Hatch is open and the lock is locked can't get lock to open to close hatch
SOURCE: 2002 Escape
Probably a issue with your actuator... there is a recall due to the "latching system does not meet the inertia load requirement" might want to check with the dealership to see if your vehicle is with this group, hope this helps :)
Recall 04V602000: Liftgate Latch Release Rod Replacement
Certain 2004-2005 sport utility vehicles and certain 2001-2003 sport utiity vehicles having rear liftgate components serviced with 2004 equivalent components fail to comply with the requirements of Federal Motor Vehicle Safety Standard No. 206, "Door Locks and Door Retention Components." The rear liftgate latching system does not meet the inertia load requirement in one direction.
SOURCE: 1998 FORD EXPLORER REAR HATCH WONT LOCK WITH FOB / KEY OR SWITCH
We had the same problem with our 99 explorer there could be two seperate problems , problem # 1lock mechinism is very dirty from road dirt, take inside panel off and clean than spray with lubricant, problem # 2 bad lock actuator needs replacement ! good luck!!!!!
SOURCE: How to remove rear hatch panel on 98 Ford Explorer?
you can get a repair guide at your local auto parts store
SOURCE: rear hatch on my 2001
you may have to remove the interior panel for the tailgate to gain acess to the latch mechanism to maually move the unlock arms to open the tailgate.then lube and freeup the latch mechanism until it moves freely and try it before assembly of the interior panel.
