Electrolux EOC6630 Pyrolytic Electric Single Oven
Problem for Electrolux EOC6630 Pyrolytic Electric Single Oven
Oven will not heat
By Gerd1500 on Aug 12, 2007
After a electricity supply fault (low voltage) the internal light illuminates when I turn on the Oven or Grill but the element will not heat. The red indicator light for "heating mode" does not illuminate either. The fan will not run when "fan assisted heating" is selected. I should add that the clock was correctly re-set after the power failure. The unit has been disconnected, re-connected and clock re-set again but the problem persists. My fear is that the low voltage experienced for a period drew excessive current & damaged some of the electronic circuitry. Does anybody have any bright ideas or similar experiences?
Thanks in advance
Popular Solutions for Electrolux EOC6630 Pyrolytic
Questions and Unsolved Problems for Electrolux EOC6630 Pyrolytic
Do you recommend Electrolux EOC6630 Pyrolytic Electric Single Oven?
Answer
Answer
The oven works for 30 mintues and then both light flash and the heat goes of, plus the door does not... (More)
Answer
Have used pyrolytic previously and it worked. won't work this morning. Have lost instruction manual
Answer
have broken the inner glass on an electrolux oven. where do i get replacement glass from???
Answer
I turned on my oven one day and there was a spark from the fan area of the oven so turned it off, it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Ovens Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
