Question about Cell Phones
Gt b7210 Manual
How do I ge the sd card out
What does code 912 mean? i get this when downloading apps from apps store
There are a few reasons why you would get a 912 error when downloading apps.
  • Downloading apps directly to an SD card
  • Play Store (app store) needs to be updated
  • Bad cache
The following methods could help solve the problem
Clear Cache and Reboot
  • Go to Setting >> Go to Application Setting (In some devices application setting is named as apps).
  • Go to, All the apps > >Find the Google Play Store >> Clear Data and Cache
  • Once you have clear everything, Next you need to Force Stop the application
  • Also, try to clear Cache and data of Download Manager and Google Service Framework.
  • Now, Restart your device and try to download the app.
Unmount SD Card
  • Go to Setting >> Storage >> Scroll down and select "Unmount SD card"
  • Open Google Play Store >> Download the app again that was giving you the error message
  • After successful installation, Go back to Settings >> Storage >> tap on "mount SD card"
  • If above steps didn't work, also try removing your SD card before installing.
Move app to phone
  • Go to Settings >> Go to Apps >> Select, All the apps
  • Scroll down and select the app that was giving you the error during update
  • Select "Move to phone"
  • Open Google Play Store and update the app
  • After successful installation, you can move the app back to SD card
Feb 01, 2018 | Tablets & eReaders
How do I get my pictures to save to my sd card?
Make sure you have an SD card inserted in the camera and formatted. You didn't specify the model of your GE camera. Some of them accept only SD cards, not SDHC cards. If your camera is one of these, make sure you have an SD card, not an SDHC card.
May 10, 2012 | GE Cameras
When i try to take a pic, the words "WRITE PROTECT" appears on my screen & wont let me take a pic, can you tell me why this is?
Try to format your SD card on your computer, you should be able to uncheck the write protect option, in the format menu.
Hoping for a Windows-based computer, Start > My Computer > under "devices with removable storage" right click on your SD card, choose format, options should appear.
Hope this helps...
Jan 07, 2012 | GE A1455 Digital Camera
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
My sd card is saying blank and unsupported
Is your computer able to read the card with an SD adapter? If so, back up any information on it to the computer. Put card back in phone and go to settings->storage->unmount SD card->then format SD card. Allowing the phone to format the card usually has better results than formatting it in Windows because it's going to use the correct file system type.
Hope this helps
Ray
Mar 02, 2011 | HTC G1
How do you format sd card for quickfire
Hi alln1nite,
I just found this so I hope it works for you too:
  1. Put the SD card in a reader hooked up to a PC. Move everything off the SD card and into a temp folder I created on the PC.
  2. Put the card back in the phone and have the phone reformat the card, thus ensuring all folders will be read correctly (Settings > Phone > Memory Meter > SD tab > Format)
  3. Put the card back in the reader for the PC and copied things from the temp folder and into the appropriate folders the phone created. (Music, Video, images, etc)
If you don't have anything on the SD card to back up just continue with step 2.
Regards
Myke
Feb 23, 2011 | AT&T Quickfire Cell Phone
When trying to review pictures taken the message unable to recognise files comes up and doesnt save the last picture taken.We have a x5 GE digital camera.This problem happens most of the time.
Hi
Sorry to hear of the problem with your GE X5 camera.
I would suggest you start by removing the memory card, placing it in a memory card reader attached to a computer. Download the SD Card Association formating program (http://www.sdcard.org/consumers/formatter/) then format the card.
This should solve any corruption issues the card could be suffering from which in turn could cause the problems you have.
Hope this helps
Regards
David
Jan 13, 2011 | GE X5 Digital Camera
I cannot access my SD card on my cellphone thus I donnot know where to open it on my menu
SD card in Nokia mobile can be opened in two ways,
1. Click on Menu --- > Gallery ---- > SD Card
2. Click on Menu --- > Applications --- > SD Card
By default the name of the SD card is "no name". You can change that name as the following
1. Menu --- > Applications --- > SD Card --- > Options ---> Rename mem.card
Enter the new name and press ok.
Jun 26, 2010 | Lands Phones
I have the LG Rumor 2 phone and when i put the micro SD card in the phone reads can't initialize music D8. How do I fix?
Did you format the SD card for your phone?
Turn off the phone and seat the SD card. Turn on the Phone and goto menu > settings > tools> memory > card memory > memory usage > options - Format card.
Apr 01, 2010 | LG RUMOR Cellular Phone
Cell Phones Logo
50 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
