Parrot Par Ck3000 Evolution Ck3000 Handsfree Car Logo
Posted on Mar 17, 2009
Can't connect my nokia 6300 to Parrot Bluetooth Car kit V5.1
Parrot bluetooth kit already installed in vehicle, but no information supplied with it. Tryiing to connect but my phone asks for a password. Have used 0000, last 4 numbers of my tel nr to no avail!
What should I be doing?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1100
Points
6
Try "1234". That's the code on my parrot kit.
A
Anonymous
I cannot get the galaxy ace to automaticaly connect to my car hands frre kit ( Parrot )
The parrot car kit varies, there are about 10 different types of the parrot car kit and the connections varies slightly. Just follow these steps to connect ur galaxy phone to the car kit.
For this model of the parrot car kit,after the installation on your car,ensure the car is on
Parrot CK3000:
1. Start the car and ensure the car kit is on.
2. Activate Bluetooth on your phone, and search for Bluetooth devices.
3. Select "Parrot CK" from the list.
4. Enter 1234 on your phone when prompted for a password or code.
5. The Parrot CK3000 will sound a beep when connected to your phone.
Your phone has now been paired with the Car Kit and is ready for use.
For other models of the parrot car kit,repeat step 1 & 2 above and for step 3, u select the model name like "parrot EVOL" for the CK3000 Evolution model.
How do itransfer a contact number from my nokia phone to a parrott mki9200
Depends which Nokia phone but normally you would select, CONTACTS / MARK ALL / SEND VIA BLUETOOTH / SELECT PARROT.
Try Parrot.com for more info on all Nokia Phones
I changed the car battery and i am not able to connect with my parrot ck v3.13
Some of the vehicle has the 12 dc and not ignition to the cigar lighter socket. You have to check when you switch off the ignition to know if there is a power supply.
Cause after a while, the car kit still under supply will not connect cause it suppose to be already.
Then the advise is to unconnect the product when you do not use it, and simply connect the product and retreive the battery of the phone during a minute and put it on again then you will see if the beep of connection is working.
Cant pair nokia 6300 with parrot minikit handsfree
hi
remove the 6300 battery then re-fit, then try to pair with kit, code should be 0000 or 1234.
hope this helps
1helpful
Trying to connect my new handset with my Parot . when it starts conecting Parot says: Pair the device or something like that.How do i pair the device? I've done it before but I lost the manual.
This is a software issue, you need to update the parrot kit to the latest software. Im guessing you got a new nokia. Nokia changed the bluetooth coding so you can now block devices but it now causes issues with other bluetooth devices.
Using the Parrot VM3.18 car kit and not working with the nokia 6220 handset what can be done
HI IVE GOT A NOKIA E71 PHONE AND I AM UNABLE TO HERE THE CALLS IT IS CONNECTING BUT THE PHONES LOAD SPEAKER IS LOADER THAN THE BLUETOOTH MY VEHICLE IS FITTED WITH A VM3.18 ANY SOLUTION TO MY PROBLEM
Top Parrot Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
