Question about Magellan RoadMate GPS
My magellan roadmate 5120 when turned on does not connect to the sattelite
SOURCE: magellan roadmate 300
I posted yesterday as a guest with the same problem and then I contacted Magellan by email from thier site...this is thier disappointing response...It took less than 24 hours though.
Thank you for contacting Magellan. This email is in response to your query
about the RoadMate 300.
Our Sincere apologies for the delay in responding your email.
I understand your mail that you are unable to download or install the
software.
We apologies to inform that NO software in Magellan support MAC
Computers/Windows Vista.
I am sorry to inform you that all Magellan units are only compatible with
Windows 2000 and Windows XP.(Household and Professional) Currently we dont
have any drivers for Windows Vista. I request you to try with a different
computer.
I am confident that the above information would help you in resolving the
issue. If you have further queries, please get back to us.
You can also contact our Technical Support at 1-800-707-9971 for further
assistance.
Regards,
Magellan Email Support.
Posted on Jan 20, 2008
  • 3 Answers
SOURCE: Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
Posted on Jan 26, 2008
  • 9 Answers
SOURCE: My Magellan Roadmate won't turn on
THere is nothing wrong with it. On the left side of the unit pull up the rubber cover. You will see a very small switch and a button above it or below it.
With a a pen slid the switch, and push the re set button. Then slid the switch back. and turn on the unit the way you normally do. If it doesn't light up
either you did it wrong, the unit is discharged, or there is something wrong with it. If nothing works call Magellan and if it is still under service, they will help you. Good luck to you.
Posted on Jan 22, 2009
  • 54 Answers
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Posted on Mar 10, 2009
  • 5 Answers
SOURCE: Can I charge my Magellan roadmate with USB cable
It depends on the Roadmate that you have. :
- If your Roadmate has a separate plug-in port for charging your unit IN ADDITION TO a USB port, then no, your Roadmate cannot be charged using your computer via the USB cable.
- If your Roadmate only has a USB port available for charging your unit, then yes, you can charge it via your computer via USB.
However, please note, according to Magellan, charging your unit using your PC via USB can take up to 12 hours to charge vs. 4-6 hours when using the vehicle power adapter.
FYI: This is mainly due to USB constraints on pretty much all electronic devices. USB cannot carry the same amount of power to a device. It uses what is commonly known as a 'trickle' charge to recharge a device. It carries much less current than a full-blown charger (like an AC power adapter).
Posted on May 16, 2010
Magellan roadmate 5120. How do I reset it?
You can probably find your answer by downloading this free manual on your Magellan: http://support.magellangps.com/support/index.php?_m=downloads&_a=viewdownload&downloaditemid=227 I hope that helps!
May 14, 2015 | Magellan GPS
How can I get a Users Manual for the RoadMate 5120-LMTX? (downloaded to my computer)
The manuals for all Magellan GPS units (and most other products) are available for free download in the support section of the Manufacturer's websites. For your product, the manual is available at http://support.magellangps.com/support/index.php?_m=downloads&_a=view&parentcategoryid=362&pcid=19&nav=0,16,19
Jun 01, 2011 | Magellan GPS
Magellan roadmate 5120-lmtx...cant find a user manual
It is free from the Magellan site located at this link
http://support.magellangps.com/support/assets/manuals/OM_5045T_5120_032211.pdf
May 02, 2011 | Magellan GPS
Just bought magellan roadmate #5120 LMTX ....it said download the user manual from www.magellangps.com/support for details information.....where is it?
I am glad to HELP YOU!
I understand your frustration, pal! But I think you will become even MORE FRUSTRATED when you will take a look HERE, on the Magellan webpage, and you will see that you have to order and to pay for a USER MANUAL.
But I've found a way for you. THIS is the missing manual you're looking for, in PDF format.
GOOD LUCK!
... and don't forget to RATE, please...
useful WINDOW TIPS!
May 01, 2011 | Magellan GPS
Can you download an update for a magellan roadmate 1430?
Yes you can: Enter your info here http://www.magellangps.com/support/
English Manual: http://docs.google.com/viewer?url=http%3A%2F%2Fwww.magellangps.com%2Fassets%2Fmanuals%2Froadmate_1430_manual_en.pdf
Magellan® RoadMate® 1430 Software Update Version 3.12: http://www.magellangps.com/support/chooser.asp?prodid=2056&supportid=806
2009 Spring Map Update: http://www.magellangps.com/products/map.asp?tab=0&PRODID=2194
As for connecting it to the computer, you'll need the usb cable that came with it. Then you'll want to do this:
Follow these steps to connect your Magellan RoadMate to your PC.
  1. Turn ON your Magellan RoadMate.
  2. Touch "Map" to display the map screen.
  3. Connect your GPS to your PC using the USB cable.
Oct 19, 2009 | GPS
How can I get the code to unlock the European map Magellan Roadmate 760
You will need to pay Magellan for the authorization code, they are the only one that can provide you with an EU code for your Magellan 760 RoadMate. Sometimes Auto Nav 2000 Plus, Inc can also assist. They have direct connection with Magellan to assist issues with Magellan products. Good Luck
Aug 04, 2009 | Magellan Roadmate 760 GPS Receiver
Language on Magellan Roadmate 300
You'll have to obtain a copy of the Magellan Roadmate manager disks, load them into your computer, connect the GPS to your computer using the USB cable and the use the "Roadmate Manger settings" to change the language.
Sep 15, 2007 | Magellan RoadMate 300 GPS Receiver
GPS Logo
35 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
