Question about Ibanez JEM77 Steve Vai Jem Electric Guitar (with Case)
F0709768sin serial number
  • Lia Fox
    Lia Fox Apr 02, 2014
    Hi Alex Malmstrom, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Hi out there, I am trying find the correct age of my Classic Gibson Les Paul and am struggling. it's serial number is 064336. Any help would be great fully appreciated. Thank you
This is actually not an easy question to answer a Gibson (as you may already know) has used multiple numbering schemes..Your guitar may be a 2000... This is from Gibson's site: "Les Paul Classic: This model features an ink stamped serial number with no "MADE IN USA" (just as we used on the original 1952-1960 Les Pauls). Most will be 5 to 6 digits in length, but the earliest examples feature 4 digit serial numbers. There should be a space after the 1st digit with the 4 and 5 digit serial numbers, and no space with the 6 digit numbers. The 1st digit indicates the year of manufacture for the 4 & 5 digit serial numbers, these were used from 1989-1999. The 1st and 2nd indicate the year of manufacture for the 6 digit serial numbers which we've been using since 2000. Examples - 9 xyx = 1989 (4 digit number beginning with "9" used only in 1989) 0 xxyx = 1990 9 xyxx = 1999 00xyxx = 2000 05xyxx = 2005" http://www.gibson.com/Support/Serial-Number-Search.aspx/ Alternatively many people have gotten the best answer by calling Gibson directly: USA: 1-800-4GIBSON HTH!
Dec 10, 2017 | Gibson Music
Can you date gibson acoustic with serial number L-67913 should be LG-2
No, but you can try:
"Serial numbers can be extremely tricky," says Gibson Customer Service Manager Jason Davidson, whose team fields calls and emails regarding every Gibson division. "Some can tell you a lot about a guitar, and some don't really tell you anything. Gibson has had so many different schemes over the years, and now we're using reissue serial numbers that look like the old serial numbers."
Gibson Support Serial Number Search
Nov 17, 2016 | Gibson Music
Could you please tell me the year of manufacture of Washburn mandolin serial number A16672.I suspect it would be approx 100 years old.
Here you go
  • Washburn Frequently Asked Questions - Washburn Guitars www.washburn.com/info/faq Washburn Frequently Asked Questions. General ... Can I buy an instrument from Washburn directly? Washburn Guitars are ... Washburn has used many serial number ...
  • SERIAL NUMBER - Washburn Guitars forums.washburn.com/index.php?topic=6344.0 The serial number will tell you a lot. Sammick guitar factory in Indonesia (SI). The first 1 or 2 numbers indicate the year of manufacture, so without knowing the ...
  • Vintage Washburn Mandolin Restoration: Serial Numbers ... www.vorreiterguitars.com/?attachment_id=1003 The headstock is stamped 10271 (across the grain) and 5280 (between tuner machines, along the grain).
  • Ventage Wahburn Bowlback Mandolin - serial number 17575 www.mandolincafe.com/forum/showthread.php?69653-Ventage-Wahburn...
    • 4 POSTS
    • FIRST POST: 2011-01-28
    2011-01-29 · Ventage Wahburn Bowlback Mandolin - serial number ... Wahburn Bowlback Mandolin - serial number 17575 ... book which includes serial numbers of Washburn mandolins...
  • Washburn Prewar Instrument Styles : Guitars, Mandolins ... books.google.com > Music > Musical Instruments > Guitar
    • 5/5
    • 2 REVIEWS
    This book is the first of its kind to report on Washburn ... rosewood ribs s/h bound serial numbers shaped tortoise ... Washburn Prewar Instrument Styles ...
  • How Can We Check Serial Numbers On Washburns? forums.washburn.com/index.php?topic=16011.0 How Can We Check Serial Numbers On Washburns? ... Washburn M4 mandolin Washburn M1SDL mandolin Epiphone AJ100VS Carlo Robelli J220-VS Guild Pilot Bass
  • Dating a Washburn Mandolin forums.washburn.com/index.php?topic=6573.0 I own a nice F type Washburn mandolin. ... Based on what I learned here about serial numbers, ... I have an old mandolin with Washburn sticker intact inside.
  • How old is this mandolin? - instrument resolved ' Ask ... ask.metafilter.com/244116/How-old-is-this-mandolin 2013-07-04 · From Washburn's website: Washburn has used many serial number formats over the years, ranging from 4-12 characters long. The year of manufacture ...
  • Washburn Mandolins www.washburn.com/products/bluegrass/mandolin Washburn has been building mandolins since the late 1800s so we know our craft and your mandolin is of the highest quality and finest tone. Whether you play bluegrass ...
  • May 25, 2016 | Music
    Is the serial number J96107 a real serial number? I was told that they only went up to J96096.
    As with any hardware, you need to supply a "brand name" or manufacturer and what the "model number" is. Of course, a model number is not a serial number. Even within a brand, each model may have its own set of serial numbers. I suggest you do a google search for "brand serial numbers" replacing the word brand with your specific brand. But here is a short cut that may serve you well:
    http://musictrader.com/?page_id=61
    If you want to try another type of direct google search for your:
    If you do not know the brand, then try the type of instrument and serial numbers. That may offer you a list of different instrument brands with links to serial numbers associated with them. Here is a result for a search for clarinet serial numbers.
    For example: http://www.woodwind.org/clarinet/Equipment/HowOld/
    Aug 26, 2015 | Music
    I have a martin d 18 serial number 1713264
    If that's the correct serial number, it was made in 2013. The Martin serial number chart is at http://www.martinguitar.com/about-martin/the-martin-story/serial-numbers.html
    Oct 01, 2014 | Martin Music
    What year was a fender stratocaster serial number 33170 made?
    This guitar is from the U.S. Vintage Series
    made at the Corona Plant (Fender), USA
    in the Year(s): Cannot be determined from serial number,
    however you can consult this chart showing the
    corelation between serial numbers and dates found on the neck
    Fender MIA RI Serial Number vs. Neck Date (Note the earliest I'm seeing is mid 80s)
    Jul 24, 2014 | Fender Music
    Clarinet serial numbers
    The Ambassador was their most successful student instrument. The serial number is usually on the back near the tenon joints. Olds Sons Serial Number Listings The link takes you to a list of their serial numbers and the dates manufactured.
    May 06, 2014 | Music
    The serial number to my makie onyx 2480 is missing the serial number on the back. how do get it
    Some of these units will have a serial number on the INSIDE of the unit, but this is not likely with this unit. No serial number means the unit has been intentionally tampered with by someone.
    Feb 27, 2014 | Behringer Sx3242fx Eurodesk 32-channel...
    Ibanez JEM77 Steve Vai Jem Electric Guitar (with Case) Logo
    Top Ibanez Music Experts
    Michial Gueffroy
    Wayne Tolonen
    cwradio73
    Are you an Ibanez Music Expert? Answer questions, earn points and help others
