I cannot boot up my laptop. I get a black screen. I can hear the fan humming, but I do not see the e-machine logo and it does not go into Windows 7. I'm not sure if this is because of a virus or my hard drive is not working. If I put a Windows recovery disk in the DVD drive, I can hear some action but I cannot see anything happening. I'm not sure if the boot order is hard drive or DVD first so I try to go to setup but pressing F2, F12 and Del does nothing. Actually I cannot even see the e-machine logo page. Any suggestions. Thank you.
SOURCE: Replace hard drive on Compaq presario 2190US
I have a 2190 with the exact same problem. I have now found that it is the hard drive. The hard drive should spin with random clicking, not that clock-like clicking. The hard drive is located in the front edge of the unit looking like a drive door. Remove the two rubber plugs and two screws. Pull the "drawer" sharply to toward you to unplug the drive. Then try to boot the computer without the hard drive installed. The computer will now let you enter the bios, etc. Weird, huh?
SOURCE: Does not display setup or boot menu
first try to clean you mother board with anty dust spray
secound on your motherboard you can see clear comos junber behind the battery comos try to clear it ...... i think your motherboard will workink after that
SOURCE: Toshiba Satellite L25-S119 No boot
Had the same problem turned out to be the DVD drive. Apparently it won't boot if the DVD drive is not recorgnized.
SOURCE: Dell Precision 470 Dual Processor
enable "auto" in BIOS for drive #0 and drive #1. you can select IDE or SATA drive. restart the machine.
SOURCE: Can't start windows: Hard Drive - No drive detected
The laptop cannot see/detect the hard drive. This means the hard drive is faulty or it needs reaeating.
Remove the hard drive and inserting again, then reboot the laptop, if it still cannot detect the hard drive then it is faulty.
You need to purchase a new one and install Windows on the new hard drive.
