code p8 / unit shut down will not restart
for all error codes. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Posted on Jul 13, 2009
heatman101
  • 43501 Answers
SOURCE: my heat pump runs about 5 minutes, shuts down for
Did you check yourair filter at the indoor unit. If you are not getting enough air through the unit it will do that. The othere thing that it could be is not so easy for you to fix. Your unit may be just a bit low on refrigerant. After running for a while the pressure drops too low and the low pressure switch cuts out. after a few seconds the pressure rises againa and it restarts. If the filter does not solve this then you need to get the unit serviced by a professional that is certified to handle refrigerants and can charge it for you.
Posted on Nov 14, 2009
  • 141 Answers
SOURCE: Tadiran split a/c unit shuts down after 5 minutes.
try cleaning the outside condensor you may have to remove the top of the condensor coil and wash from inside out
Posted on Apr 05, 2010
  • 89 Answers
SOURCE: A error code E154 appears,
Hello there, I guess your Running capacitor is leaking already, when you start your aircon it will run after a minute the aircon will stop with errors, because the fan is stop running due to busted capacitor. thanks
Posted on Apr 26, 2011
Testimonial: "thanks I will do so"
Refrigeration problem. Must be a bad thermostat.
May 11, 2013 | Sharp AF-S120FX Air Conditioner
C300h mower starts fine, idles when cold, but when up to temperature will not idle when the throttle control is shut down. The throttle cable seems to be doing what it should, but is there anything to
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 19, 2012 | Cars & Trucks
I have a dell inspiron 530 with the quad core an everytime i start it up it goes into windows for about 10-15 mins an the monitor screen just goes blank an the keyboard lights go off an when i push the...
it sounds like your motherboard is shutting itself off to protect itself from overheating or some other system failure. you should verify all your fans are running at the correct speed. if it seems like everything is running fine, you can probably turn that off in bios. obviously if there is something wrong with the fans, then you need to replace them. Another options is maybe the processor is getting too hot which is why it's shutting down. open the case and remove the heat sync from the board so you can see the processor. clean the thermal paste off the processor and apply a new generous layer. put the heat sync back on and then try and restart. make sure before you do ANY of this you unplug the computer! good luck and let me know if it works!
Jan 27, 2012 | Dell Inspiron 530 Desktop Computer
Coleman Powermate PM0545007 generator. Unit started and ran. I turned on a window air unit and it worked ok then in about a minute the generator shut off. We are in a hurricane, so I'm trying to...
The generator has a low oil level sensor. Fill the oil all the way to the FULL mark and try it again.
IF you still have the problem after adding oil; repsond here and I can still help you. Just want to get this off as it has been 4 hours since your post.
Kelly
Aug 28, 2011 | Coleman Powermate Premium Plus 6250W...
System over heating
Simple reason is Replace your SMPS .
Apr 02, 2009 | ASUS K8N-DL Motherboard
Power/Monitor
looks like the power button needs to be replaced.. must be pushed it
Mar 28, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
1991 f150 when i first start it runs fine when i shut it off and
have the electronic module checked and maybe replaced to correct this problem
Nov 26, 2008 | 1989 Ford F 150
Medion AE19E1 (second hand)
sir,,i think theres something wrong with the power supply,,,kindly checkthe power supply of it,,,thanks and hope to help you thnkss??
Jan 28, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
Blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Sep 23, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Heating & Cooling Logo
248 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
