Question about Dell Computers & Internet
Dell ot7570 driver
Remove hard drive
Sata driver download
Check your motherboard manufacturer's website. Sata drivers are not hard drive specific, they have to do with your motherboard. If your computer was pre built and you are simply upgrading it, check your pc manufacturer's website (Dell, HP etc.)
Sep 03, 2014 | Dell 2TB 7200RPM SATA 3Gbps 3.5-inch...
Can you tell me step by step directions on how to reseat my hard drive on a dell inspiron 1545?
Turn off power, remove battery.
Flip it over and look to the bottom right. Remove the 4 screws with a small Phillips screw driver.
Pull out hard drive slot. Remove the screws attaching the slot, fix new hard drive in old hard drive's place.
Put screws back in, plug back in battery.
It really doesn't get any easier than this, kudos to Dell for making it easily serviceable.
if you are still unsure watch the youtube
http://www.youtube.com/watch?v=ZILBkW7Zmfo
hope this helps
Jul 24, 2012 | Dell 160 GB 7200 RPM SATA Internal for...
System says there is no hard drive. error code 0142 says hard drive error
This is what the manual says:
Replacing the Hard Drive caution.gif CAUTION: Before working inside your computer, read the safety information that shipped with your computer. For additional safety best practices information, see the Regulatory Compliance Homepage at www.dell.com/regulatory_compliance. notice.gif NOTICE: Hard drives are extremely fragile. Exercise care when handling the hard drive. notice.gif NOTICE: Use firm and even pressure to slide the hard drive into place. Excessive force may result in damage to the connector. This procedure assumes that you have completed the removal procedure Removing the Hard Drive.
  1. Slide the hard drive into the hard drive connector until the drive is fully seated.
  2. Replace the hard drive cover aligning the notches.
  3. Replace the two M2.5 x 8-mm screws to secure the cover.
  4. Install the operating system for your computer, as needed. For information on reinstalling the operating system, see the Setup and Quick Reference Guide for your computer on support.dell.com.
  5. Install the drivers and utilities for your computer, as needed. For information on reinstalling drivers and utilities, see the Setup and Quick Reference Guide for your computer on support.dell.com.
I would say that was a bit harsh and this is what I would do.
Insert your System disk and install a fresh system. During the installation, Windows should be clever enough to detect and format the drive.
If you remove the drive and with a caddy you could try to repair the system with another pc but you may get problems.
Hope this helps.
Nov 04, 2010 | Dell Vostro 2510 Laptop
Where can I buy a refurbished Dell OT7570 with windows XP?
Check out the US DELL refurbished outlet
Here is the canadian one that sells open box and off lease ones just in case your in canada : Canadian DELL
Oct 29, 2010 | Dell Computers & Internet
I tried to format my Dell laptop but it display internal hard drive not found
Go to the BIOS configuration and see it the BIOS detects the hard drive. If it doesn,t detect the hard drive then the hard drive coulf be faulty.
Another way to check the hard drive. Remove the hard drive and connect it to an USB hard drive adapter and then connect this to a computer's USB port. If this computer does not detect it as and external storage device, then the hard drive is faulty.
To get your laptop operational again, insertl a new hard drive and install Windows on this hard drive, together with the laptop's device drivers and your programs.
Sep 21, 2010 | Dell Inspiron 1525 Notebook
Harddisk not working
First - check the BIOS settings to see if the hard disk is detected.
If not re-seat the data and power cables on the hard drive and on the motherboard. Reboot the computer to see if it boots up. If not is the hard disk LED flashing as the computer boots up?
If not then to further check the hard disk, remove the hard disk and attach it to an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see this as an external hard drive nor open the various folders and files then the hard disk is definitely faulty.
THE FIX.
Install a new hard drive in your Dell and install Windows on this hard drive, together with the Dell's device drivers and your programs.
You can download the Dell's device drivers from a another computer that has Internet access.
These drivers are available from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
May 28, 2010 | Dell /Intel 1.3Gh 3M Itanium2 400Mhz P3250...
New, second modem won't recognize modem
You probably need to install network adapter driver on your new hard drive.
Go to my computer properties, select "Device Manager" and see if there is a network adapter installed and working.
Dec 27, 2009 | Dell (S423) for Dimension 8100 (3F546)...
Dell optiplex 170L hard drive recognition
Ms Driver gets flaky sometimes. Get New driver from Dell Downloads.
Contact Dell Support for more INFO
Oct 08, 2008 | Dell OptiPlex 170L PC Desktop
Computers & Internet Logo
21 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
