Siemens IQ700 (WM16S870DN) writing P5: variantcoding in the display. What does this mean?
4 Suggested Answers
adnanbhatti
  • 1188 Answers
SOURCE: Kipor 6700TA displaying charge fault (P5)
Check for loose or rusty battery cables. Unscrew the rear cover and locate the red battery wire. Disconnect it and, using a multi meter, check its resistance: it should have a very low value. Do the same with the other wire.
Start the generator and remove battery wires. If the voltage between them is zero then a fuse is blown.
Next open the front panel (where the display is), there you will find two blue wires with covered fuses, check and replace those fuses if found faulty.
If the problem is still there then it could be the charge regulator. Open the back cover by removing the six nuts. Near the edge you will find a component with silver cover resembling plates. There are three wires leading from it. Check resistance between these wires (one by one) and its body: it should be infinite, if not then replace it. remove the charge regulator and take it to a generator spare shop. The person there will further inspect it and will tell you if you need to replace it or repair it.
Hope this solves your problem.
Thank you for using fixya!
Posted on Aug 20, 2009
thepool
  • 78 Answers
SOURCE: Hayward pool heater - p5 code
The code is "PS" for Pressure Switch and means there is insufficient pressure to operate (low flow) or the switch itself is bad.
Posted on Apr 22, 2010
richroth
  • 9472 Answers
SOURCE: my siemens iq700 dryer wont start it has a symbol of a key?
Press and hold the "Finish in" button until the key symbol goes out.
Posted on Nov 05, 2012
Have any idea how to open the washing machine door iQ700 Siemens
Wait for cycle to fi?ish, plus another minute or so. Then activate door release. If this fails I suggest that you have the machine looked at by a technician.
Jul 16, 2015 | Siemens Washing Machines
My siemens washer front loader is displaying an E04 what does that mean
Drain is blocked - unplug the auxillary drain plug and check for clog.
Mar 21, 2014 | Siemens WXL142 Front Load Washer
My Siemens IQ700 displays error code E23. I switched off and on again and still the E23 is displaying. What should I do now? Thanks!
You basically have water in the sump at the bottom of the machine, and the sensor gives you E23 error to stop a 'flood'.
Unscrew the back cover and dry it with towels and then a hair dryer and you should be fine...
You must have added extra water and overfilled the tray, or there's a leak somewhere if the problem persists.
Oct 18, 2013 | Washing Machines
P5 variant coding speed 1
I had the same problem. The device (siemens iq700 washing machine) was transferred to siemens service center and the following day I was notified that they were unable to unblock the panel, so it had to be replaced (~200+ euros...) . So this is not a solution, it is bad news instead...
Aug 27, 2013 | Washing Machines
My siemens iq700 dryer wont start it has a symbol of a key?
Nov 05, 2012 | Dryers
F:80. My new siemens washing mashine IQ700 shows F:80 at the end of the program with the alarm. I can\t open the door normal way. What does it mean? We installed the mashine yesterday.
It means that the machine register what's in there as too heavy.
Can't understand for the life of me why this error code isn't explained in the user guide, but that's just how it is.
To fix this, turn off the machine, make sure that you get out as much water as possible and then open the door manually by pulling the red plastic band to the right of the pump (remove lid first ofc), or you need a screwdriver or something like that on some models depending on the age of your product.
I do know that this answer comes a little too late, but browsing for answers myself, I had to dip into the old noggin of myself as a former White Goods Consultant and I figured it all out.
For future reference I therefor post it here anyway ;o)
Jun 23, 2012 | Siemens Washing Machines
May 26, 2009 | Hayward 116k HeatPro Heat Pump HP3100
Washing Machines Logo
323 people viewed this question
Top Washing Machines Experts
