I have a hp g71 laptop and it keeps shutting down and says module 701 not found it also started making like a crackle sound then shuts off please help me
  • 5,660 Answers
Error message - Module 701 error - means there is a problem with the Wireless card. Correct speak? Wireless Module
We need to diagnose, Christine
I would like to first suggest, to remove the Wireless Module, and see if the laptop works again.
There will probably be another error message, that there is a problem with wireless.
However one step at a time.........
Wireless Module removed, and laptop works, of course we now know the problem is just the Wireless Module, and not further into the computer.
1) Remove ALL power. Remove the AC adapter, (Charger)
FIRST, unplug the AC adapter from the surge protector, then unplug the AC adapter from the laptop.
(This method avoids a possible voltage spike)
Next remove the Battery.
Now press the Power On button, and hold down for a count of 10 seconds. (Relieves all residual power)
2) Suggest lay a soft static free cloth on a table, and the laptop laid upside down on it. Bottom side up, and Battery Compartment AWAY from you.
3) Remove the Wireless Compartment Cover,
http://www.ebay.com/itm/HP-G71-340US-Bottom-Housing-cover-A-Condition-370P7BATPG0-/261211061790?pt=US_Laptop_Housings_Touchpads&hash=item3cd1647e1e
This is the Base Enclosure, or also can be stated as the Bottom Cover; for sale. Using it for reference.
The Main view automatically shows as the Inside view.
Below the Main view there are two smaller views. Click on the view to the Right. Then put your mouse cursor on the main view.
Here in the Bottom view of the Bottom Cover, you can see the Battery Compartment at the Top. (And naturally, battery removed)
Immediately below it is a small rectangular open area, to the Battery Compartment's left side.
This is the Wireless Module Compartment.
One Philips head screw to remove. (No.1 Philips screwdriver, or equivalent Jewelers screwdriver)
Lift the cover up on the screw side.
This is what the Wireless Module looks like by itself,
http://www.ebay.com/itm/HP-G50-G60-G70-G71-CQ61-HDX-X16T-Laptop-Wireless-N-Card-/400116846704?pt=US_Internal_Network_Cards&hash=item5d28d29070
Looking at the Left side of the Wireless Module, note there are two small rounded terminals.
These are marked by the numbers 1 and 2.
When you remove the Wireless Module Compartment Cover, note that there are two wires attached to the module.
If memory serves one wire is Black, the other one White.
Make a note, and/or small drawing as to which of these wires go to the No.1 round terminal, and the No.2 round terminal.
They must be attached correctly later.
The rounded terminals on the Wireless Module, marked as No.1 and No.2; are essentially little cylindrical posts, and have a round flat top on them.
The Wireless Antenna wires connecting clips, are a flat spade terminal type of affair, with curved over edges; and have a flat spring underneath attached.
To remove the clips, gently push down on the clip, then slide back.
(Back towards the wire in the clip)
The wires are Wireless Antenna wires.
They thread up through a cavity hole in the body of the laptop, and go up by the Right Hinge, then up into the Display Assembly.
The Display Assembly has a Wireless Antenna that they connect to. There is NO power coming from the Wireless Antenna wires.
The power TO them, comes from the Wireless Module.
The Wireless Module receives power from the slot on the laptop, that it is plugged into.
I do not believe that if the Wireless Antenna wires were left to just dangle, that either one of them could contact, the contact pins in the interface slot of the laptop.
Then again, I do NOT want to take any chances with your laptop.
Suggest wrap a small piece of black plastic electrical tape, on each terminal for the Wireless Antenna wires.
(About as long as your thumbnail will do. Just wrap it over the wire's terminal, like a folded sheet of paper)
There is one Philips head screw, in the corner of the Wireless Module to remove.
Then the Wireless Module is slid back, and removed.
(DO NOT lift straight up at first!
Slide back, until the gold plated contact pins of the Wireless Module, are free from the interface on the laptop that it plugs into.
Then lift up, and out )
Suggest replace the Wireless Module cover, and turn the laptop on.
Laptop works, but indicates no wireless connectivity, you know you just need to replace the Wireless Module.
Laptop does not power up, of course there is a further problem.
This would suggest to me that the laptop is dirty inside, and needs to be cleaned.
Would also suggest if this does not 'cure' the problem, that the Thermal Paste on top of the Processor, needs to be PROPERLY replaced.
I can guide you step by step with either, or both endeavors.
[You will need though,
A) A can of compressed air for computers.
B) A soft small brush (Makeup brush?)
C) Tweezers
D) No.1 Philips screwdriver, or equivalent Jewelers screwdriver.
Thermal Paste needs replacing;
E) A small tube of Thermal Paste
F) A small piece, (1-1/2 inches by 1-1/2 inches. Is cut from a larger piece you buy, ) of Thermal Pad.
(A Thermal Pad is a material that is impregnated with Thermal Paste. It will be used on the graphics chipset)
G) The Large Hadron Collider
NO!............you gonna' believe that last oNe?..........geez!
H) An ESD wrist strap. Average price is around $3 to $6.
Connect it's alligator clip to a good ground source.
I) Believe in yourself. I believe in you.
I have taught two 9 year old children to perform this (In person), and countless people on here.
(It isn't countless, of course. I am just too lazy, to go through the more than 10,000 solutions I have given, to go see.........lol!)
As far as I know......................
Fixya has undergone a site change recently. You know, new 'paint', and 'drapes'. (This I DO know)
Since undergoing this change, I haven't received any response back; from the asker of the problem/s.
No response given by Comment.
Or by Reply at the end of the solution.
('Twilight Zone'.............do-dee-do-do, do-dee-do-do)
Which means to me I may not hear back from you, and be able to guide you further, or answer further questions.
In lieu of this I tried to post all possible solutions to your problem.
However, I may not be able to guide you with cleaning, or possible replacement of the Thermal Paste/Thermal Pad.
If this turns out to be the case, and you need the above information; would implore you to post as a separate problem.
A) Video of completely disassembling an HP G71 laptop;
Part 1:
(Remove WLAN Module starts at 0:23
Wireless Local Area Network Module.
Wireless Module for short)
http://www.youtube.com/watch?v=QEwsUB8fjQQ
Part 2:
Part 1 and 2 of course, to clean laptop, and replace Thermal Paste.
http://www.youtube.com/watch?v=NfechCFqC14
Just in case someday you need to replace the LCD screen;
http://www.youtube.com/watch?v=yIV54EdGxyM
(The Screw Covers are held on by a type of rubber cement.
You just carefully pry them off.
I -> Lightly <- stick them to the Display Bezel, for safekeeping.
This is the thin plastic frame in front of the LCD screen.
Regards,
joecoolvette
Posted on May 11, 2013
5 Suggested Answers
  • 2976 Answers
SOURCE: hp laptop shuts itself down
Get a can of air and really blow the intake & exaust ports and ALL fins. A laptop cooler really helps with this problem but, you have to blow them out too.
Google HDD thermometer and download a temperature indicator. It will show you when things are starting to heat up. Mine runs between 25-33 degrees celcius and will shut down randomly around 34 or above.
Posted on Jan 29, 2009
SOURCE: my sound also crackles and I have a very slow windows startup
That's most likely a virus that's gotten into your sound device drivers. Try updating/reinstalling them. Try Dell's website or a search engine for exact drivers and how to install them.
Posted on Jul 13, 2009
ruben_barrer
  • 117 Answers
SOURCE: Can't reload windows xp. Keeps shutting down???? Acer 2700 Laptop
this happens when you have errors with the hard drive not responding to the new boot or drivers not responding. is this a clean install or a restore? if you are not using the original xp disk the machine came with you may get these errors. the blue screen usually has a message in it. let me know what it says if you get a second.
Posted on Jul 19, 2009
durtopian
  • 408 Answers
SOURCE: Problems with my HP G7000 Laptop
Sounds like a failing HDD and/or overheating.
Posted on Jul 31, 2009
G71-35bnr hp wireless lapto module not found.
That could mean anything from hdd to usb device. Please re post with more information.
Dec 08, 2016 | HP Computers & Internet
Why does it keep shutting down
what are you doing when it shuts down? i'm having a similar problem with my HP. if i have the laptop on a hard, flat surface like a table, it works perfectly, but when i move the laptop to my lap, that's when it shuts down. it seemed to happen every time i touched the battery area. found out that it's a bad motherboard and i have to send it in to HP to be repaired.
Jul 02, 2014 | HEWLETT-PACKARD HP ProBook 6455b(WZ237UT)...
My hp computer keep shutting off after being on a shot time
Is it a laptop or desktop computer?
If a laptop and running windows vista/7 or 8 please take a look in the power options in the control panel, make everything in never. See below. Another question is is there a "bluescreen" after it shuts down?
Feb 07, 2013 | HP Pavilion Computers & Internet
My hp g71-449wm notebook says module 701 not installed correct how do i fix it?
Try performing a BIOS update using the following tool for your laptop model:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-90455-1&cc=us&dlc=en&lc=en&os=4063&product=4125466&sw_lang=
Dec 17, 2012 | HP Computers & Internet
I have and HP G71 and it is only about 6 months old I have recently restored the entire system to brand new. Recently the thing just started shuting off all by itself for no apparent reason today it
It seems that your system memory is the cause of problem
You can run a diagnostic check on the system memory.
If you have two memory sticks in the system try to run the system with one memory stick installed at a time, This will give us a proper idea of which memory stick is causing the problem.
Sep 27, 2012 | HP Computers & Internet
Hp pavillion dv9815 won't start. it just reboots over and over. shutting down each time.
take out the battery, then take out the memory. Put one of the two memory modules back in, and turn it on. If everything looks ok, shut down and put the other one back and try again...if everything is ok...then ok. If it doesn't work after the first one, let me know...
Jun 11, 2012 | HP Computers & Internet
HP G71 Notebook PC - during a movie, screen keeps going black
Go to the control panel > Power Options > Select a Power Plan, look in the middle for Additional Plans, click on that and choose High Performance. Now, look in the left hand pane and click on "Choose when to turn off the display", make sure they all say never. Click on "Save Changes" and exit out of the page.
Jul 09, 2010 | HP VM114UA notebook
My laptop previously used to startup and shut down fast but from two days its taking too long for start up and shut down also , i scan my laptop with Norton antivirus which is updated but no virus found...
Hi, sound like its infected with a virus or a bug, Update your virus scanner and do a complete scan. Also try a great bit of free software, spybot search and destroy, to remove spy ware. Hope this helps?
Jul 07, 2010 | HP 413670-001 - HP Compaq nc6320, nx6310,...
Why do I have to go through the Start, Shut Down, process twice before my computer will shut down?
keeping it updated dont mean you dont have one when your computer dont shut down there is a parasite program keeping it on you need to check it, anti virus protection only protects against known viruses not one that has not been detected yet, once one is found then a program is made to fight and delete it, not before
Apr 07, 2010 | HP Compaq nc6220 Notebook
Dell inspiron 9300 17inch makes crackling sound then shuts down
Please try to upgrade the BIOS version and flash the BIOS. Please check the link and follow the instructions: http://support.dell.com/support/edocs/systems/ins1525/en/SM/bios.htm#wp1179839
Sep 28, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
