Question about Sony PS-LX250H Turntable
Sony PS-LX55II Tonearm Doesn't move when playing
The tonearm on my Sony PS-LX55II has stopped moving to track the record when playing. It travels well forwards and backwards when using the arm transport function, but not when playing the record. Any ideas?
  • EvilJekyll May 12, 2013
    This is a linear tracking turntable.
  • Sony Master
  • 16,162 Answers
Is there an antiskate or skew adjustment and also a way to set that counter weight? If any of those are wong then it wont work
Posted on May 12, 2013
2 Suggested Answers
SOURCE: My Sony PS-LX520 turntable skips with tone arm not moving
Yep - Just did the repair and it was as stated above. Had exactly the same problem you have and changing this tiny drive belt was the fix. I add more details and another source to find this belt:
I had the same problem and a review of forums and my experience with my own fix indicated that this is almost certainly your problem:
The roughly 2.6 inch (circumerence) drive belt (that connects a tiny motor to the worm screw that moves the tone-arm laterally when it gets the signal) likely needs replacement. Mine was intact but old and rigid enough to keep slipping or hang up the tiny motor. Unplug the unit - take out the 8-10 screws to take off the bottom - remove this little belt - scrub the pulleys with tripled-up sewing thread, and replace with new belt. This is a good source:
http://www.turntableneedles.com/Square-Belt-Small-26-Inch_p_227.html
$6.50 (paypal available) for 2 belts to reach their minimum, free shipping, arrived in 2 days.
You might also want to clean and lightly grease the rail that the tone arm rides on, but this is unlikely to fix the problem without a replacement belt.
Posted on Jan 08, 2011
Aiwa PX-E850
Hi, most likely the auto function needs resetting. With the power off turn the platter manually clockwise a dozen or so times. Power up and play. Cheers john.
Apr 08, 2013 | Audio Players & Recorders
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
Arm will not travel all the way across record before it lifts
Tonearm wiring is tangled under tonearm. Cheers john, Stylus City.
Sep 22, 2011 | Thorens TD295-MKIVB Turntable
How do you adjust the tone arm on a Denon DP-47F turntable? Thanks Cosmicharlie
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Apr 14, 2011 | Denon DP-47F Turntable
I have an older QL-45 turntable that needs tone arm adjustment- I don`t know how to set the weight so it doesn`t lower down to album so hard or heavily
I can't find the specific turntable. Who makes it?
This should work with some modifications for your specific controls...
Make a note of the tracking force setting.
Make sure the turntable is level.
Set the Stylus Pressure/Tracking setting to 0.
Dial in the prescribed tracking force on the Stylus Pressure/Tracking control. Play records.
Apr 11, 2011 | JVC Audio Players & Recorders
Tonearm skips imediately to center of album
Your stylus is damaged or worn. Or some one may have spun the balancing weight at the rear of the tonearm. Reset the weight so that it will drop when two postage stamps are lain upon the stylus end of the arm.
Sep 08, 2009 | Audio Players & Recorders
45 and 33 sound slow
Here's a procedure for setting the tonearm...
Unplug the power to the turntable and place it on a perfectly level surface.
Set the Tracking Force and AntiSkating to 0.
Manually rotate the platter Clockwise a few turns to disengage any cueing mechanisms.
If you don't have a Stylus Tracking Force Gauge. Dial in the prescribed tracking force and a corresponding anti-skate reading. Play records.
May 04, 2009 | Audio Players & Recorders
Turntable stylus not staying on record
Since there are no tonearm adjustments the only solution in the manual that comes close is to make sure the turntable is level. The other possibility is the no-brainer of checking the stylus cover is NOT rotated down, preventing the stylus from contacting the record.
A quick and dirty test of tonearm balance being too light would be to unplug the power and manually move the tonearm over the platter. Gently lower it to see if it floats in the air or lightly but firmly contacts the platter. That won't tell you if it is tracking properly but it might indicate or eliminate tracking force as the culprit.
Apr 26, 2009 | Audio Players & Recorders
Turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Jan 24, 2009 | Kenwood KD-291RC Turntable
Difficulty balancing the tone arm on kd-1033 turntable.
A new stylus should not change the tone arm balance setting if it is the correct stylus.
Does your arm have a sliding balance weight at the rear of the arm? If so you can slide this slightly towards the cartridge to regain the correct playing weight.
I would suggest you get a repair shop to do this for you, or you could finish up damaging your records.
Jan 01, 2009 | Kenwood KD-291RC Turntable
Sony PS-LX250H Turntable Logo
217 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
