Question about Zanussi IZ12 Front Load Washer
Filling The washing machine drum does not seem to fill properly so that very little water is visible in the drum when it washes. As a consequence, wash performance is low and clothes often come out smelling. The machine cannot cope with large sheets.
  • Anonymous May 17, 2008
    my LG Intellowasher 8013f sounds same. Even stopping to restart, hoping to at least get every artical wet, is no good.At the 3rd start NO extra water enters. no bubbles in sight either. Being my 1st front loader I just thought "great  water saving" but no. A tiny wash is just ok with refills. no wash size options. i don't know. ok thanks, karin
    Novelist:
    Champion:
  • 244 Answers
Have u got the echo-fill button on if it is it will only fill up with very little water other than that without seeing it cant say
Posted on Aug 12, 2007
SOURCE:
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
Hoover washer dryer - not sure it is filling with enough water
How old is the machine and which wash cycle are you selecting? Newer machines use very little water; it is not needed.
Mar 08, 2014 | Dryers
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
New washer, seems to work fine. I just question the water filling sequence at start of a wash. The water valve opens in 1 sec spurts about 6 times when drum is rotating in one direction. On 7th time it...
Every few months, new things are done to improve washing methods. If washing machine is washing clothing cleanly, and no apparant fault code comes up, then it is how the controller is programmed and meant to be.
Aug 14, 2010 | LG Washing Machines
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Washing machine filling with water while not running
youll need to replace the water inlet valve, its not seating properly after fill, and continues to leak into machine.part number 8181694. in hte ean time you can turn off water supply to machine inbetween wash loads.A good habit to be in anyway.
Mar 17, 2008 | Washing Machines
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Zanussi IZ12 Front Load Washer Logo
104 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
