Dixon ztr ram 44/968999612
The drive belt broke, in doing so it chewed off some wiring ( 2 lines colour coded green )Where are these connected to please> regards Wallace
3bachelors
  • 52 Answers
SOURCE: Tow bar wiring
use the wires inside the hatch behind the plastic panel on either side. Wiring for your car is as follows -
Parking Lights YELLOW (-) 1K OHM RESISTOR AT THE STEERING COLUM HARNESS USE A 1KOHM RESISTOR Brake Lights WHITE/TAN (+) AT SWITCH Reverse Lights VIOLET/BLACK (+) 72 PIN CONN POS 6 BEHIND PASS KICK
Good Luck, NGK
Posted on Sep 04, 2008
  • 85 Answers
SOURCE: Dixon ZTR buzzes but won't start.
Clean the battery connections to bsre metal
Posted on Aug 07, 2009
  • 61 Answers
SOURCE: where on the Dixon ztr 5421 do you check the
there should be a sight glass or a dip stick in the
hydraulic tank.
Posted on Sep 06, 2009
Dolfoff
  • 148 Answers
SOURCE: Dixon ztr 311 The left lever will not make the
The motion drive design is similar to a set of spider gears, except it uses friction material rather than bevel gears in the cluster. The friction material may be worn down to the point that it no longer engages and needs replacement. This is a likely scenario for the symptoms you describe.
The replacement procedure is a rather involved process. If you feel confident and are VERY handy, reply to this post and I'll be happy to go into detail.
Hope this helps!
Posted on Oct 01, 2009
Testimonial: "Thanks, lots of help. Details would be great"
  • 181 Answers
SOURCE: Hi Good morning ,
enble front port settings
Posted on Oct 27, 2010
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
Belt pattern for blade drive belt on Dixon ZTR6022
Try googling for the owners manual to view that
Oct 04, 2014 | Garden
Need a belt diagram for a dixon ztr 5023
Dixon 5000 Series Belt Diagram
Jul 21, 2014 | Garden
Carb problems
check and see if all your carb jets or clean sound like some dirt got into one
Jul 07, 2014 | Dixon Ticonderoga NEW 52" DIXON ZERO TURN...
My 12 year old Dixon ZTR mower turns to the right only slowly. Left turning is normal. The right steering lever has to be held farther forward than the left one to go in a straight line. Repair shop...
Hi, first check your tire pressures are equal then check/replace wheel drive belts and pulleys for uneven wear. If all ok adjust the drive link arms until it travels straight. Regards Phil.
Jun 14, 2012 | Garden
I need a left rear axle for a dixon mower it is bent so the chain jumps off, and a diagram of the rear assembly. It is blue with the levers between your legs, it has a 12hp motor. I am not sure what year...
You can eventually find your manual here:
http://www.dixon-ztr.com/node2171.aspx
There are a ton of manuals.... on that page. Looks like it will be a tedious hunt with out a model number.
If the link does not work go to
and click on support.
If you can come up with a part number you might be able to get it here:
http://www.lawnmowerpros.com/Dixon.htm
They also have parts manuals on this page:
http://www.lawnmowerpros.com/Dixon/Dixon-Parts-Diagrams.asp
Thanks for using FixYa.
Kelly
Mar 09, 2010 | Mtd LAWN MOWER PART # 903-0382 AXLE...
Should I buy a used 311 Dixon ZTR for my 1/2 acre yard?
Never buy one. Ever. Unless you have a mechanic from Dixon that will live with you to fix it every time you turn it on. I HATE it. If it isn't one thing, it is something else. Will not run. Tires a worthless. Seven thousand dollars of ****. Just call and complain and see if anyone cares. Nope. Cannot keep battery that works more than a summer. Nothing but trouble. Cannot get anyone west of the Mississippi to come to your house to service it. Must pull it in a trailer to get it serviced. Over all --junk. No one helps from Dixon, no one cares. Cannot wait until they go out of business. A sling blade would work better. Please get sheep or goats. Much more reliable.
Mar 07, 2010 | Briggs & Stratton Garden
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
