Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Riding mower won't turn over
I have replace both spark plugs, the oil and filter and air filter. The mower sounds like it wants to start but wont turn over. HELP my lawn is outa control. Lisa
  • 640 Answers
SOURCE: My Husqvarna riding mower won't start. I was
Check to see if you left the blades engaged. There is a safety switch that prevents starting with blades engaged. Easy to miss, happened to a friend of mine last month.
If this really helpful, please rate.
Posted on Jul 11, 2011
SOURCE: I have a YTH1542 husqvarna riding mower. Will not stay running
make sure the small vent hole on top of the gas cap is not clogged. Mine did the same thing and then I found mine was packed with dirt.
Posted on Jul 20, 2009
ginko
  • 19396 Answers
SOURCE: Husqvarna riding mower w/20 hp
Hi.
There is gas smell in the carburetor because the engine is not starting and carburetor is flooding.
As first thing ensure that there is spark, pull the spark plug wire and put the end near to engine block while cranking. You will see the spark. If there is no spark, check distribution coil and wires.
If there is spark, check if there is fuel pressure, if there is smell from carb, then the fuel pressure should be Ok.
Once you are sure that the pump is doing its job, and that there is pressure, check the carburetor settings. The mixture is probably too rich or too lean, and for that reason it is not igniting.
If it is not a matter of carburetor settings, then the carb must be taken apart to check carburetor filter.
To get parts and diagrams see: Outdoor Distributors - Lawn Mower Parts
Posted on Sep 26, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Husqvarna CTH180XP rideon lawn mower 42" rear
Hi Sue and welcome to FixYa, I am Kelly. You have been quite lucky to get 7 years out of your battery. Given the age of the battery that is currently installed this is most likely your problem. You have voltage but very little amperage due to thinned out battery plates.... (
Let me know how it goes.
Thanks for choosing FixYa,
Kelly
Posted on Aug 09, 2011
richroth
  • 9472 Answers
SOURCE: I have a riding lawn
Take a look at this tip I wrote on the no start problem.
Posted on Oct 18, 2011
Husqvarna riding mower, (Model: YTH2448) won't turn over
turn on device and wait for response inspect every component for malfunction
May 13, 2013 | Husqvarna Garden
Snapper mower 331416kue won't start
You can try buy a new spark plug and replace it with the old one.
I had the same problem!
You just have to keep pulling until it catches!
Or maybe it's the carburetor that needs to be replaced!
I had the same problem wih my scooter.
I just changed the carburetor and it worked fine :)
Sep 08, 2012 | Garden
Won't start...turns over...took. Air filter off and gas and oil mixture shoots up into their once it starts
sounds like the needle valve in the carb is not seating and the fuel is draining into the oil
May 14, 2012 | Yard Man Garden
My mower won't start
try running it with the gas cap loose the vent might be plugged
Apr 13, 2012 | Garden
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
May 01, 2010 | Poulan Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
221 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
