Question about Refrigerators
Refrigeration My Maytag refrigerator works good but after a few days it stop's getting cold. I changed the thermostat but still doing the same thing. Anyone have a suggested solution for this problem?
    Top Expert:
  • Refrigerators Master
  • 51,174 Answers
Check to see that the compressor is working by turning there controller to off and then up. The motor should cut in and vibrate the cabinet and heat the back of the unit and cut out when turned off. IT may need a new capacitor for the motor and if that is outside the sealed unit OK you can do it but if inside it will need a compressor unit replaced.
Posted on May 11, 2013
  • Jesus Valenzuela
    Jesus Valenzuela May 11, 2013
    One time, I opened the freezer door and behind the back panel I saw a red light but it turned back off. You think that that\'s part of the problem?
  • Jesus Valenzuela
    Jesus Valenzuela May 16, 2013
    Jesus Valenzuela on May 11, 2013
Refrigerator runs continuously. freezer cold but even though running all the time main cormpartment does not freeze up.but stays cool not cold.
How old is your refrigerator? I do believe most manufacturers have a 10 year warranty. Try getting in contact with a appliance repair shop...give them the make and model number...they should be able to confirm whether you still have a warranty through the manufacturer.
Good luck
Jason
Oct 04, 2014 | Maytag MTB1504ARS Top Freezer Refrigerator
Hi, how can i fix maytag refrigerator gt1626bas and it doesn't defrost, ice was all over, I melt it, and I checked the heater,but it's cold, few days ago it stoped working completely but in the back
IS THE TIMER MOVING TO ACTIVATE A DEFROST CYCLE? IF SO THE HEATER MAYBE OPEN CIRCUIT; OR DEFROST SENSOR IS OPEN CIRCUIT EITHER WILL STOP A DEFROST CYCLE HENCE LOADS OF ICE!!!!!
May 11, 2014 | Maytag Refrigerators
Maytag 51105349JA refrigerator top freezer snowing up and won't stop running
Defrost thermostat, defrost timer or defrost heating element is bad. Because of that the evaporator is clogged with ice and the cold air cannot get to the fresh food section. Therefore the thermostat control doesn't get cold enough to turn off the compressor. On the other hand the temperature thermostat may be bad and stuck inn the on position causing the ref to operate continuously thereby defeating the defrost cycle. Uplug the ref and allow it to thaw completely. (24hours). Then while its quiet... turn the thermostat to OFF or 0 and then to the coldest setting and listen for a click sound. No click sound means bad thermostat. Later after thawing plug in refrigerator and observe function after 2 hours and check for cold air flow to the fresh food section. If the refrigerator appears to be okay... the problem is a defrost issue. Most typically a defrost thermostat is bad, but when behind the freezer panel is a good time to perform an ohm/ continuity check on the defrost heating element.
Feb 08, 2014 | Maytag Refrigerators
Maytag MSD2556AEW; Fridge and freezer not cold
Without actually putting gauges on the system to see what is really going on, I would say that your compressor has failed. There is a good chance that it is something inside that has broken. Turning it off and back on will give it another life sometimes but like youexperienced it is usually short lived.
I assume that you have checked that the condenser fan is running underneath the fridge. Also that the condenser coils are not completely plugged with dirt. These things can also make your firdge od wierd things...
This should give you a couple of things to checkout, but I fear that the compressor is bad and you will need to replace it or get a new refrigerator. If you choose to replace the compressor get a full price quote before the work is done, as it may not be worth doing if you have an older refrigerator.
I hope that this helps you to solve your problem.
Thanks for using Fixya!!
Heatman101
Nov 25, 2009 | Maytag MSD2756G Side by Side Refrigerator
Whirlpool Estate series fridge/bottom freezer no longer gets cold
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Refrigerator not cooling: Maytag Plus: Model MSD2756GEQ
Your PTC relay is bad and needs to be replaced. It is on the side of the compressor that connects the wires to it. Cost is about 50 maytag price or you could go with a 3 in 1 cost about 15. If you need any help get back with me and can walk you though it. Ken
Aug 15, 2009 | Maytag MSD2758G Side by Side Refrigerator
Maytag, side by side refrigerator stopped working
Check the thermostat which is located in the top left hand coner of the refrigerator. Also check the relay on the compressor to make sure it is not staying open all the time. Also there has been a huge recall on Maytag side by side refridgerators made between 2001 and 2005. I would also try calling Maytag and get the problem fixed by them by recall
Apr 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator operates properly for a few days then stops working
When you said it stopped working, do you mean it is not working at all? or is it not cold enough? If not working at all, that will be thermostat, when you change the thermostat, did you adjust the small switches to match you unit and make sure wires are connected properly, If not, it would work properly. If not cold enough, check and make sure the condenser fan motor and compressor are running, if both are running but not cooling then you have sealed system problem.
Mar 28, 2009 | Marvel 6BAR-BD Beverage Cooler
Refrigerator not cold.
if the freezer section is still working ok then check for ice build up inside freezer on the back wall, its possible that the unit is not defrosting and ice is building up on the cooling coils, the most common culprit is the def thermostat. easiest way for you to get it going again fast is to manually def the coil.
remove the 2 screws about half way down the back freezer wall. then using a blow dryer def the ice from the coil.
since this refrig has an electronic def control i would recomend calling a reputable service company to check it further for you..
Dec 19, 2007 | Maytag MSD2456G Side by Side Refrigerator
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
