Question about Exercise & Fitness
Reebok active runner
Stops after running, and at times belt wont even run...
  • 64 Answers
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
  • 103 Answers
SOURCE: Reebok Vista belt not working properly
There could be 3 different problems with this machine.
1) loose drive belt (this model has a spring loaded idler that tightens the tension)
2) Bad front drive roller (you wil hear the pulley spinning freely on the front roller if the roller is bad)
3)Last is possibly the walk belt itself. May need to be tightened or replaced.
To try to tighten the walk belt, go to the end of the walk belt and find the 2 adjust allan screws in the end and tighten them 2 revolutions clockwise on both screws.
Hope this helps a little. Tim
Posted on Nov 27, 2009
  • 31 Answers
SOURCE: I have a 6 year old Reebok RX5000. At speeds
They walkbelt is most likely worn out causing too much friction overheating the motor.
Posted on Jan 16, 2010
maxtreadmill
  • 832 Answers
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
Posted on May 14, 2010
maxtreadmill
  • 832 Answers
SOURCE: Reebok treadmill
Hi James
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
Posted on May 24, 2010
1991 Cressida How do i know if my alternator is bad?
if the alternator is not charging , there will be a red battery light on the dash
reasons for engine stopping are
broken timing belt/chain, cam/crank position sensor failure
immobilizer activation
ignition control module failure
run the fault codes as some engine lights only light up for urgent problems that require you to stop the engine
Oct 08, 2016 | 1991 Toyota Cressida
Toyota avolon wont stop running when you turn the key off
This is known as 'dieseling'. The most common causes are
-idle speed set too high
-engine operating too hot (faulty thermostat, faulty temp sender, leaky head gasket)
engine timing is out (loose distributor clamp, worn timing belt, faulty timing belt tensioner)
Jul 19, 2016 | 1998 Toyota Avalon
My audi a5 wont run it starts and cuts out since i fitted a new serpentine belt
How long does it run? Sure you only changed the serpentine belt? The car would actual even run without the serpentine (or also called accessory belt) since the belt only drives fairly non essential components (AC compressor, alternator, fan, power steering pump. etc).
Mar 27, 2016 | 2010 Audi A5
Why wont it run?
Is the motor running? If not, is it receiving power? Is the belt slipping? If motor has brushes, they might need replacement.
Nov 18, 2015 | Nordic Track APEX 6100XI TREADMILL Console
Drive 2007 grand prix. wont even turn over or click.lottsa batery. Everything works. Just wont start or turn over. When starts and I drive it, then stop and turn off,sometimes wont start. Half to sit a few...
SOUND LIKE ALTERNATOR NOT CHARGING BATTERY.CHECK BATTERY VOLTAGE SHOULD BE 12.6 VOLTS.MAY SURE BATTERY CABLES CLEAN AND TIGHT.WITH ENGINE RUNNING CHECK ALTERNATOR OUT PUT AT BATTERY.SHOULD BE 13.5 - 14.5 VOLTS WITH ENGINE RUNNING.IF ALTERNATOR FUSE GOOD AND ALTERNATOR BATTERY FEED WIRE AND VOLTAGE REGULATOR WIRES OKAY NOT DAMAGED.DRIVE BELT NOT SLIPPING OR BELT TENSIONER NOT DAMAGED.ALTERNATOR MORE LIKELY FAULTY.TURN OFF RADIO FIRST.BEFORE REMOVING NEGATIVE BATTERY CABLE TO KEEP FROM LOSING RADIO CODE.
Apr 10, 2011 | Pontiac Grand Prix Cars & Trucks
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
Jan 25, 2010 | Horizon Exercise & Fitness
Stopped running while driving
did it make any weird noise when it stopped runnig while driving? . . maybe timing belt slipped . . does it turn over even though it wont start?
May 24, 2009 | 2003 Mitsubishi Eclipse Coupe
2001 audi tt just stopped running while driving 55mph. wont turn back on now. power works. just wont turn over.
Timing belt might have broke. Same thing happened to mine. Going to cost ALOT of money to fix.
Apr 27, 2009 | 2004 Audi RS6
1991 mitsubshi wont start
check the timing belt ho be sure it hasent slipped off time or even broke
Mar 31, 2009 | 1991 Mitsubishi Eclipse
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
