My magnavox flat screen turns off than back on after about 30 min of use , it than repeats it every 3-5 min
    Master:
  • 563 Answers
Hmmm, I would say something is over heating, could be a transformer, possibly a capacitor.
Posted on May 11, 2013
Kazong
  • 152 Answers
SOURCE: Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Posted on Dec 18, 2007
  • 86 Answers
SOURCE: picture will go out but audio stays on.if i turn
When the picture goes out, are you able to bring up the TV's onscreen menu?  If not, you have a problem with one of the video boards.  If the menu does come up, you may have a problem with the input/output board/cable you are using.  Does the picture dissapear when viewing another device as well?  If not, it could just be that one input or the cable connected into it.
Posted on Mar 24, 2009
MNfisherman
  • 11896 Answers
SOURCE: Tv went off and won' come back on.
Most likely you will have to replace the power supply. It is a very common problem especially in newer electronics. You can test it with voltmeter or multi-tester. They tend to get worn capacitor inside the power supply due to cheaper parts
Posted on Aug 24, 2009
budmrtn
  • 11361 Answers
SOURCE: my magnavox turns off and back on. its a lcd 32
You may have unstable power supply problem due to bad DC filter caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 30, 2010
  • 608 Answers
SOURCE: Magnavox 42" flat screen clicks
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Kaufman605
Posted on Dec 13, 2010
My magnavox flat screen will turn off than back on after about 30 min of use. Than it will repeat it about every 3-5 min
Return it for a refund or if it's too late for that try swapping it for another one.
May 11, 2013 | Televison & Video
Magnavox 19mf337b/27 will turn off and back on with loud noise through the speakers until it warms up. approx 30 to 40 min. What is the part causing this common problem?
Check the 2200uF capacitors for bulging. You can get the schematic here to really toybleshoot: http://www.electronica-pt.com/index.php/component/option,com_remository/Itemid,34/func,download/id,15048/chk,6022df47696641c1c064cb27f2bd7d11/no_html,1/
May 20, 2010 | SNK Magnavox 19MF338B/27 19 in. LCD TV
Philips magnavox smart series pr1920c601 turning off itself!
well let me ask ya something so it is coming back by its self then going back out may be solder connection okay call tv shop good luck shad
May 03, 2009 | Zenith B27A11Z 27" TV
Power Problem
Same problem as sweetpetny...blinking power button, won't on.
Jul 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Mute and C on the screen
The TV is in factory or demo mode - turn tv off and unplug it from wall outlet for 30 seconds - turn tv back on after 30 seconds and see if problem goes away. If not, press the (volume -) and (channel -) buttons repeatedly for about 10 seconds to see if "C" will go away. If this fails call 1-888-PHILIPS for further assistance (they do Magnavox also).
May 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Magnavox lcd tv
Dec 18, 2007 | Televison & Video
Power turning off and on
This may be the main digital module, I would suspect that this set is a couple years old and would be having issues with maybe the SSB module in that case, unplugging the set for 1 min might help, but I bet that it will require service.
Jul 08, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
