Question about Singer Sewing Machines
Singer model 384 13016300
How to i set the tension for straight stitch
  • 323 Answers
SOURCE: forgot how to set stitch
Find your zig zag width control and set it at 0 You will have a straight stitch.
sewman7
Posted on May 22, 2008
SOURCE: Singer 8280 is not giving me a useable stitch due to tension is not properly feeding resulting , no interlocking
Make sure that the thread is not getting caught on the handle. I was having the same problem and tried everything only to find that my thread was caught.
Posted on Dec 15, 2008
  • 6 Answers
SOURCE: when making a straight stitch or Zigzag stitch,
Your top tensioner is too loose.make sure the thread runs through all the relevant eyes and then tighten the top tension little by little as you do a sample few stitches.
Posted on Feb 21, 2009
  • 69 Answers
SOURCE: Tension settings for husquvana daisy
Your machine tension should be set between 3-5. If your stitch is too loose on the bottom, you can try to up the tension a little at a time. You can also check to make sure that your machine is threaded properly and also check the tension and make sure there are no threads wrapped up inside the tension between the tension discs.
Posted on Mar 01, 2009
bargainbox
  • 1388 Answers
SOURCE: Kenmore Ultra Stitch 12 model 1595280. Tension
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Bargain Box
Posted on Sep 06, 2009
I have a Singer Curvy 8780. All I want to do is sew a straight stitch. What are the settings?
You'll need stitch pattern 01 in the first group after you press the utility stitch button (top button on the left of the 4 way arrow keys). Press button A (the left most up-arrow below the LCD screen). Use buttons B (move left) & C (move right) to select the needle position and D (shorter) & E (longer) to adjust the stitch length. E is the right-hand button in the group. Start with the tension set to Auto and adjust as needed based on your fabric and thread. For normal straight seams, start with the default settings.
Singer has the manual for the Curvy 8780 on the product site: http://www.singerco.com/products/1545/8780-curvy#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/089a99d1802347d9441d83e8a591e6d0db17b80c.pdf . See page 30 for the stitch pattern; page 40 starts a longer discussion of straight stitching.
I hope this helps.
May 25, 2016 | Singer Sewing Machines
My thread keeps bird nesting on the bottom of my fabric what am I doing wrong? What are the correct settings for a straight stitch?
Is your bobbin threaded correctly? You should be able to pull out the thread slowly while feeling it very slightly holding back. It should not pull out easily or quickly.
Could be something wrong with your tensions, try adjusting the upper tension first by starting at the middle setting and working gradually higher and then lower till you get a neat even stitch.
Nov 29, 2015 | Sewing Machines
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
Bottom thread is still loose even if i try to balance the tension, how do i balance the thread tension?
You bobbin tension CAN be adjusted. First, thread your machine with different colors in the top and bobbin, set your top tension at its default, and run a line of straight, and then a line of zigzag stitches, and compare the results at the top and bottom. You will be adjusting your bobbin to your top tension. If the top tension looks like a straight line instead of stitching and the zigzag looks like "chicken tracks" instead of a zigzag, but the bottom looks like a zigzag, your bobbin tension is too loose.
Remove the bobbin case, and locate the straight-slot screw. There are generally two; one is a Phillips and one is straight--you want the straight one. Leave the other alone.
The rule is "lefty-loosy, righty-tighty." If your stitching displays the above symptoms, it needs to be tightened, so turn 1/4 turn to the right--no more--then test again. You will need patience, but don't turn more than that. It is easy to do, but if you don't do it systematically, you can make things worse, and very slight adjustments can alter the stitching significantly.
Apr 15, 2015 | Singer Sewing Machines
I have a Singer model #6105, what do I set my stitch lenght to and what do I set the tension dial to for just regular sewing?
Your upper tension dial should start at 4 to 5. The stitch length should be at 2.5, or 3. Make sure your settings are on straight stitch, and the rest are set in the middle. I've worked on one of these, and it's a nice little machine.
Feb 15, 2015 | Singer Sewing Machines
Kenmore 19233 very new. When using the zig zag stitch, only reliable at 2mm or less. Increasing width to 7mm results in a straight stitch with a few zig zag blips.
The hook timing is out. If it's very new I'm assuming it's still under warranty. Take it to the place you purchased for repair.
Oct 20, 2014 | Sewing Machines
How do I adust the tenion for a straight stitch on a BrotherXL-3510?
Set the stitch selector to straight stitching.
Set the stitch length to 2.5
Set the thread tension dial (leftmost dial) to 5.
Done
Sep 10, 2014 | Brother XL-3510 Mechanical Sewing Machine
Singer 6235, tension, top thread straight
Bottom tension needs tightening and top tension slacking off
Aug 25, 2014 | Sewing Machines
Top stich perfict but bottom stich too loose on vivo singer machine 1004
Your bobbin tension needs adjusting, and although it is not hard to do and doesn't require that you take the machine apart, you MUST do it systematically. If you don't, you'll make things worse.
First, download the user's manual from the Singer site if you don't have one. On page 20, you'll see a discussion regarding tensions, and what improper tension looks like. Tension is a balance between the top and bobbin.
Then, using scrap fabric, set your top tension on Auto and make sure your needle is all the way up in the clamp. Run a line of straight stitches, and next to it, run a line of zigzag stitches, maybe four inches, and examine it. The illustration on that page will show you what your straight stitches SHOULD look like. If your zigzag stitches show one side that looks like "chicken tracks" but the other side looks like it should, the chicken tracks side is too tight. In your case, if the bobbin is too loose, the top will look like chicken tracks. It helps a lot to use two different thread colors, as well as a third for the fabric.
To adjust the bobbin tension, you will need a tiny straight blade screwdriver. If you have an indication that the bobbin side stitches are too loose, take the bobbin case out of the machine and locate two screws on the side. One is a Phillips--don't touch it. The one on the left of the Phillips is a straight-slot screw--that's the one you want. The saying is "lefty loosey, righty tighty." If your test indicates the bobbin tension is indeed too loose (which can happen over time), you need to tighten it by turning the screw 1/4 (ONLY) turn to the right (righty-tighty). Test again. You should see at least some improvement to indicate you're on the right track, and repeat--turning ONLY 1/4 turn--until your top and bottom tension are balanced. Don't forget to also test with a zigzag; I have adjusted bobbin tensions in the past that looked OK on the straight stitch, but the zigzag indicated I wasn't quite there yet.
Jun 25, 2014 | Singer 2638 Mechanical Sewing Machine
Sewing Machines Logo
75 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
