Question about Nokia E Cell Phones
Memory tab shows no memory card inserted - E Nokia Cell Phones
    Problem Solver:
  • 7 Answers
Restart the phone.....
Posted on May 11, 2013
mohammed387
  • 1952 Answers
SOURCE: my phone is not showing memory option and when i
remove the battery and memorycard then 5 min after put the battery and card then not worked cadr is damaged
Posted on Feb 25, 2009
mohammed387
  • 1952 Answers
SOURCE: Memory Card is not accessible in my N-72 mobile phone.
take the memory card out of the phone and then try all of the options to reset to factory defaults etc and if it is related to the memory card it will just give you an error message of some description to state that it cant erase the memory card because you do not have one
Posted on May 25, 2009
  • 39 Answers
SOURCE: while i insert the memory card its showing format the memorycard
whenever u want to format any thing ,use quick formating otherwise it will creat a problem ok ,try to format the memo card by connecting it with ur computer
Posted on Aug 27, 2009
SOURCE: Please insert memory card LG Cookie
JUST RESTORE THE SETTINGS THEN TURN THE CELLPHONE OFF THEN TURN IT ON
Posted on Sep 04, 2009
  • 312 Answers
SOURCE: On my Nokia N70, my phone memory card is not
first connect your memory card to a card reader and check wehther it is recognising...if no,sorry to tell you this, your memory card is currupted. formating is the only one way to get bak your memory card...hope this will helps you...thank you...
Posted on Oct 15, 2009
When i insert memory card in my dell vostro i can not edit any documents in memory card it is showing "write protected", how can i solve this problem
You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
Hope this helps.
Jan 21, 2013 | Dell Vostro Computers & Internet
I am thinking of adding memory to my Compaq Presario SR111ONX. I was looking for a schematic of the motherboard or a diagram showing the memory slots and how to add it.
Two long slots with tabs on each end... the hold the memory sticks vertical to the board.
Use your finger to gently move the tab away from the memory stick on both sides... after each tab has been moved away pull up firmly on the memory stick...note the position of the slot(s) on the side of the stick that goes into the slot. insert the replacement memory stick in the slot lining it up carefully and push down ... the tabs should go back into place on their own if the memory is seated properly.
Robert
Sep 19, 2008 | Compaq Computers & Internet
I inserted kinston 4gb card in my digital camera , while in the unlocked position of switch.But camera shows "memory card error" "card locked"
  • There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  • There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  • The mini sd card has some error: Go for a low level formatting.
  • The card has virus: Remove the virus. The link for the steps is present in the related link at the bottom of the article.
  • Read more: http://wiki.answers.com/Q/How_do_you_remove_write_protection_from_a_mini_SD_card#ixzz1Fvsnj1XE
    Mar 07, 2011 | Kingston 4GB Secure Digital High Capacity...
    I have a canon pc 1043 (Power Shot A 70) digi cam. i have a problem with this cam.It memory card is 128 mb. and when i switch on my cam it show memory card error.what can i do. I show it many local shop...
    Hello
    OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
    If the error is still displayed after you did the above, you might want to try the card in another camera.
    If the card works in another camera . the problem is with your card reader in your camera.
    If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
    1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
    2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
    Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
    It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
    If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
    Please feel free to contact me if you need further information
    Kind regards
    Andrea
    Aug 22, 2010 | Canon PowerShot A70 Digital Camera
    When i insert my memory card in the slot than the phone didnt show the memory it tells insert memory card..........
    The memory card is not good, please, try and change the memory card and insert it. Thanks
    May 20, 2010 | Lands Phones
    I have re-inserted my memory card of Nokia N73. but is showing "memory card not inserted"
    ur memory card may damaged or used password in memory card. pls check other phone to confrm
    Jan 11, 2010 | Nokia N73 Cellular Phone
    My camera will not put pictures onto the memory card, it just put them into the internal. how do i fix this problem
    The problem may be that the memory card is defective - or more likely that the card is "locked" or "protected" You can check for this by removing the memory card from the camera if it isn't already, and look along the left edge of the card. Find a small tab and slide it forward (to the unlock position) and carefully slip the card back into the camera and try again. If it still won't store images on the card, carefully remove the card to see if the tab has moved back to the locked position. It is possible that if the tab is moved when inserting the card, it could just as easily be moved back when removing, too.
    Either way, if the tab is moving (or suspected to be be moving) to the locked position during the insertion and / or withdrawal process, you could place a small amount of tape along the card edge - over the tab - and carefully insert the card again. You might have to remove some tape to allow the card to fit into to slot, depending how much room there is. If you never lock the card (I never do); you could put a very small drop of super glue on the tab to hold it in place. Wait for the glue to set completely before inserting into the camera and try again.
    If all else fails, you might try again with a different card.
    I hope this helps!
    Nov 10, 2009 | Fuji FinePix A820 Digital Camera
    Have fujifilm finepix f40fd. protected card shows. wont clear
    just take out the memory card . there will be a small button or a panel like thing on one of its side. just move that to the other side i.e opposite to the current position of the button. re-insert the memory card and check it out...
    May 29, 2009 | Fuji FinePix A303 Digital Camera
    May 25, 2009 | Nokia N70 Cellular Phone
    Memory card
    it only supports micro sd and not memory card or mmc
    Jul 18, 2008 | LG enV VX9900 Cellular Phone
    Cell Phones Logo
    15 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
