Question about Camping, Backpacking & Hiking
COLEMAN MODEL PML8000Y SPOTLIGHT
AC ADAPTOR OUTPUT VOLTAGE
SOURCE: Lost ac power supply adaptor for Mli 190 speakers
http://an-labs.com/multi/sw190.html 12vac
Posted on Jan 22, 2007
plkruger
  • 32 Answers
SOURCE: coleman 5000 generater-no AC output
Pull off the cover at the end of the generator and locate a 2 lead capacitor, it should read 130UF 200V and replace it, they often go bad and you will not have any output if they are. colman has them for 20.00 shipped. 1-800-445-1805
Posted on Feb 04, 2009
  • 3 Answers
Try replacing the capacitor. You can buy it from http://www.jackssmallengines.com/do_it_home.html. When you pull off the power end of the generator look at the diodes also. If they look toasted replace them as well
Posted on Feb 07, 2009
protek480
  • 1714 Answers
SOURCE: no output voltage at all
The generator needs to be 'flashed' to bring back the excitation for output. Is this something you can do? Let me know and I can help you...
Posted on Sep 11, 2009
SOURCE: I lost my AC adaptor for my DVD Xpress - USBAV -
I stopped wandering and I bought a brand new DVD Xpress DX2
Posted on Jan 03, 2010
My remote speaker system works with the batteries but not with the AC adaptor plugged in to the speaker.
I would suggest to check AC outlet first where adaptor is pluged in,if Ok measure output voltage from adaptor to see if there is any (using any voltage multimeter with AC/DC)
Check label on adaptor shold be writen AC or DC output ,and value 3V,6,9,12,24,48 etc...
If adaptor is ok then problem is power jack mounted in to the speaker (cold solder joints' or damage)
Aug 23, 2011 | Audio Players & Recorders
DVE AC ADAPTOR, model :NO.: DV-91A, INPUT :
You dont need an exact replacement for your router to work, just check on radio shack for generic adaptors with the same specifications, they would work fine, make sure voltage is the same as well as wattage...thats all that matters, and obviously input being 120vac, Hope this helps..
Oct 25, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
Dear Sir/ Madam, I have TWO Western Digital USB
first of all , you are looking at the wrong voltages. The important voltage is the DC OUTPUT, which is the voltage the external harddrives use AND the polarity of the plug attached to the harddrive end of the cable.
if both the harddrives have say 12v dc output and both have the insignia of the center conductor being + (posative) then you can interchange them. and you CAN run a 9volt unit with 12volt DC power, but not the other way around.
Look at your power adaptors again for the OUTPUT and polarity.
should be a half-circle with lines depicting the polarity(+,-) of the center and sheild connections to the hard drives printed on both the harddrives and the power adaptors . This can also be tested with a dc volt meter while the adaptors are plugged into the wall.
DO NOT try to test the AC end while plugged in!!
Regards
Aug 09, 2010 | Western Digital 250GB MyBook External USB...
Coleman Powermate Powerbase 4000 -no AC Need Field test procedur
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
Apr 16, 2010 | Coleman Powermate Premium Plus 6250W...
I have a coleman 1850 sport madel.the unit runs
The lack of DC output COULD possibly prevent the stopping. There are likely fuse(s) between the low voltage winding and a rectifier to generate the DC. SOMETIMES these are even inside the generator cover.
Mar 21, 2010 | Coleman Sport 1850 Generator
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
at most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
Nov 13, 2009 | GE Ultrasonic 2.1 Speaker
HP scanjet 3500c doesn't turns on
Look at your AC Adaptor for your Scanjet and see what the output voltage is. Then try to find another AC adaptor that will fit your scanjet and has the same output voltage as your original. It could be that your adaptor is bad.
Feb 08, 2009 | HP ScanJet 3500C Flatbed Scanner
Lightning strike ac adaptor is fried
Your phone did expirence a surge that probably blew the ac adaptor which happens most of the time, u can buy one of those universal adaptors and look on the back of the old adaptor for the output voltage it will usually read between 3 and 8 volts DC.Set the universal adAptor voltage to the setting right below the voltage output on the back of the ac adaptor.
Aug 04, 2008 | Uniden Cordless phone EXS9950
HP printer AC power adaptor 0950-4399
I want to purchace new HP printer AC power adaptor 0950-4399 from mumbai where shall i contact
Mar 26, 2008 | Office Equipment & Supplies
Camping, Backpacking & Hiking Logo
115 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
weirdtop
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
