Microsoft Windows XP Professional With Servise Pack 2  for PC
Problem for Microsoft Windows XP Professional With Servise Pack 2...
HD Audio Hardware
By ghegde on Aug 12, 2007
I have a PC
Intel 945 motherboard, duel core processor
windows XP SP2 installed.
PC could not recognise onboard audio hardware.
motherboad Disk included with Sigmatel audio drivers & KB835221 pach I also tried KB888111 pach.
Is there any experts help to solve this problem?
Comments:
Aug 12, 2007
- Hi Benimur
This is the report generated by 'Intel Chipset Indentification Utility'
Detected Chipset:
Intel(R) 945 Express Chipset family
Chipset Components
Memory Controller:
82945G/GZ
I/O Controller:
Intel(R) 82801GB/GR I/O controller hub (ICH7/ICH7R) SATA Controller found in IDE mode
Aug 12, 2007
- Hi Benimur
Detected Chipset:
Chipset Components
Memory Controller:
82945G/GZ
I/O Controller:
Aug 12, 2007
- Hi Benimur
The Number printed on motherboard is
Intel Desktop board
D945GNT
Aug 13, 2007
- 1. it is intel High Definition motherboard. and uses Sigmatel Audio Driver.
2. front panal and back panal audio are enabled at BIOS level
3. 6 channel
4. winxp sp2 is compatible with mb Disc
5. Actually Audio Drivers supplied with MD Disc.
But at device manager-Sound, video and game controllers section will not come. and all other drivers(except audio) installed successfully.
The patch file from microsoft corporation - KB835221.exe is supplied in the cd in order to enable Sound hardware. I also tried patch file from local service person - KB888111.exe - this file works for some Laptop PCs with some Intels make motherboard.
Clarification Request
Posted by satash on May 17, 2009
Solution Link . . . http://www.microsoft.com/Windows-XP-Professional-With-SP2
Same Problem
Dec 10, 2008
-   no se oye nada
-   Guest
Nov 19, 2008
-   no tengo sonido me aparece un cartel de error cuando quiero escuchar algo en la pc que el hadwards de sonido esta desinstalado -   maximilia168
Nov 13, 2008
-   חלעלוו-   Guest
Jun 03, 2008
-   soundmax-   Guest
Best Solution
posted on Oct 01, 2008
Very Helpful)
ravidisco
Rank: Apprentice
Rating: 100%, 1 votes
I HAVE LOST MY INTEL 945 MOTHERBOARD CD PLEASE HELP ME OUT WITH DOWNLOADS
Was this helpful?
Yes
No
Solution #2
posted on Aug 12, 2007
Somewhat Helpful)
Benimur
Rank: Guru  Microsoft Expert
Rating: 88%, 3780 votes
To be able to help you on what audio driver to install, pls specify brand, model and version of your motherboard. If not printed on the MB itself, maybe you can check the info on POST or visually check the audio chipset on the mobo.
Pls post back the info/details. Kind regards.
Comments:
Aug 12, 2007
- Hi again,
The data you posted "Intel(R) 945 Express Chipset family" is being used by several motherboard manufacturers like ECS, MSI, Intel themselves, ASUS. What we need to determine is the motherboard manufacturer, the motherboard model number and its version. Like in the case of the 945 chipset, it is being used by Intel D945PLNML/GNTL/GCCRL, ECS945GZTML/P-AL/G-M3L, MSI 945GCM5F, Asus P5L-MX and others. Each one although using the 945 chipset can and may use a different sound chipset therefore would require a different driver.
Perhaps to assist you in determining the correct model of the motherboard, you can follow these steps:
1. Upon powerup of your PC right after the Video card specs and while the memory is being counted, press Pause/Break on your keyboard; your display near the top will show the model number of your motherboard plus its bios version. There will be a lot of other information available but we only need the mb model number, better still at the bottom of your display, there will be a series of numbers and letters, this will also indicate the mb model number.
Soon as you have these information, pls post back then we can start figuring out what drivers you need.
I would also appreciate if you would remove the "thanks for trying rating" since I have not done anything other than to ask you for additional information about your concern.
Aug 13, 2007
- Hi ghegde,
Based on your posted motherboard model Intel Desktop board D945GNT, there are a couple of things you can check and do:
1. Verify your audio if it is either AC'97 or Intel® High Definition (HD). MB before 2004 are often AC'97 and after 2004 are HD;
2. Verify the settings of the audio at BIOS level;
3. Verify what settings you have, 2, 6 or 8 Channel;
4. Verify compatibility with your OS, for example your i945 CD installer will not work with Win2K; and/or
5. Determine which output you will use, the front panel or the std/rear.
Incidentally, this is a known issue with Intel MBs from D845 series to DQ965. Intel has posted a rather lengthy Audio Troubleshooting Guide @ http://support.intel.com/support/motherb...
There is even a part on how to install a 3rd party add-in audio card, you can draw your own conclusions from that.
For added info, updated drivers are @ http://downloadcenter.intel.com/filter_r...*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
The troubleshooting guide would be a more comprehensive source of suggestion, instruction and information.
If all else fails, you may want to consider installing a 3rd party add-in audio card and disable onboard audio.
Good luck and may I expect your objectivity and fairness towards this session.
Was this helpful?
Yes
No
Solution #3
posted on Feb 12, 2009
Somewhat Helpful)
ISMAILKOYILA
Rank: Apprentice
Rating: 75%, 1 votes
ITS GOOD
Comments:
Feb 12, 2009
- MKI LALA
Was this helpful?
Yes
No
Solution #4
posted on Aug 07, 2009
Not Rated)
chabis
Rank: Master
Rating: 75%, 5 votes
Try this link . . . http://www.microsoft.com/Windows-XP-Professional-With-SP2
To find your best solution.
20
Was this helpful?
Yes
No
Solution #5
posted on Nov 05, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
you are all very bright, as I have the intel 945GZ exp chipset, and have been forced to install win 2K, XP, XP64, Vista, and Vista64 (and a demo of win7). I've simply been trying to find the SATA driver for win XP 64, but so far, every download from Intel fails (luckily Intel won't let you nuke you're system too easy) Don't be afraid of installing Intel software, GO FISHING! the installer will auto-terminate if you do not have the device it is installing the software for. I just hope that they have a driver for the XP64 SATA on my schools crappy boxes that came with no install disk, but let me warn you, if you plan to use win 2K on these 9xx Intel chipsets, you won't get very far with graphics.
Solution #6
posted on Apr 10, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
requird sound driver
Solution #7
posted on Apr 07, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
tytry
Popular Solutions for Microsoft Windows XP
Questions and Unsolved Problems for Microsoft Windows XP
Do you recommend Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC?
Answer
Answer
I'm having trouble getting my Verizon MyFi card to configure on my Dell PC w/ XP or my Dell laptop... (More)
Answer
I have a list of codes for the above topic. However, when I use those keys, I don't get the icon.... (More)
Answer
My daughter has a Fisher Price FP3 player and we have windows vista and it won't work together, can... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Windows XP...:
Top Operating System Experts
Rank: Guru Guru
Solutions: 1407
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Operating System Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
