Question about Bulova Diamond 96R39 Watch for Women
Are bulova watches nickel free - Bulova Diamond 96R39 Watch for Women
Wich battery number may i use in this watch bulova 96t63 ??thanks
cant see that model watch on the Bulova web site user manuals
http://www.manualslib.com/brand/bulova/watch.html
if unsure if it needs a battery go to a jeweler or watch or battery seller
some model Bulova Watched instructions
IF YOUR NEW WATCH IS A MECHANICAL WATCH
(no battery)
Mechanical watches differ from Quartz watches in several
respects:
1. No battery changes are needed - they are powered by a main-
spring, which is wound either by wrist movement; or in some
models by daily winding of the setting crown.
2. Because it is a mechanical device, it's accuracy is subject to
the effects of gravity and temperature. You can expect, on the
average, a daily variance of up to 10 to 20 seconds for
mechanical watches.
3. Just like automobiles, these watches require routine mainte-
nance. Due to their mechanical complexity, mechanical
watches require cleaning and new lubrication every 3 to 5
years to run at optimum efficiency.
FOR THE AUTOMATIC SELF-WINDING
MECHANICAL WATCH
it must be wound at least six or seven times before you wear it.
After that, your daily activity should wind the watch sufficiently
to keep it running at night when it is not being worn. If your
normal daily activity is not sufficient, occasional supplementary
manual winding may be necessary. It is suggested that your
mechanical watch be cleaned and oiled periodically to insure
optimum performance. As a mechanical watch, quartz watch
accuracy cannot be expected. References to the power cell do
not apply to Automatic watches
May 02, 2016 | Bulova 96T53 Watch for Women
I NEED TO KNOW YEAR OF BULOVA LADIES WRIST WATCH ITS 10 KT AND I HAVE A SERIAL NUMBER z78782. it has bulova ms on back
A Bulova "M5" code would indicate that the watch was made in 1965. Vintage Bulova watches can be dated by this little alphanumeric code:
Lx = 195x Mx = 196x Nx = 197x Px = 198x Tx = 199x
Pre-1950 Bulova watches used a variety of symbols and numbers (e.g., 47 and 48 to designate 1947 and 1948) to show the model year of the watch. A chart of those symbols can be found here: http://www.manleyhorlogerie.com/Watch_History/bulova.htm#Bulova%20Date%20Codes
Jul 13, 2011 | Bulova Watches
I need the instruction manual for Bulova watch model 96R19...
Go to http://www.bulova.com/brands/bulova/product.aspx?origin=sku&sku=96R19&brand=bulova
and you will arrive at the page for your watch.
Click on "operating instructions" to download instructions.
Feb 10, 2011 | Bulova Watches
I NEED INSTRUCTIONS FOR MY Bulova 98B013 Marine Star watch for men where can I locate more instructions
You can get the .pdf here:
http://www.bulova.com/brands/bulova/product.aspx?origin=sku&sku=98B013&brand=bulova
Sep 25, 2010 | Bulova 98B013 Marine Star Watch for Men
I inherited the watch but not the manual. I don't know how to operate it.
Here is the Bulova website that has manuals for most of their watches.
You can print out the manual for free...
Did this help? Good Luck.
http://bulova.com/service/servicecenter.aspx
Jan 08, 2010 | Bulova Marine Star 96B98 Wrist Watch
I need to add links to my caravelle Bulova watch band G960472. Where can I buy the links? I need maybe 3 or4
You will likely need to go to a jeweler that carries Bulova or Citizen (now owned by the same company) as most after market parts are only available to retailers. Also, you may want to check for a used or broken one on EBAY or somewhere, then you can replace the links inexpensively.
Oct 17, 2009 | Bulova Crystal 96L000 Watch for Women
Zeon calculator watch, just replaced battery CR1620, cannot set date and time, lost instructions. Can you help please.
You can find all the bulova manuals on the website HERE>.
It's a free download for any of their manuals.... look for your model number.
print a copy for your future reference too..
K
Jun 25, 2009 | Bulova Watch
Bulova Diamond 96R39 Watch for Women Logo
239 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
