Question about Exercise & Fitness
I have a bladez x450 elliptical and I am trying to change belt how do I do it
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: bladez elliptical
see the steps and fix it. God bless you
Adjust the magnet with bolt attached there are loose, tight very well and ready the resistance is the main parts that need repair,
However if the resistance is faulty, you must test again the magnet from the refrigerator by attracting or repeled, if do not pass this test replace it buying small cheaping from home depot or similar.
GoD BLess you
  • 1 Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
  • 2 Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
  • Sponsored Links
  • 3 Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
  • 4 Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break.
  • 5 Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine.
  • Read more: How to Fix an Elliptical Machine ' eHow.com http://www.ehow.com/how_4681374_fix-elliptical-machine.html#ixzz2DLrv9YSH
  • Sponsored Links
    Posted on Nov 26, 2012
    Looking for owners manual for Bladez bf-6527hrp treadmill
    Try Googling (bladez)(bf-6527hrp)(manual) without parens.
    Jan 22, 2018 | Bladez Exercise & Fitness
    When plugging in my BLADEX x450, computer portion lights up, continually blinks and occassional beeps. Control buttons do not work. Unable to reset the computer
    1) adjust the REED switch, see the diagram , test for open or faulty, Clean it, and tight the connector very well.
    2) tight the ribbon cable inside from dispaly for keypads control,clean it
    3) replace the batteries by new one, REChargeable hybrids rayo-vac with the mark, polarity.
    God bless you
    Jan 07, 2013 | Bladez motion x450
    Belt tension won't release to zero
    please follow the next steps. God bless you
  • Dec 04, 2012 | Bladez X350P Elliptical
    CHARGE BATTERY ON PRECORE EFX546I
    The machine recharges the battery while in use. If your battery is dead, chances are you have a battery with some dead cells. You will need to locate your battery, usually mounted under the lower electronic board. You can try a 12 volt charger, or purchase a replacement battery. Precor Equipment Repair Parts Treadmill Belts Ramp Sleeves SPORTSMITH...
    Oct 14, 2012 | Precor EFX 546i Elliptical Version 4
    Too difficult to use even on easiest setting
    ask your persona trainer what he recommend you, in base to your need physical.
    God bles you
    Jul 16, 2012 | Bladez Fitness X350P Homecrosstrainer
    Precor efx 5.33 belt replacement
    This link will take you to the replacement belt. If you use your serial number, you will be able to access a service manual on our Website to assist with the belt change. Drive Belt Poly EFX PPP000000010217131 SPORTSMITH net
    Jul 01, 2012 | Precor EFX 546i Elliptical Version 4
    How do I change the clutch belt on my BladeZ Moby motorized foot scooter (25CC)? Do you have any instruciton manual type pictures as I can't download any from the manufacturer?
    there are 4 bolts that hold the engine in place on the left side of scooter when your looking straight towards the bars
    then there are 3 more bolts below those tak em all all be carefull not to loose the small spacers behind the large ons there hard to notice but they are there
    slip you belt over both pulleys and reasemble using the 2adjustment screws that attach to the big pulley on bottom until the belt is 110 & straight and has a little bit of play abotu half in or so should be fine you dont wat too much other wise it will break if you hit a bump or whatever an if its too loose wellit will slip as you might know
    Jul 15, 2009 | Bladez 320-5M/25 Clutch Belt for BladeZ...
    Exercise & Fitness Logo
    Top Exercise & Fitness Experts
    Howard
    Howard
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
