Question about Garden
Diagram of fuel lines for skil model 1641
Fuel line routing
steve_lima
  • 181 Answers
SOURCE: How to replace the Husqvarna chainsaw fuel line.
let me knoe the model number and i'll see what i have....
Posted on Feb 11, 2009
  • 384 Answers
SOURCE: mcculloch 4600 chainsaw fuel line routing
Shouldn't be that hard to do. Possible paths 1) Run hose from tank fitting to Carb fitting. 2) Run hose from tank to shut-off vale to Carb 3) Run hose from tank to shut-off to prime to carb 4) run hose from tank to shut-off to prime to filter to carb. Omit any item not on your saw.
Posted on Jun 12, 2009
dontbother10
  • 2220 Answers
SOURCE: Diagram of fuel line for Craftsman 16" chainsaw
Your saw is a Poulan. Try converting the cc to a model number. A 2.2cc Craftsman is often a Poulan model 2200. go to this link and find something that appears the same under (POULAN-WEED-EATER).
http://www.ordertree.com/cms/illustrated-parts-list/9788.html
The IPL will help. Pay attention to the year there is a different area for older saws.
For a current saw Craftsman should have something available.
Posted on Sep 04, 2009
dontbother10
  • 2220 Answers
SOURCE: fuel line diagram for 358.352160
It is most likely a Poulan almost all are. The IPL is the only manufacturer supplied fuel system detail, it lists components, part numbers and very little routing detail. and is usually spread over multiple illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
I think you'll find the short video, a few notes and a typical system most helpful. Any local saw shop can provide replacement hose.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
HTH
Lou
Posted on Nov 19, 2009
  • 4088 Answers
SOURCE: Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
Posted on Jul 16, 2010
Replaced fuel lines,vent line is my major problem!
Make and model please.?
Where is the fuel leaking from exactly?
Generally you don't get diagrams od fueling routes. They often go via the most direct route from tank to carb/primer
May 26, 2016 | Garden
Need a diagram of fuel line
You haven't stated the make and model.. BUT generally IPL's don't show the fuel line routing. Generally the most direct route from tank to carb.
If you need any more assistance feel free to ask
May 24, 2016 | Garden
Belt routing for cub cadet 1641
Easiest way is to remember; flat side of belt goes onto flat pulleys and small V shape goes into V shaped pulleys.
Oct 08, 2014 | Garden
Poulanprop fuel line routing diagram
in 1980 it is pretty much forward from fuel tank to fuel pump from fuel pump to carburetor ....the return line from pump to tank
hope it helps
Apr 06, 2014 | GMC C1500 Cars & Trucks
2006 Honda Shadow VLX 600 fuel line routing
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2006 Honda Shadow VLX 600 fuel line routing Google Search Hose routing diagram
http://www.vt600vlx.com/VLX%20VT600%2088-89%2091-96%20Service%20Manual%2061MR107.pdf
https://www.partsfish.com/page/oem-parts-for-honda
http://www.vt600vlx.com/VT600C-1992.pdf
Mar 07, 2013 | 2006 Honda Shadow VLX
1986 Yamaha Fazer fuel line routing diagram
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1986 Yamaha Fazer fuel line routing diagram Google Search Fuel line diagram
Yamaha FZS1000 2001 Service Manual
OEM parts for Yamaha
Yamaha FAZER FZS1000 Owner Manual
Jul 06, 2012 | 1987 Yamaha FZX 750
I need a diagram for the fuel lines on 1997 kawasaki vulcan 750. i took the fuel lines loose and i don't know where they go
Hi.
There is no "diagram" showing the whole routing of fuel lines in the bike. You need to use different diagrams in Fuel System section of the service manual. Fuel system section starts at page 15 in service manual, but what you really need starts at page 40. I have posted fuel service manual at the end of comment.
There is one forum where users discussed the routing. One user has colored the diagram from service manual to indicate lines routing. Here the diagram:
Here the forum, I quote:
"The red and yellow are the fuel lines that go to the petcock. The green one you left unmarked also goes to the petcock. The line with a question mark is a vacuum line that connects to a part in front of the battery along with the larger lines to the cylinders."
Here the service manual in PDF format.
Regards.
Ginko
Sep 05, 2011 | 1988 kawasaki VN 750 Vulcan
Need diagram / pictures of routing of all fuel lines. 1981. CX500 Custom
It's hard to find diagram for older bike.
I got the pic from the tank to pet ****.
LINK HERE
Aug 10, 2011 | Honda CX 500 B Motorcycles
Need diagram of fuel lines from tank to primer bulb and carburator on a Poland chainsaw model 1950 wood shark
There are 7 different types of the 1950 model (types 1 - 7) and it came with one of these 2 carbs Walbro or Zama. The carbs are different as are the fuel line connections for each one.
Although this video is for the promer bulb you can see the routing of the fuel lines.
http://www.ereplacementparts.com/article/4262/How_to_Replace_a_Primer_Bulb.html
You will have one line from the fuel tank connecting to primer bulb the 2nd line going to the carb. If you connect it backward it does not pump fuel into the carb.
Kelly
(FYI Types 1 - 5 all have the same fuel line routing.)
Apr 12, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
