Tcl 21e11 the secondary supply have low voltage how can i fix it ? pls help me thanks
  • 1153 Answers
SOURCE: no power
look for high voltage cap like 200-250v 100uf that could be bad around flyback. Also look to see if reg. shorted, and horz. output bad.
Posted on Aug 22, 2007
  • 68 Answers
SOURCE: power supply (transformer)
You should have just one supply voltage on an AM type dishwasher. Find the data plate in one of these places - frame behind RH door, on the control box, under the front cover. The required voltage and phase (1 or 3) will be listed there.
What is the problem with the unit?
Posted on May 25, 2008
SOURCE: help for TCL Brand of tv
I WANT THE SERVICE MODE CODE FOR MODEL NO: DP21E101 TCL TV 21"
Posted on Oct 06, 2008
  • 208 Answers
SOURCE: how do you fix P0231 secondary fuel pump voltage
check your grounds clean and reattach it may have a faulty ground wire
Posted on Jun 22, 2009
  • 6 Answers
SOURCE: Tascam DM-24 power supply voltage (+5v) too low for stable...
power supply needs to be replaced
Posted on Aug 16, 2009
Tcl-21E11 standby mode only what can i do?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 13, 2015 | Televison & Video
Sylvania tv shrinks the sides
Check its secondary power supply voltage from SMPS power supply. Check the smoothing capacitor connected to secondary power supply voltage, replace it.
Jun 13, 2012 | Sylvania 6420FB 20" TV
Relay keeps click on and off
This is an indication of unregulated supply either on the ff:
1. B+ at the low voltage power supply
2. B+ at the system IC.
The above fault is due to leaky capacitor on the said section.
Also to consider the dry joints on that section, relay, and the system IC itself.
No quick fix. Needs a technician to do the job.
Thanks for using fixya.
Pls rate my help.
Jan 21, 2011 | Televison & Video
Accindentally pluged it to 220 volts instead of 110 volts
hello , i suggets you replace the power supply with a 110 v input boerd .
or do this if the damage is big replace the all sytem with a new one then get a voltage step down ie 220 to 110.
thank you
May 06, 2009 | Yamaha DVR-S120 DVD Player
Help for TCL Brand of tv
Jun 15, 2008 | LG 30FS1D TV
Codes for TCL TV on the Chunghop universal remote
most universal remote would work like this... press butons tv and power on at same time till red light of remote lights still. then press 110. then presto, it works... i hope i help in a way.
Jan 30, 2008 | Universal Remote Control Remote Control
Jvc tv
You need to check the horizontal output transistor first for a short,ift he transistor is good check the diodes and low value resistors of the secondary of the flyback(output trasformer),if all those are ok check the crt board,it has low value resistor for the g2 voltage,if ok you need to go back to power supply and check for a short from each one of the diodes to ground for a posiblwe short.Be careful when measuring voltages and use the correct ground.
Oct 01, 2006 | JVC AV-36F702 36" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
