Question about Refrigerators
Ge refrigerator control panel not working
Display light & door panel not lighting. compressor not running
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
  • 163 Answers
SOURCE: GE refrigerator TDX11SNYAWH.
check your defrost timer and see if it is stuck in defrost.
Posted on Mar 07, 2009
SOURCE: Ge Monogram ZISS420DMAS compressor and fan not running
ICE CREAM WON'T FREEZE
The ice cream does not freeze, it stays soft. I have a GE Monogram 42" Built-in-Side-by-Side Refrigerator.
Posted on Jun 18, 2009
  • 286 Answers
SOURCE: Refrigerator compressor motor will not run.
Does the fan work? If yes then the compressor has a relay and overload that might be bad. Or it could be a compressor that is bad. If its a compressor then you will need to have a tech verify that it is the problem. If nothing is running then it could be a thermostat thats not switching it on. Let me know if you need any more help with it.
Posted on Aug 12, 2009
pilungu
  • 30 Answers
SOURCE: front panel on my GE side-by-side refrigerator doesn't work
Replace the touch pad.
Posted on Nov 07, 2009
The compressor of my GE PFE 29PSDASS floor model comes on for a few seconds then goes off. The lights remain on. What is wrong?
Refrigerator Repair Help ' Appliance Aid
www.applianceaid.com > ... > Refrigerator Help Section
I heard a sizzling noise inside my freezer section and it looked like something ... Myfridge makes a bang noise when it shuts off; My Frost free fridge will not run at all; Myfridge is making screeching/squeak noises; My GE SxS fridge door has ... an amp meter, each compressor is rated in running amps ( see model/serial tag ...
GE Refrigerator Repair Online Manual ' General Electric ...
www.appliancerepair.net/ge-refrigerator-repair.html
FREE ONLINE GE refrigerator repair manual - Diagnose and troubleshoot ... to know basically how the bloomin' thing works, and then get on with fixing it? ... Chapter 5: GErefrigerator problem: Refrigerator is not cold and compressor is ... Do you have somequestions that you would like to ask a professional GE repairman.
Dec 17, 2015 | GE Refrigerators
What can cause my refrigerator to stop working
I would be checking for power at the wall socket, broken wire in the lead (no light) after that get an technician out as it could be the control board failed
Oct 11, 2015 | GE GNE29GGHBB 28.5 Cu. Ft. Black French...
I need to repair my GE profile refrigerator
The first thing you need to determine is if the compressor is coming on. If it isn't then the problem is in the lower section, PCB, start relay or capacitor or compressor. If the compressor does come on, then it sounds like your main board is the problem.
Jan 19, 2012 | GE Profile Stainless Bottom-Freezer...
I have a ge gss22kgpacc side by side, the freezer is working, lights, etc. all working, but the refrigeratoe side is not working, any insight? thanks, mike
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hope this helps good luck ron
Dec 12, 2009 | GE Refrigerators
Have GE Profile refrigerator Quit Working
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Refrigerators
Temp light does not light up and temp does not get cold. inside door latch is broken model #pfs22sisbss
The main control board could solve the display problem . May also solve the cooling problem , but would need to know , if frost build up on back wall inside freezer , are both fans working (freezer and compressor cooling fan) , is the compressor running ,are the coils clean in back of refrig ? Unsure about a "door latch" . The freezer door ,rides on glides , and the magnetic gasket should hold it closed .
Jul 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
My control panel on my ge profile psc23ngpacc is not lighting, and the water in the door dispenser seems to have no power.
G E is going yhrough some changes and one is there now low energy cost compressor that constantly runs just at diffrent speeds. anyway the control circuit board controles everything and the first noticible problem is in the Ice despensor and display board. In most cases after the first replacement the will replace board over and over at no cost for the part that is how common theis part failure is.
Jun 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Nov 28, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
My GE PSS26SGRSS is not working. The panel lights are blinking.
Problem is the circut board in the back, you can go to ge appliances.com go to service and support type in model# go to unit and main board parts to order.
Nov 14, 2008 | GE PSS26SGRSS Stainless Steel Side by Side...
GE Profile does not run.
Just to be sure... check your owners manual to see if this unit has a "showroom switch". It's a little switch that turns off the compressor, etc. but lets everything else light up so the sales persono on the showroom floor can show it off. Some customers have hit the switch to "on" during cleaning by accident.
Sep 29, 2006 | GE Profile PSS26NGS Side by Side...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
