Question about Garden
My encore pro48 belt drive walk behind will not pull to the right
  • 7 Answers
SOURCE: I have a walk behind mower. The drive belt broke
you must have a belt tensioner somewhere. Have a look near your belt pully or a idler pully that has an adjustment screw where you can tighten your belt to give grip. It appears the weight of the mower is causing the belt to slip hence it no moving because your belt /belts are slipping
Posted on Jul 03, 2009
  • 17 Answers
SOURCE: Craftsman Walk behind lawnmower
usually theres just a few bolts to take off on the top, and the whole rip cord assembly will pull right out, allowing you to install the new one.
Posted on Jul 09, 2009
  • 28 Answers
SOURCE: gaining access to change a drive belt on mower
the belt cover should have screws with the heads on top of the deck, then there is a guide which keeps the belt in the engine pulley with 2 or 3 bolts you might be able ot get it on the gearbox with just those off and a bit of prying etc.
Posted on Oct 03, 2009
  • 3 Answers
SOURCE: I have an old Toro proline 52 inch commercial walk
with ur dikki pemole
Posted on Jul 02, 2010
  • 1509 Answers
SOURCE: Yardman self propelled walk behind Right wheel
there's a shaft going from one wheel to the other a gear on the end of the shaft heald from turning with a key ( can be broken) then the gear is running on a gear made on the inside of the wheel, ( gear can be striped or wheel can be striped or the wheel can be coming off and the gear does'nt tou=ch the wheel. remove the wheel that doesn't pull and you can see the problem. Go on the internet to MTD and with your model number and serial number you can see the parts diagram for your mower and pick out the parts that you need.
Posted on Sep 30, 2010
How to tighten drive belt on 26 inch walk behind mower or replace drive belt
Here is a video about how to replace the drive belt on a walk behind mower, hope it helps you out!
How to Replace Lawn Mowers Drive Belt
Jul 28, 2015 | Garden
Why won't my Lawnboy model #10604 self-propell go forward?
Its possible that the drive belt is old and stretched. You may need to replace the belt.
May 23, 2014 | Garden
Encore Premier 36 walk behind- safety switch connection problem
you can adjust the handle not the switch try and swapping the switch with the other side and see if the problem follows the switch
May 12, 2012 | Garden
HOW DO YOU PUT A DRIVE BELT ON A TROY BILT 33"
I think you should go to your local dealer. They will be able to pull up the info you need and they may even print up for you a picture of the way the belt is installed. GOOD LUCK.
Jul 03, 2011 | Troy Garden
Metro walk behind bogging down
the springs that control carby is there leaves or grass stopping it from moving ,some lawn mowers have bad desinge for air flow off ****
Jun 02, 2010 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
C2200 belt is slipping how to straighten and tighen belt
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First, ensure that it is the walking belt that is loose. There is a belt hidden under the hood that connects the front roller to the motor (motor/drive belt). Start the treadmill at 3 or so and carefully apply pressure to the walking belt until it slips/stops. Watch the front roller. If it continues to spin when the walking belt stops, it’s the walking belt. It the front roller stops with the walking belt, the motor belt is loose and needs adjusted or replaced.
To adjust the walking belt, locate 2 hex head bolts, one on either side of the deck on the very back of the machine. These bolts will be recessed inside the plastic covers. Your treadmill came with a tool for this, but if you can’t find it, a standard (not metric) allen wrench kit will work. It’s helpful to have a wrench in each bolt so that you can adjust them at the same time, but one will work.
The allen bolts thread directly through each side of the rear roller. As you tighten the bolts, it pulls the rear roller away from the front roller, tightening the walking belt. This also centers it; if you tighten one bolt, it pushes the belt towards the center of the walking deck away from the bolt you’re tightening. So if the belt is too far to the right, tighten the right bolt and it will move towards the center.
Place your wrenches in the roller bolts and turn the machine on to 3-4 miles an hour. Keep your fingers clear of the belt, it will eat them. This method is quick, because you can see the belt move as you tighten one side or the other. It takes a few seconds, but if you tighten the right bolt for instance, you will see the belt move to the left. If the belt is loose but centered, tighten each bolt ½ turn and then get on the machine and see if it slips. The user manual will tell you to pull it up a couple of inches to test the tightness, which is a relative method and doesn’t necessarily work. My wife can pull on the belt and get 2 inches, and I can probably get 3 or even 4 if I’m showing off. The best way to test it is to gradually tighten it until you can run on it without it slipping.
You should lube the belt a couple of times a year. You can get them from iconfitness.com
Good Luck!
Mar 11, 2010 | Nordic Track /proform Treadmill...
Have a 4.9 treadmill and cant get it to adjust if i loosen bolts in back it slips if i tighten bolts on motor it quits pulling when i put weight on it can you help
Ok I really need more info but let's take a stab at it. The bolts in the back of the rear roller adjust the belt right and left. It also tightens and loosens. Ok there is also a drive belt from the motor that needs to be tight. Generally you should be able to twist the drive belt about 45 degrees. If it's more than that it probably needs to be tightened. If this is loose it will affect the walking belt the same as the walking belt being loose. So when your walking belt is slipping, make sure you tightened the right belt. Tightening the wrong belt can lead to other problems. Tightening the walk belt with the rear roller- turn both bolts clockwise equally to tighten. Remember the walking belt will travel to side with least tension. So to center belt, adj left or right side to fine tune. If belts are adjusted properly and machine stops when you walk on it, you have other issues. Could be the deck ( the board under the belt) and belt or the motor.
Nov 17, 2009 | Proform 6.5q Treadmill Walking Belt
Poulan weedeater lawn mower belt slip can it be tightend.
Is this the drive belt you are talking about? If so, it would be safe to say no, it would have to be replaced...normally, walk-behind mowers do not have a tension adjustment feature.
Sep 08, 2009 | Garden
Toro 20073 self propeled, walk behind mower-how to replace belt ?
Wait until the mower cools off
1. Remove the drive belt cover from the top of the mower
2. Tip the mower up, being careful to not go too far or the oil and fuels may spill out
3. Remove the mower blade - as I recall the bolt is 5/8" (could be 9/16") You will have to hold the blade from turning (if you have impact tools, this will be much easier)
4. Remove the blade
5. Pull the pulley out or off and remove the belt - be careful to not lose the crankshaft "woodruff" key - it's the little piece of half/moon shaped metal that keeps the pulley from spinning on the crankshaft.
6. Reverse the steps to reinstall
You MUST make sure the blade is tight when you reinstall it. Also, the blade usually fits over a couple of pins - make sure they are lined up properly and the blade is installed right-side up.
Mar 16, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
137 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
