Question about Dixon Original Part 23HP KOHLER COMMAND 60" DECK ZTR230060
Dixon ztr Hello I have a dixon zero turn and it works really well until it warms up a bit. Then the blade seems to bog down and I have to mow really slow or it makes horrible screeching noise coming from the deck area. When i turn to the left it seems to allow me to cut any grass, but straight and to the right seems to bog it down intermittenly? Thoughts?
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
Carb problems
check and see if all your carb jets or clean sound like some dirt got into one
Jul 07, 2014 | Dixon Ticonderoga NEW 52" DIXON ZERO TURN...
Why Dixon lawnmower goes slow?
Yes they should be a sealed system. Check the fluid level in the tank.
Sep 16, 2017 | Garden
Exmark 44
When you say 'going forwaed', is that while mowing or does it do it without the blades engaged or 'not mowing'?
Jun 13, 2013 | Kohler Engines NEW 25HP KOHLER ENGINE...
Should I buy a used 311 Dixon ZTR for my 1/2 acre yard?
Never buy one. Ever. Unless you have a mechanic from Dixon that will live with you to fix it every time you turn it on. I HATE it. If it isn't one thing, it is something else. Will not run. Tires a worthless. Seven thousand dollars of ****. Just call and complain and see if anyone cares. Nope. Cannot keep battery that works more than a summer. Nothing but trouble. Cannot get anyone west of the Mississippi to come to your house to service it. Must pull it in a trailer to get it serviced. Over all --junk. No one helps from Dixon, no one cares. Cannot wait until they go out of business. A sling blade would work better. Please get sheep or goats. Much more reliable.
Mar 07, 2010 | Briggs & Stratton Garden
Airens Zoom 1944 ZTR Blades Slow Down In Bahaia Grass
You mention many PM issues but do not mention a blade sharpening. I don't get on my ZTR without a freshly honed blade installed. "That's" what cuts bahia grass...the blade. You can put all the horsepower you want behind the lade but if you're trying to cut grass with a 2X4 it rips more than cuts grass.
Jun 30, 2009 | Ariens Garden
Dixon Original Part 23HP KOHLER COMMAND 60" DECK ZTR230060 Logo
Top Dixon Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Dixon Measuring Tool and Sensor Expert? Answer questions, earn points and help others
