Question about Refrigerators
I'm trying to find a manual for whirlpool fridge/freezer model Wrid45 ts, I want to replace ecb part no W10527555
My fridge is warm, & freezer is working ok Lights ok,the freezer dial tends to be way too stiff to Adjust
  • 330 Answers
SOURCE: My hotpoint fridge freezer model
check the fan
Posted on Jul 10, 2008
  • 57 Answers
SOURCE: WHIRLPOOL CB18M FRIDGE FREEZER
3 things to check. If you didn't adjust the damer from the freezer to the refrigerator, like closed it off. Is the freezer fan running? The fan blows air from the freezer to the refrigerator section. Some fans shut off when the door is open so you may have to push in the door switch to check this out.
Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap. coil is icing up and there is no air blowing into the refrigerator. Set the thermostat back to the normal setting it just causes a longer run time on the freezer section.
Posted on Oct 20, 2008
  • 36 Answers
SOURCE: top of fridge warm but bottom freezer working ok
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
Posted on Dec 16, 2008
  • 115 Answers
SOURCE: fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Posted on Jan 03, 2009
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
Whirlpool side by side refrigerator freezer is warm and fridge section warm tap on thermostat and everything starts up and gets cold
What is the model number of your refrigerator? In most cases replacing a mechanical thermostat that begins doing this is the answer to solving this problem. Problem is I don't know what the type of thermostat yours has because you did not post the model number. Thanks, Sea Breeze
Apr 05, 2013 | Whirlpool Refrigerators
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
After defrosting, the freezer will not start. - Whirlpool fridge.
I presume that you still have got electricity power and the fuse has not 'blown' - if not you could try putting in a new fuse in the plug, sometimes two problems can occur simultaneously.
Otherwise I would leave the door shut to keep the stuff as cold as possible, some may refreeze, or ask a neighbour, friend, or relative to let me have some space in their freezer.
Aug 28, 2012 | Whirlpool Refrigerators
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
May 11, 2012 | Refrigerators
My whirlpool fridge isn't cooling but freezer is
check if it has iced up around the air vents between the two halves as that will block airflow and warm up fridge. if it is is give it a good defrost to melt the ice and stop it from reicing
Feb 08, 2012 | Whirlpool Refrigerators
THE FRIDGE IS NOT COOLING IN THE MAIN SECTION. CAN YOU HELP?
air blows from freezer to fridg, usually ther is a dial or lever to adjust flow, but look in freezer for any thing blocking vent to fridge, ,also mitwe be a blockage in vent
May 07, 2010 | Whirlpool 21.6 cu. ft. Top Freezer...
Freezer froze,ice and frost,freezer door froze, warm in fridge
change thermostat sensors in fridge and freezer easy
Feb 04, 2010 | Refrigerators
Side by side: freezer temperature fine, fridge too warm
sounds like your auto defrost isn't working. my maytag does same thing. the cooling core in the freezer is probably iced up. when it becomes solid ice no air(or very little) can pass by, leading to too little cold air reaching the fridge. you can try to cycle the temp levers(usually doesn't work) you can manually defrost the freezer. pull the cover off the back(inside freezer) and use a blow dryer. not sure how much parts are for whirlpool. hopefully this is just a one time thing. there are tests you can find to check some of the parts.like the heat element for the defroster, just search for the tests.
Jul 30, 2009 | Whirlpool Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
