Royal 480 My machine will not stop beeping
  • 27,725 Answers
Millions of people rely on computers to help them be productive, organized and even entertained. Over time and with extended use, these machines will eventually fail.
Some issues are easy to troubleshoot while others can be more perplexing.
When a hardware component fails, often you won't be able to boot the computer.
In such situations, the BIOS chip on the motherboard may emit "beep codes" to alert you of a problem help you pinpoint the cause.
If your computer tries to boot but instead starts beeping, listen carefully the computer is telling you what you need to know to fix it.
Power on your malfunctioning computer.
It will attempt to boot.
If it recognizes a failed hardware component during POST (the power-on self-test), it will emit a beep to alert you of the issue.
Listen carefully to the beeps and write down exactly what you hear.
Count the number of beeps as well as the length of each beep.
Keep in mind that a "beep" and a longer "beeeeep" are probably two different signals and should be noted accordingly.
Shut down the computer when the beeping stops.
Consult your computer's documentation to determine the BIOS manufacturer.
It will likely be either AMI, Award or Phoenix.
If you can't determine the BIOS, call the PC manufacturer.
The company should be able to tell you what BIOS is installed based on your serial number or model number.
Visit the BiosCentral website from a healthy computer.
Select your BIOS manufacturer from the Bios Beep Codes list on the right side of the page.
This list describes the various beep codes for each BIOS and what each code means.
Compare the beep code you heard to the beep codes on the list.
This will help you troubleshoot what is broken.
Repair or replace the damaged component to restore your computer's functionality.
http://www.bioscentral.com/
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove new hardware
If any new HARDWARE has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue.
If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device.
Remove any disks or USB devices
Remove any disks, CD's, DVD's that are in the computer and if any USB devices
(Ipods, drives, phones, etc) are connected disconnect all of them as well.
Reboot the computer and see if anything changes.
Disconnect external devices.
Remove everything from the back of the computer except the power cable.
Turn on the computer and see if it beeps normally.
If the computer has never beeped keep the monitor or display connected to see if any change occurs.
Check all fans
Make sure all fans are running in the computer.
If a fan has failed (especially the heat sink fan for theCPU) your computer could be overheating or detecting the fan failure causing the computer not to boot.
Check all cables
Verify that all the cables are properly connected at that there are no loose cables by firmly pressing in each cable.
All disk drives should have a data cable and power cable connected to them.
Your power supply should have at least one cable going to the motherboard.
Many motherboards may also have additional cables connected to them to supply power to the fans.
Disconnect all expansion cards
If the above recommendations still have not resolved the irregular POST, disconnect the riser board (if applicable) and each of theexpansion cards.
If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue.
Disconnect all drives
If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA ,SCSI or other data cables from the CD-ROM ,Hard Drive and Floppy Drive from the Motherboard.
If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue.
Remove the RAM
If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions.
Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
Re-insert the memory into the same slot.
If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
Try one stick of memory in each slot.
If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory.
Try to identify what stick of memory is bad and replace it.
If you're able to get memory to work in one slot but not another slot.
You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard.
Power cycle the computer
In some situations a computer may have power related issues often caused by either the power supply or the motherboard.
To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time.
In some situations you may be able to temporarily get the computer to boot.
This should only be used as a temporary workaround if you're able to get this to work.
Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware.
Disconnect and reconnect the CPU
For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer.
Bad motherboard, CPU, RAM, or power supply
If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard, PSU, CPU, orRAM.
The next step would be either to replace these components or have the computer serviced.
If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers.
Posted on May 14, 2013
I am looking for an instruction manual for a Royal CMS 480 Plus
Try Googling (royal)(CMS 480 Plus)(manual) without parens.
Sep 30, 2017 | Retail Supplies
Laminator will not stop beeping
We just brought home a new Royal Sovereign Laminator. Plugged it in and turned it on. It will not stop the loud, annoying beep and is stuck on reverse. It's going right back to the store for a refund. Will not ask for another Royal. If you can't make it right, don't try to sell it!
Apr 02, 2014 | Royal Sovereign 13" APL-330U Hot & Cold...
Total Z-out for royal 482nx cash register
I would like some instructions how to operate my Royal 482 NX Register.
May 21, 2012 | Adler Royal CMS 480 481 482 CL4000 Cash...
My Nechhi Royal Series Sewing Machine Has stopped working
Make sure the stop motion wheel is tight, make sure you do not have any thread stuck in the raceway area if you get a buzzing sound from the motor
Feb 17, 2010 | Sewing Machines
When turned on, all it does is beep,,,,,,,,,and beep and beep.
Assuming this is a Royal Satellite 40 or 80......
Check the multi-strand cable harness that runs from underneath the carriage...it is likely there are one or more wires broken.
**Also the silly part...make sure you have a print wheel in the machine.
Dec 09, 2009 | Royal Office Equipment & Supplies
My 480 NT Royal Cash Managment System shows "EE" on the screen and beeps not stop
turn the machine to PRG - unplug for 20 seconds. while pressing clr plug back in
May 25, 2009 | Royal Office Equipment & Supplies
Types a few characters then stops typing and just beeps...
Perhaps you have the R. margin set at that point. Try resetting it at the R. end.
DickyO
Mar 18, 2009 | Lexmark Wheelwriter 1000 Typewriter
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
