Remote control codes
Want to control TV power and volume from Tivo's remote control. Does Bauhn use the same codes as another manufacturer?
    Top Expert:
  • Televison & ... Master
  • 74,630 Answers
If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. You can also make a search by type in the brand name of your device into the search box; can be located at the top right of the display window. More than Nine Lakh viewers cannot be wrong.
http://electrohelponline.blogspot.com/
Posted on May 11, 2013
4 Suggested Answers
SOURCE: Programming my TiVo remote to control my Proview TV
  1. Cover the end of the TiVo remote control with your hand.
  2. Hold down the TiVo and TV POWER buttons simultaneously until the red light on the remote control remains on.
  3. Remove your hand from the end of the TiVo remote control.
  4. Enter code 0999.
After you enter the code, the red light will flash three times and then remain on.
  1. Press CHANNEL UP once every two seconds. This will test hundreds of codes, one by one.
IMPORTANT: Do not go any faster than this or you may skip over a code that works.
  1. If you press CHANNEL UP and your TV turns off, press ENTER to select the code. Press the TV POWER button to test the code. If your TV turns on, you have successfully programmed the remote
Posted on Jun 16, 2009
  • 23 Answers
SOURCE: Remote to my tivo won't work my on/off and volume on Akai TV
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Posted on Feb 18, 2010
gopakumarg43
  • 74630 Answers
SOURCE: need 4 digit remote code for LG LV5500 led Tv to
Hello
Just do a code search process, and see whether it can help you. As there is no codes listed for LG with Tivo remote, this is the only thing to get it. If this does not help you to get any code, there is no other way than buying an other universal remote, which has codes listed for LG.
Code search process
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Posted on Oct 08, 2011
Need to replace remote GL21A-C2 for Bauhn tv
Just visit the site pointed out here, and check. There are setup code list to some popular models remote controls. Check them, and find out, which remote has setup codes with your brand TV, and select that one. In most cases, Philips universal remote will have it.
Feb 28, 2013 | Televison & Video
How to set up bauhn universal remote
how to set up bauhn universal remote control for tv vivo lcd
Jan 19, 2013 | Tivo DirectTV Remote Remote Control
Suddenlink tivo apex tv code
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1)
From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 23, 2012 | Televison & Video
I need a remote code for an Olevia 232 s13 that will work for TIVO Premier Remote Control.
Hi
Please check this code 11610, if it works.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 11, 2011 | Televison & Video
  4. Enter code 0999.
Jun 11, 2009 | Tivo Series 2 Remote Control
I need to program the remote from my TivoHD to operate power and volume on my Samsung LN52A850
You should be able to go to the tivo menu and push Messages and Settings, followed by Settings, and finally Remote Control. Then follow the directions on the screen. You normally would program volume and mute, power, and tv input. It will walk you through the manufacturers and give you the codes to try.
If the codes do not work, it is possible that Tivo does not have the codes for the TV yet, but I would first make sure that you have the most recent version of the Tivo operating system (force a network connection a few times).
Nov 25, 2008 | Samsung PCK5315RX TV
Sylvania 6727fde universal remote code
Hello goyitos,
I would contact the TV manufacture and then see if they can send you a replacement remote. They will usually do this for the cost of the remote with shipping and handling.
I hope this helps
Thank you,
Shuttle83
Mar 23, 2008 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Electro Med Services...
