Dell latitude d600 setup screen
I haven't been able to get it to turn on in weeks it told me something about a hard primary hard drive was missing I don't know what that is but it takes me to the screen which I can't get off of someone please help
    Master:
  • 563 Answers
May have lost the hard drive. I would try to format the drive which will erase everything and allow you to re install the operating system.
Posted on May 11, 2013
  • Computers & ... Master
  • 5,660 Answers
Harddrive: A mechanical, and now some of them are solid state; device that stores memory permanently.
(Ram Memory loses it\'s stored memory, every time the computer is turned off. It is Volatile Memory. Not so with a Hard Disk Drive.
Harddrive)
http://www.howstuffworks.com/hard-disk.htm
On the Harddrive is the Operating System. Yours has a version of the Windows operating system on it. Your laptop has ONE harddrive. It is the Primary Hard Disk Drive. (Or can be stated as the Primary Harddrive, or Primary HDD. HarDDrive)
If you had two it would have a Secondary Harddrive, also.
Going further........
What you are looking at is the BIOS Setup Utility screen.
You press the Power On button. This in turn presses against the Power On switch.
The AC adapter (Charger) is already providing power to the laptop.
[19.5 Volts DC to be exact,
http://www.ebay.com/itm/90W-AC-Adapter-Power-Supply-for-Dell-Latitude-D600-D610-D800-D810-D820-D830-/380625856133?pt=Laptop_Adapters_Chargers&hash=item589f11a685
No, not stating to buy it. Using it for reference ]
The AC adapter plugs into the DC Power Jack on the laptop.
(DC_IN)
The DC Power jack is connected to the DC - DC circuit on the laptop\'s motherboard.
Pressing the Power On switch momentarily (It\'s a Momentary Contact Switch), turns the Soft Power on circuit, on.
Power goes to the motherboard. The first chipset to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized. (Started)
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor (CPU) on; and hands the computer over to the Operating System.
(Again, a version of Windows. Original O/S?
Windows XP Home, or Pro)
Moving on........
You have a Harddrive problem.
The BIOS Setup screen is up.
Error message stated Primary Harddrive is missing.
This is a general look at the Harddrive,
http://www.ebay.com/itm/30GB-IDE-Laptop-Hard-Disk-Drive-DELL-C600-C500-C610-D400-D410-D600-D610-Latitude-/200920776865?pt=US_Internal_Hard_Disk_Drives&hash=item2ec7cfc0a1
What it means is the computer doesn\'t recognize the Harddrive.
A) Harddrive may be loose in it\'s connection.
Looking back at the image of the Harddrive, note the contact pins in the front view.
These contact pins slide into a rectangular shaped interface, in the laptop. (Actually, on the motherboard)
The Harddrive is encased in a sheet metal cover, type of affair; known as the Harddrive Caddy. The caddy is screwed onto the Harddrive.
The screw/s may have come loose. This would allow a bad connection, of Harddrive TO motherboard.
Hence the computer (BIOS) would not \'see\' the Harddrive.
B) Harddrive may be bad.
May have gone to the great harddrive cemetery in the sky.
(NO.......you gonna\' believe that last sentence? lol!)
Suggest;
1) Remove ALL power.
Remove the AC adapter (Charger), and Battery.
2) Suggest lay a soft static free cloth on a table, and lay the laptop upside down on it. Bottom side up, and Battery Compartment facing away from you.
[Caution!
Do not work on a bed, couch, or directly on a carpet floor!
These are HIGH areas of Static electricity.
Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Laptop OR Desktop ]
Laptop bottom side up, Battery Compartment facing away from you; the Harddrive is to you, and to the Left corner.
The plastic Harddrive Caddy\'s cover is what you see.
Part of the cover wraps up towards the Bottom of the laptop.
There is one single Philips head screw to remove, then the Harddrive Caddy can be slid out, along with the Harddrive.
Slide the Harddrive Caddy out, then slide slide it back in.
Now replace the screw.
Reinstall the Battery.
Reconnect the AC adapter (Charger), THEN plug AC adapter into power.
WAIT 20 seconds, then turn the laptop on.
Still no?
Suggest Harddrive is bad. Replace.
You will also need the Restore (Restoration/ Setup/ whatever) disk.
New Harddrive is installed, laptop is turned on, and disk put in Optical Drive. (CD/DVD drive)
When asked choose Full Install.
(Destructive Installation)
For additional questions please post in a Comment.
(Or click on Reply at end of solution)
Regards,
joecoolvette
Dell Support > Latitude D600 Notebook PC > Main Support page,
http://www.dell.com/support/troubleshooting/us/en/19/Product/latitude-d600
Click on -> Manuals & Documentation - tab.
Click on the blue -> Dell Latitude D600 Service Manual
Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the blue file name, it may take up to 30 seconds; before the first page comes up.
A PDF file will not show until fully downloaded.
There is a way to save a copy if you are interested.
This way you will have it whenever you want, in safekeeping; and will not have to download again.
Also after checking your copy (Suggest CD-R disk), then remove from the computer you downloaded it to, and save Harddrive space.
Clicking on the Zoom In icon ( + ) at the Top, increases the view size.
Clicking on the Zoom Out icon ( - ) decreases the view size.
Moving on..........
Increase the view size, click on the blue - Harddrive - in the list.
Laptop may also need to be cleaned on the inside.
I can guide you with this also.
No matter what though, buy, and wear an ESD wrist strap; if you go to clean the laptop.
(Electro Static Discharge)
Connect it\'s alligator clip to a good ground source.
Average cost is $3 to $6.
Here is an example,
http://www.radioshack.com/product/index.jsp?productId=2103245
Also suggest replacing the Thermal Paste on the Processor (CPU), and Thermal Pad on the graphics chipset.
  • 32,281 Answers
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
  • 1 more comment
  • mike fischer May 12, 2013
    Wow tried and now it wont turn on:\
  • Chris Hingee
    Chris Hingee May 12, 2013
    Try charging the battery overnight then boot up the laptop. Go into the BIOS and see if the hard disk is detected.
  • joecoolvette
    joecoolvette May 12, 2013
    I don't believe the Inspiron D600 is dependant on the Battery being in the DC - DC circuit......Laptop should run directly off the AC adapter......We'll see.........I believe there are other issues coming into play, also......
itszspot
  • 4 Answers
SOURCE: dell latitude d600 doesn't turn on
The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive.  Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
Posted on Aug 16, 2008
freetek
  • 5568 Answers
SOURCE: dell latitude d600-vga
The flickering may not be caused by a corrupt driver, it could be the impending failure of the fluorescent back light of the display or its high voltage supply.
Trying driver replacement though is the first thing to try.
If the original driver is corrupt, you can try the following;
- Right-click on My Computer
- Left-click on Properties
- Click on Hardware tab
- Click on Device Manager
- Locate and open Display Adaptors
- Locate the video listing for your
- Highlight and delete this
- Reboot the computer
If Windows does what it should (no guarantee on this!), it will 'find' a 'new device' and install the driver for it.
Posted on Aug 23, 2008
SOURCE: dell d600 network controller
my problem is' how can i get a dell latitude d600 network controller drive
Posted on Sep 12, 2008
SOURCE: dell latitude d600 blinking battery light
Sometimes a systemboard will cause this,
Posted on Mar 16, 2009
CLEONTI
  • 33 Answers
SOURCE: Dell Latitude D510 Screen Failed
The 14.1" inch screen is compatible with Latitude models D500, D505, D510, D600, D610 and Inspiron models 500m, 510m, 600m.
You may also need a screen inverter - in fact that is often the reason a screen is considered to be failing. The lcd inverter can be one of the most common items to become defective in a laptop computer. You may need a lcd inverter replacement if your screen is dim, dark, colored oddly, blinking, flickering or has dark stripes. Just something to keep in mind.
Hope this helps,
Chris
Posted on Mar 23, 2009
BSOD constantly comes up on Dell Latitude D600 with several different error messages. Is this common with this laptop?
On the dell screen press f12 run the diagnostic option if anything fails replace that part. If nothing fails try system restore or just reload the computer with the operating system disk
Feb 18, 2012 | Dell Latitude D600 Notebook
I have a Dell Latitude D600 that worked perfectly fine, until around a few months ago. It starts up normally and takes me to a DELL startup and then takes me to a black screen that says this: Windows...
Have you tried starting windows using the safe mode, and if it does start up in the safe mode, did you try to restore your system to a previous date that it was working properly. Sometimes when you have your kind of problem, even though several months have past, the calender for restore is lock too at the time your system went down. this gives you the opportunity to restore to a date close to when your system failed.
Before you try restore, make sure you do not have a virus that has corrupted you system, run a virus scan first. If you haven't done so I suggest downloading Malwarebytes anti-malware that is free online, it works very well, and Microsoft uses it for there systems.
I hope this is helpful, good luck, I hope you don't have to purchase the setup CD.
Jul 13, 2011 | Dell Latitude D600 Notebook
I have a Dell Latitude D600 laptop. Every time I turn it on, it says that the primary hard disk cannot be found. It is long past its warranty. Solutions?
There's no way you can fix a hard drive unless you're a professional who deals with at on the regular .... Other then that ...what you need is a new hard drive....
Apr 04, 2011 | Dell Latitude D600 Notebook
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
My dell latitude 600 decided to not recognize its hard drive, I got another one and it wont recognize it either. Any ideas
  1. Turn on the laptop
  2. press F12 repeatly until you get to a screen with option
  3. Navigate to Hard drive Diagnostics screen and select it
  4. If this comes back failed you indeed have a bad hard drive.
Oct 15, 2009 | Dell Latitude D600 Notebook
MY DELL LATITUDE D600 WONT LOAD WINDOWS AT ALL :( HELP
The computer is telling you is that the hard drive isn't being detected. This could be due to a poor connection from the drive to the motherboard, hard drive failure, or even something that's gone wrong on the motherboard.
In the BIOS setup (the F2 option), check to see if the drive is listed on the screen where you can check connected devices. If the hard drive doesn't show up, you'll probably want to replace it. The good news is that it's very simple to get to the drive, and you easily find replacements from several online vendors (Tiger Direct, Newegg, and so on) or possibly even at large retailers. Here is a link to online documentation at Dell for this model. You can view or download the service manual which shows just what you need to do. (The hard drive access page is here.)
If you replace the drive you'll have to reload all your software, but you've already decided that's not a bad thing.
Jun 16, 2009 | Dell Latitude D600 Notebook
I but a dell d600 latitud 60 hdd and 512mb,using it up to a month pluse it was tell me 0 primary hard drive not.
I assume you meant "primary hard disk drive 0 not found"? Have you pressed F12 during bootup and run the HD diagnostics? If you can't run the diags and it does not show up in the BIOS, then you have a bad hard drive.
I've seen this error many, many times on D600s.
Dec 20, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600
It is the Hard drive on the system. Hard Drive is failing. Another Error code for the Hard Drive is Error Code 7. Check BIOS setup if the system still detects the Hard Drive as well. You may want to consider changing the Hard Drive on the system.
Nov 09, 2008 | Dell Latitude D600 Notebook
Dell latitude d600 not booting/blank screen
well what you have on your computer is the computer does not find your hard drive where you have the operative system thats why is asking you to boot from cd because the computer wants to instal a operative system may be your hard drive is damage ok lets do a test turn on your computer by presing the power botton and then press the key to boot on bios page can be (delete ,F1, F10 ) any of those every time you try to do the boot up if does not go to bios you have repit the same operation so when you get bios system display on you computer look for the hard drive and the boot order if there is no hard drive so your hard drive is damege and you have to reolace for a good one and instal the operative system
Dec 29, 2007 | Dell Latitude D600 Notebook
Computers & Internet Logo
233 people viewed this question
David Payne
David Payne
