Question about Combi Ovens
Siemens microwelle hft859
When the oven is set to a temperature the heating light does not come on and theoven will not heat
SOURCE: oven switching off
Hello, this is a commom problem. The cooling fan is not working correctly and you need a new controller. The part number is 8996619267611 and costs about £28.00.
Posted on May 30, 2007
SOURCE: aeg competence b 8139-4-m - oven not heating up
your heating element is probably bad. all u have to do is, make sure the oven is off, pull elem. away from it's holders on the top or bottom of the oven, then pull the elem. loose from it's sockets then, straight out of the oven. take to home depot, or lowe's, or an used appliance store. installation is reverseal.
from sid
Posted on Apr 20, 2008
  • 110 Answers
SOURCE: Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
Posted on May 30, 2008
SOURCE: GE double oven - bottem will not heat, top oven fine
I had a similar problem. Solved mine by resetting the manual reset thermal switch. The switch for the top oven is located behind the control panal which can be removed easily by taking out three screws then lifting up an leaning out. The switch has a red reset button, just push it in till it clicks.
For safety, SWITCH THE BREAKER OFF WHILE YOU DO THIS!!!
The lower oven switch is located behind the vent grill between the two ovens.
GE should be ashamed of hiding this feature-it isn't mentioned in the manual. I discovered it on a schematic hidden behind the control panal.
Good Luck, DVS1936
Posted on Nov 02, 2008
barkencoa
  • 3463 Answers
SOURCE: fagor oven will not regulate its temperature, once
From the symptoms you describe, I would say the oven thermostat is faulty, and in need of replacement.
This is the control you regulate the temoperature with.
Hope this helps.
Posted on Dec 15, 2009
Riello 40 gasG900 burner that will ignite but when oven reaches temperature it turns off completely. After temp drops by 4 degrees it turns back on and reheats back to temp then turns off.Why is this?
that would be normal. if it didnt shut off, it would go above the set temperature. the heat is either off or on. it cant me in the middle. it turns 'off' so that the temperature doesnt go too far above 250. when it senses the temperature falling too low below 250, it heats it up again.
Sep 03, 2017 | Ovens
Siemens oven not heating to high temperatures
possibly,but i would check both upper and lower elements are working first, lower element is hidden so test from the back with a multieter after removing oven fuse from the power box
Feb 03, 2018 | Siemens Ovens
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
Looking for a manual for Whirlpool BS0801/WH oven
I have a paper copy of the manual - if you need to know anything more than the information below post a more specific question.
The function symbols on Knob F, clockwise from the top, are as follows:
  • 0 = Off
  • Lamp symbol = Lamp Only, no fan, no heating.
  • Fan + Drip Symbol = Lamp + Fan, but no Heating - this is for defrosting.
  • Fan inside a Circle symbol = Lamp + Fan + Oven Heating - this is the normal cooking position. The temperature of the oven is set on the Temperature Knob.
  • Final position = Grill. The temperature of the Grill is set on the Grill knob.
The red indicator light only comes on when the Oven is heating (not the Grill), and goes off when the oven has reached it's set temperature.
The bulb is 25W 230V Type E-14 300 Degree C.
The oven draws a maximum of 2300W so requires a 10A supply.
Nov 29, 2010 | Ovens
I have a Thermador wall oven (POMW301/02) when bake is selected, heats up very slowly until the pre-heat light goes off. And then the oven light stays on but it doesn't hold the set temperature. While it...
Due to the nature of the self-cleaning cycle heating the oven to above normal temperatures what likely happened is that the temperature sensor went bad. The sensor is a small rod about 6 inches long and 1/4 inches wide that sits in the back of the oven. You can remove it from the back side of the oven which will need to be pulled from the wall. Replacing it should solve the problem.
Let me know how this works out for you.
Benjamin
Dec 28, 2009 | Ovens
Hbn7052gb/05
If you have a BOSCH electric Cooker or Fan Oven which isnot heating it could be one of the following problems.
1, If the fan motor in the back of the oven is goinground and the temperature light is on (normally little red light), but there isno heat then you will probably need a new oven element, these are generallyvery easy to fit and readily available from our website these can be testedwith a electric meter.
To gain access to the BOSCH element you will have to remove the back platefrom inside the oven. Once removed you will see the fan and element,if you look closely at the element you will probably see a small holeburnt in it where it has blown. Sometimes however there is no evidence of afault but the element is open circuitie: broken inside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your BOSCH fan oven is getting warm but takes avery long time to cook or is burning the food more on one side than the other,then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into theoven then you need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace your BOSCH oven thermostat
4, A quite commonand easily overlooked answer is if your BOSCH oven is not working at all ie: no heatand no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Jul 30, 2009 | Bosch HBL 5032 Electric Single Oven
Aeg competence b 8139-4-m - oven not heating up
from sid
Apr 20, 2008 | AEG B2100-4 Electric Single Oven
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Ovens Logo
63 people viewed this question
Top Combi Ovens Experts
ray gallant
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Combi Oven Expert? Answer questions, earn points and help others
