Question about Cell Phones
Bumil safe The battery is empty, how can I change?
    Scholar:
    New Friend:
  • 103 Answers
The black plastic piece under the key pad is supposed to slide to the left and come off in your hand and the batteries should be right there: 4 AA batteries. When you take the key pad off and have a view of the batteries loom for two phillip head screws, remove the screws and the black piece and there should be an overide key whole. I hope this helps.
Posted on May 11, 2013
Empty battery
you can change the battery yourself. it's located on the left side on the upper print. if you change it be sure the machine is in the 'on'-position, if not you will lose all the programming-data. the battery is an 'cr-2032' lithium battery. it is very easy to do :-)
Feb 28, 2014 | Franke Evolution
Camera says battery empty
When you finished chargin the batteries, was it fully charged? Are you using the AC cable that was provided to you witht the device? if your camera showed that it was fully charge but discharge even though you dont use the camera,I would recommend you to replace the batteries on the device....
Jan 17, 2008 | Olympus FE-210 Digital Camera
My battery is every morning empty. Changed the dynamo, battery, steering contact. After removing the fuse of the radio / amplifier, battery keeps on level. Unplugging amplifier with fuse in results in low...
Have battery/alternator checked. Really clean connectors and battery posts even if they look ok. If battery is ok have it slowly recharged for 12-24 hrs. Alternators are not designed to recharged an empty battery but just to maintain the full charge. I large amp and sound system demands a big battery and heavy duty alternator.
Aug 04, 2013 | Cars & Trucks
Mls-18D says "chgbat w/power on". what does the
yes change battery it will solve. its because of empty or discharge battery.
Dec 20, 2010 | Avaya Corded Phone avaparp18d
Hi my 06 BMW 325i the battery went dead on my car...
When inside your car is it a the IBS (intelligent batery sensor) what this is the all recharging controlls. Battery must a registrated to car memory when new is where after change to empty battery! In diagnostical tools only! Car remember so how a old empty battery and recharging no good!
WARNING: Use you AGM specially batterie with fibre glass for your BMW attached only!
May 20, 2010 | 2006 BMW 3 Series
BATTERY SHOWS EMPTY WHEN TRY TO TAKE PICTURE
if its internal and have to charge it with a charger then you need to change the battery. i would recommend taking it to a camera shop and having it evaluated its well worth the evaluation trust me it might be something simple as just getting a new battery to a loose connection inside. Worse case you might have a bad indicator that needsto be fixed.
Sep 22, 2009 | Olympus Camedia D-540 Zoom Digital Camera
"Battery Empty" Message
extra dose 12V power pinch for 3 sec
Jun 18, 2009 | Olympus FE-20 Digital Camera
My motoflip is not charging
Your battery is dead. You need to change it. One more thing you can check before changing your battery put your battery in some other handset and try to charge it through that charger if it works then your chargers output voltage is wrong change it.
Jun 16, 2009 | Cell Phones
Hi, I have a Nikon D300. First problem - The battery started showing empty / full / then empty again. Bought a new battery, worked first time, then the same problem empty / full / empty. Change the...
A capaciter in your camera is not working properly and is discharging your battery even when the camera is turned off (this is a cheap problem to fix but must be sent back to NIkon for repair
Dec 06, 2008 | Cameras
Cell Phones Logo
235 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
