Question about Refrigerators
Ge Wiring Diagram
Fridge will not start after being shut down for the winter (at a cottage in Canada). Power ok to interior lights, but there does not appear to be power to the compressor motor. GE model TCX18P.
  • 979 Answers
SOURCE: GE refrigerator wiring diagram
Icemaker must be at 28 degrees to make ice. The harness supplying the power should have 120 volts there at all times, and the icemaker itself is the device that switches the power off and on once all requirements are met. Your diagram for the fridge is on the rear service panel, or in a packet on the insisde rear..accordianman
Posted on Apr 03, 2008
applianceboy
  • 77 Answers
SOURCE: Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Posted on Sep 26, 2007
TJBENGR
  • 121 Answers
SOURCE: Whirlpool fridge freezer ART 462/R.
Is the 8 degrees centigrade? If yes check the freezer fan or for frost at back of freezer...and give me a holler.
Posted on Apr 21, 2008
Just_Bobz
  • 448 Answers
SOURCE: GE Fridge, Compressor not getting power from mother board
I asked that because in most cases, when it is a problem in a motherboard, it is likely a power surge or lightening. I can also tell you that when it comes to mother boards and component level, likelihood, it isn't transistors or anything unless it smells or looks burned. Most shops would just replace the motherboard and ship it as repaired becaue the cost of the IC isn't worth the possibility of something in another IC on the same board knocking iit out again. Short of plug and play, you have no real way of proving this board good/bad. You might try EBAY with your model number to see if you get lucky. I just got rid of an electronic stove because the control board went bad. New board was $150 with a possibility of it going out in 6 months. As I am not made of money, I now have a gas stove. I you could, please rate this as a fixya as I am just being honest and saving you time and aggrivation. Good luck
Posted on Jan 10, 2009
  • 3 Answers
SOURCE: Ge fridge makes Ice, doesn't dispense
turn freezer side to zero for 1 minute. press water dispenser
Posted on Apr 15, 2009
Battery drain ON MY MAZDA TRIBUTE 2008, I HAVE NEW BATTERY!!!THE mechanic after making all kind of does not know what is wrong, help please it is winter here and the drainage is worst than ever, the fuse...
Check for intermittent breakdown of the starter. Also, check for failure of the brake lights and or interior lights to go off after the car is shut down.
Nov 30, 2013 | Cars & Trucks
GE GSS25WGMC door open alarm beeps and both doors are OK and seal properly
check to make sure in fridge and freezer there are switches when the door make contact with it it shuts off the lights-check by hand by holding the swiches down and see if the interior lights go off, if not then you have a bad switch..if they go off then the control where the door alarm is located needs to be replaced
Oct 01, 2011 | Refrigerators
GE model GSH22SGRE - freezer not cooling properly. Ice maker not working. Drinking water works fine now (as temp in freezer has come up to about 20 degrees F). This will be the third time the freezer...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 02, 2011 | GE GSH25JFR Side by Side Refrigerator
Power on Interior lights on refrigerator does not operate not cool
The interior lamps fail to light up as the swittch is faulty , so replace teh door switch if a contact cleaning wont help.
Now the cooling is related to many issues, so shut off fridge to allow time of 5 hours, The restart , if the fridge does not cool , the compressor , gas pressure is done and must be checked. If cooling is present then check if the auto defrost timer/thermostat is faulty as the fridge might stop cooling after 12 hours.
Sep 29, 2010 | GE PSS26SGRSS Stainless Steel Side by Side...
MY FRIDGE CUTS OUT WHEN THE POWER FAILS EVEN IF THE POWER JUST FLICKS ON AND OFF WE CANNOT RESET IT HAS WE ARE ONLY AT THE COTTAGE WEEKENDS, SO WE LOSE EVERYTHING INSIDE
other than running your fridge on its own power source or fitting a gas operated fridge,(bottled gas) you must leave it empty,with the door open.....our friends in Canada have gas for heating and fridge /freezer and a generator, so they dont suffer any power cuts in winter.
Sep 09, 2010 | Samsung RB215LASH
INTERIOR LIGHT GOES ON AND OFF
next time it does this unplug for 20 mins and pcb will reset its self....
Sep 28, 2009 | Hoover HFA290K Bottom Freezer Refrigerator
I have an Eaton-Viking fridge at my cottage in Canada. It freezes some things in the refrigerator and needs a new temperature control. I understand these fridges were made by some other company such as...
The temperature issue will not change as you do not have a frost free fridge. With the type you currently have the older it gets the less it works. Think frost free!
Aug 05, 2008 | Refrigerators
Feb 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Dec 22, 2007 | Refrigerators
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
