Question about Yahoo Computers & Internet
Restore password 36e09efd452 - Yahoo Computers & Internet
Reset to factory defaults
go to windows help & type restore to factory defaults; here is what I found.
Restore system files and settings
System Restore helps you restore your computer's system files to an earlier point in time. Typically, you want to restore your computer to a restore point that was created just before the date and time when you started noticing problems. The descriptions of the restore points that are created automatically correspond with the name of an event, such as Windows Update installing an update. System Restore returns your computer to the state that it was in before the restore point that you choose. To learn more about how System Restore works, see What is System Restore?
To restore system files and settings using a recommended restore point
  1. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. Click Recommended restore, and then click Next.
    If there isn't a recommended restore point, follow the steps below to choose a specific restore point.
  3. Review the restore point, and then click Finish.
To restore system files and settings using a specific restore point
  1. Do one of the following:
    • If there is a recommended restore point, click Choose a different restore point, and then click Next.
    • If there isn't a recommended restore point, click Next.
  2. Click the restore point that you want, and then click Next.
    To view the programs and drivers that will be affected (which could include programs that will be deleted), click Scan for affected programs.
  3. Review the resto
Mar 16, 2015 | Computers & Internet
Will not restore also saying password is wrong but it's not I'm completely locked out
If windows is saying your admin password is wrong, you can reset it by booting from Hirens Boot CD, booting into Mini XP and running NTPWedit to blank out any passwords.
Oct 16, 2012 | Computers & Internet
Sir, I have spice m5161 phone. I want factory restore password of spice m5161?
i want to spice m-5161 restore fectory password code
Apr 09, 2012 | Cell Phones
I want restore code of spice mobil m-4580
i have no remembered Restore Factory settings input password, i want Restore Factory settings input password
Mar 17, 2011 | Cell Phones
Do not know know password for wireless internet
Hi
Go here and download the manual http://static.highspeedbackbone.net/pdf/Netgear-WNR2000-manual.pdf
You will need to reset the router or change the password in the router 1. To change the password, goto Internet Explorer 2. In the address bar type 192.168.1.1 3. Press enter key 4. YOu should see a box with username and password fields. 5. username is admin 6.password is password 7. These are not the wireless passwords but the access password to get in the router. 8. Once in the router interface on Internet Explorer; goto the wireless sections and change the password there.
To reset the router WARNING: This will reset all the settings to what it was like when it came fresh out of the box. You may need to know some other settings. Restoring the Default Password and Configuration Settings You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 5). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Failing this, please refer to the manual, page 29 onwards
All the best now
Phil
Dec 17, 2010 | NetGear WNR2000 Wireless Router
Forgot password
just put useless sim where there is no any contact or sms. then take out ur memory card. then click on restore. your password will restore. Thanks
Tenzin
May 02, 2010 | AT&T Blackberry Curve 8300 Smartphone
Ran an image restore, but given me a login request for Administrator password. I set up a password the 2nd time I did the restore, but it's not recognizing my password when enter the 2nd time around which...
only administrator account has the priviledge to restore a system and it 's the password which you assigned for administrator that the restore wizard is asking.
As you can't remember or lost the password, you need to reset the password.
Download this softwware called "Elcomsoft System Recovery Professional"
It can easily reset you password or even let you know your forgotten password within a minute.
Here is the download link
http://www.megaupload.com/?d=HUVCQWFK
Just type the security alphabets and click download.
It's a rar file,you need winrar to extract it.
and the password for that file is  : www.fullandfree.info
Extract the ISO image and burn it a CD.
Boot the system using that CD (Set your BIOS to boot from CD-ROM).
you can easily recovered the password or reset it.
Note down the password and carry on with your restoration.
If you want help on how to do Image restore,then follow the link below
http://www.insidemylaptop.com/factory-image-restore-dell-laptop-with-windows-vista/
Rate this solution.
Jan 03, 2010 | Dell Latitude 110L Notebook
Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
Jan 30, 2009 | Microsoft MN-700 Wireless Router
Computers & Internet Logo
18 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
